Ana içeriğe geç
Pioneer Steel Wheels Drivers Replacement
Neye ihtiyacın var
  1. Pioneer Steel Wheels Drivers Replacement, Headband: adım 1, 2 resimden 1. Pioneer Steel Wheels Drivers Replacement, Headband: adım 1, 2 resimden 2.
    • Remove the two screws on the underside of the headband with the PH0 Phillips screw driver.
  2. Pioneer Steel Wheels Drivers Replacement: adım 2, 2 resimden 1. Pioneer Steel Wheels Drivers Replacement: adım 2, 2 resimden 2.
    • With the headband fully extended, hold the base of the headband with one hand and with your other hand, hold the top of the headband.
    • With force, pull upwards.
  3. Pioneer Steel Wheels Drivers Replacement: adım 3, 3 resimden 1. Pioneer Steel Wheels Drivers Replacement: adım 3, 3 resimden 2. Pioneer Steel Wheels Drivers Replacement: adım 3, 3 resimden 3.
    • Remove the rail-piece that is now sticking up by pulling it up and out of the headphone.
    • Repeat on the opposite side and the headband will be released.
    • During reassembly, make the sure the rail-pieces match their respective sides so the headband reinserts properly.
  4. Pioneer Steel Wheels Drivers Replacement, Foam Ear Pads: adım 4, 2 resimden 1. Pioneer Steel Wheels Drivers Replacement, Foam Ear Pads: adım 4, 2 resimden 2.
    • While holding the base of the ear cup with one hand, insert your index finger from your other hand into the inside of the foam ear piece.
  5. Pioneer Steel Wheels Drivers Replacement: adım 5, 3 resimden 1. Pioneer Steel Wheels Drivers Replacement: adım 5, 3 resimden 2. Pioneer Steel Wheels Drivers Replacement: adım 5, 3 resimden 3.
    • With slight force, peel the foam ear pieces away from the ear cup.
    • Make sure to pull out the foam ear pieces slowly. Pulling on them fast will tear the leather wrapping.
    • Repeat for the opposite side if necessary.
  6. Pioneer Steel Wheels Drivers Replacement, Drivers: adım 6, 2 resimden 1. Pioneer Steel Wheels Drivers Replacement, Drivers: adım 6, 2 resimden 2.
    • Remove the three screws located on the driver cover of the ear cup with the PH0 Phillips screw driver.
  7. Pioneer Steel Wheels Drivers Replacement: adım 7, 2 resimden 1. Pioneer Steel Wheels Drivers Replacement: adım 7, 2 resimden 2.
    • Pull the driver cover away from the headphone.
    • Do not pull the driver cover away too fast since there are wires connecting the driver to the ear cup.
    • During reassembly, make sure the two wires are pointing downward before screwing the driver back in.
Sonuç
Garrett Leung
955 İtibar
8 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 10-40, Amido Spring 2013 Cal Poly, Team 10-40, Amido Spring 2013 üyesi
CPSU-AMIDO-S13S10G40
4 Üyeler
37 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 11
Her zaman: 706
