Ana içeriğe geç
Pioneer R1 Touch Screen Replacement
Neye ihtiyacın var
  1. Pioneer R1 Touch Screen Replacement, Touch Screen: adım 1, 1 resimden 1.
    • Insert your plastic spudger in the opening near the HDMI port.
    • Gently pry the back cover of the R1 from the the front by using the spudger along the edges.
    • Do not pull the back cover straight off the R1 as components of the speakers will be attached to both sides.
  2. Pioneer R1 Touch Screen Replacement: adım 2, 1 resimden 1.
    • Lay the R1 flat like an open book.
    • This will prevent the speakers from becoming disconnected from the motherboard.
  3. Pioneer R1 Touch Screen Replacement: adım 3, 1 resimden 1.
    • Remove the tape that is holding the motherboard to the display and covering the cable attachments.
    • Peel back just the end of this tape to free the front facing camera.
  4. Pioneer R1 Touch Screen Replacement: adım 4, 1 resimden 1.
    • Remove the three 4 mm screws along the base of the motherboard with a Phillips #00 Screwdriver.
  5. Pioneer R1 Touch Screen Replacement: adım 5, 1 resimden 1.
    • Disengage the two cable locks using your spudger or your finger nail.
    • Slide the cable free from the disengaged lock.
    • Do not pull across the cables as this may tear and permanently damage it.
  6. Pioneer R1 Touch Screen Replacement: adım 6, 2 resimden 1. Pioneer R1 Touch Screen Replacement: adım 6, 2 resimden 2.
    • Insert your spudger between the LCD display and the touch screen.
    • Gently pry the LCD display from the the touchscreen by using the spudger along the edges.
  7. Pioneer R1 Touch Screen Replacement: adım 7, 1 resimden 1.
    • Once disengaged, remove the LCD display from the touchscreen.
Sonuç
Christopher Rosario
411 İtibar
4 adet Kılavuz yazıldı
Ekip
San Diego State, Team 1-1, Sheppard Winter 2015 San Diego State, Team 1-1, Sheppard Winter 2015 üyesi
SDSU-SHEPPARD-W15S1G1
3 Üyeler
7 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 22
Her zaman: 2,619
