Ana içeriğe geç
Planet Eclipse Etha Eyes Replacement
Neye ihtiyacın var
    1. Planet Eclipse Etha Eyes Replacement, Regulator: adım 1, 2 resimden 1. Planet Eclipse Etha Eyes Replacement, Regulator: adım 1, 2 resimden 2.
      • Firmly grasp hold of the ring on the bottom of the 90 degree silver fitting on the front of the gun.
      • Pull hard, but slowly, on the macroline where it comes out of silver piece until it comes out.
      • The macroline is the black hose connecting the regulator to the tank connection.
      FixBot'a Sor
      Yorum Ekle
    2. Planet Eclipse Etha Eyes Replacement: adım 2, 2 resimden 1. Planet Eclipse Etha Eyes Replacement: adım 2, 2 resimden 2.
      • Remove the regulator by unscrewing it in a clockwise direction.
      FixBot'a Sor
      Yorum Ekle
    1. Planet Eclipse Etha Eyes Replacement, Battery and Grip Panels: adım 3, 2 resimden 1. Planet Eclipse Etha Eyes Replacement, Battery and Grip Panels: adım 3, 2 resimden 2.
      • Use the 5/64" hex key to remove the screw shown.
      • Remove the grip panel by gently holding the bottom of the panel and lifting the panel off.
      • If you are only replacing the battery, skip the next step.
      • The screws in this guide are interchangeable with those shown in the Eyes replacement guide.
      FixBot'a Sor
      Yorum Ekle
    2. Planet Eclipse Etha Eyes Replacement: adım 4, 1 resimden 1.
      • Flip the marker over and use the 5/64" hex key to remove the screw shown.
      FixBot'a Sor
      Yorum Ekle
    3. Planet Eclipse Etha Eyes Replacement: adım 5, 2 resimden 1. Planet Eclipse Etha Eyes Replacement: adım 5, 2 resimden 2.
      • Carefully remove the 9V battery and connector.
      • Remove the 9V battery from the connector.
      FixBot'a Sor
      Yorum Ekle
    1. Planet Eclipse Etha Eyes Replacement, Frame: adım 6, 2 resimden 1. Planet Eclipse Etha Eyes Replacement, Frame: adım 6, 2 resimden 2.
      • Carefully disconnect the three connectors from the circuit board.
      • Don't worry about remembering which direction the connectors go in, they will not fit in the board in the wrong direction.
      FixBot'a Sor
      Yorum Ekle
    2. Planet Eclipse Etha Eyes Replacement: adım 7, 2 resimden 1. Planet Eclipse Etha Eyes Replacement: adım 7, 2 resimden 2.
      • Use the 1/8" hex key to remove the two dome-headed screws by rotating them counter-clockwise.
      FixBot'a Sor
      Yorum Ekle
    3. Planet Eclipse Etha Eyes Replacement: adım 8, 1 resimden 1.
      • Be very careful during the step to avoid damage to the solenoid or wiring.
      • Gently separate the top and bottom of the marker.
      FixBot'a Sor
      Yorum Ekle
    1. Planet Eclipse Etha Eyes Replacement, Eyes: adım 9, 2 resimden 1. Planet Eclipse Etha Eyes Replacement, Eyes: adım 9, 2 resimden 2.
      • Use the 5/64" hex key to turn the screw counterclockwise.
      • Carefully remove the screw and place it off to the side.
      • Remove the panel and place it off to the side.
      FixBot'a Sor
      Yorum Ekle
    2. Planet Eclipse Etha Eyes Replacement: adım 10, 2 resimden 1. Planet Eclipse Etha Eyes Replacement: adım 10, 2 resimden 2.
      • Carefully flip the marker over.
      • Remove the screw and place it off to the side.
      • Carefully remove the panel and place it off to the side.
      FixBot'a Sor
      Yorum Ekle
    3. Planet Eclipse Etha Eyes Replacement: adım 11, 2 resimden 1. Planet Eclipse Etha Eyes Replacement: adım 11, 2 resimden 2.
      • Grip the marker with one hand and gently pull the eyes out with your other hand.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Hannah Lancaster
132 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 10-42, Amido Fall 2014 Cal Poly, Team 10-42, Amido Fall 2014 üyesi
CPSU-AMIDO-F14S10G42
5 Üyeler
7 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 8
Son 30 gün: 28
Her zaman: 1,572
