Ana içeriğe geç
Pioneer Steel Wheels Headphone Headband Replacement
Neye ihtiyacın var
  1. Pioneer Steel Wheels Headphone Headband Replacement, Headband: adım 1, 2 resimden 1. Pioneer Steel Wheels Headphone Headband Replacement, Headband: adım 1, 2 resimden 2.
    • Remove the two screws on the underside of the headband with the PH0 Phillips screw driver.
  2. Pioneer Steel Wheels Headphone Headband Replacement: adım 2, 2 resimden 1. Pioneer Steel Wheels Headphone Headband Replacement: adım 2, 2 resimden 2.
    • With the headband fully extended, hold the base of the headband with one hand and with your other hand, hold the top of the headband.
    • With force, pull upwards.
  3. Pioneer Steel Wheels Headphone Headband Replacement: adım 3, 3 resimden 1. Pioneer Steel Wheels Headphone Headband Replacement: adım 3, 3 resimden 2. Pioneer Steel Wheels Headphone Headband Replacement: adım 3, 3 resimden 3.
    • Remove the rail-piece that is now sticking up by pulling it up and out of the headphone.
    • Repeat on the opposite side and the headband will be released.
    • During reassembly, make the sure the rail-pieces match their respective sides so the headband reinserts properly.
Sonuç
Garrett Leung
955 İtibar
8 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 10-40, Amido Spring 2013 Cal Poly, Team 10-40, Amido Spring 2013 üyesi
CPSU-AMIDO-S13S10G40
4 Üyeler
37 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 7
Her zaman: 1,132
