Giriş
Removing the grip panels allows you to change the battery and allows you to remove the frame, which gives access to more parts of the marker.
Neye ihtiyacın var
Use the 5/64" hex key to remove the screw shown.
Remove the grip panel by gently holding the bottom of the panel and lifting the panel off.
Bir başkası bu kılavuzu tamamladı.
