Ana içeriğe geç
Pioneer Steel Wheels Swivels Replacement
Neye ihtiyacın var
  1. Pioneer Steel Wheels Swivels Replacement, Folding Hinges: adım 1, 2 resimden 1. Pioneer Steel Wheels Swivels Replacement, Folding Hinges: adım 1, 2 resimden 2.
    • While holding the base of the headband with one hand, hold the ear cup with the other hand.
    • Pull them apart to reveal the screw.
  2. Pioneer Steel Wheels Swivels Replacement: adım 2, 2 resimden 1. Pioneer Steel Wheels Swivels Replacement: adım 2, 2 resimden 2.
    • While apart, remove the screw from the headphone.
  3. Pioneer Steel Wheels Swivels Replacement: adım 3, 2 resimden 1. Pioneer Steel Wheels Swivels Replacement: adım 3, 2 resimden 2.
    • Loosen the plastic cover piece that protects the chrome folding hinge.
    • Remove the plastic cover piece.
    • During reassembly, make sure the plastic covering piece hooks onto the base of the chrome hinge before screwing it back in.
  4. Pioneer Steel Wheels Swivels Replacement: adım 4, 2 resimden 1. Pioneer Steel Wheels Swivels Replacement: adım 4, 2 resimden 2.
    • Holding the ear cup with one hand, pull up on the base of the headband with the other hand to release the folding hinge.
    • Repeat for the opposite side if necessary.
  5. Pioneer Steel Wheels Swivels Replacement, Drivers: adım 5, 2 resimden 1. Pioneer Steel Wheels Swivels Replacement, Drivers: adım 5, 2 resimden 2.
    • Remove the three screws located on the driver cover of the ear cup with the PH0 Phillips screw driver.
  6. Pioneer Steel Wheels Swivels Replacement: adım 6, 2 resimden 1. Pioneer Steel Wheels Swivels Replacement: adım 6, 2 resimden 2.
    • Pull the driver cover away from the headphone.
    • Do not pull the driver cover away too fast since there are wires connecting the driver to the ear cup.
    • During reassembly, make sure the two wires are pointing downward before screwing the driver back in.
  7. Pioneer Steel Wheels Swivels Replacement, Swivels: adım 7, 2 resimden 1. Pioneer Steel Wheels Swivels Replacement, Swivels: adım 7, 2 resimden 2.
    • Separate the swivel from the ear cup.
  8. Pioneer Steel Wheels Swivels Replacement: adım 8, 3 resimden 1. Pioneer Steel Wheels Swivels Replacement: adım 8, 3 resimden 2. Pioneer Steel Wheels Swivels Replacement: adım 8, 3 resimden 3.
    • Grab the end of the swivel that is closest to "Pioneer" and pull outward.
  9. Pioneer Steel Wheels Swivels Replacement: adım 9, 3 resimden 1. Pioneer Steel Wheels Swivels Replacement: adım 9, 3 resimden 2. Pioneer Steel Wheels Swivels Replacement: adım 9, 3 resimden 3.
    • Switch sides and grab the other end of the swivel and pull outward as well.
    • During reassembly, insert the swivel back at the tilted position so it can be popped in with ease.
Sonuç
Garrett Leung
955 İtibar
8 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 10-40, Amido Spring 2013 Cal Poly, Team 10-40, Amido Spring 2013 üyesi
CPSU-AMIDO-S13S10G40
4 Üyeler
37 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 311
