Ana içeriğe geç
Pioneer R1 Battery Replacement
Neye ihtiyacın var
  1. Pioneer R1 Battery Replacement, Battery: adım 1, 1 resimden 1.
    • Insert your plastic spudger into the opening near the HDMI port.
    • Gently pry the back cover of the R1 from the the front by using the spudger along the edges.
    • Do not pull the back cover straight off the R1 as components of the speakers will be attached to both sides.
  2. Pioneer R1 Battery Replacement: adım 2, 1 resimden 1.
    • Lay the R1 flat like an open book.
    • This will prevent the speakers from becoming disconnected from the motherboard.
  3. Pioneer R1 Battery Replacement: adım 3, 1 resimden 1.
    • Slide a strong thin object, like a thin spudger, between the battery and the display.
    • Slide the object along the length of the battery to remove it from the display.
    • The adhesive holding the battery in place is strong and the battery is quite soft. Take care not to break open the battery.
    • Disengage the battery cables from the motherboard.
  4. Pioneer R1 Battery Replacement: adım 4, 1 resimden 1.
    • Solder the black cable to the nodule labeled BAT+.
    • Solder the red cable to the nodule labeled BAT-.
    • Do not allow the solder from one nodule to touch the other, this may cause the battery to explode.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Christopher Rosario
411 İtibar
4 adet Kılavuz yazıldı
Ekip
San Diego State, Team 1-1, Sheppard Winter 2015 San Diego State, Team 1-1, Sheppard Winter 2015 üyesi
SDSU-SHEPPARD-W15S1G1
3 Üyeler
7 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 7
Her zaman: 792
