Ana içeriğe geç
Planet Eclipse Etha Solenoid Replacement
Neye ihtiyacın var
  1. Planet Eclipse Etha Solenoid Replacement, Regulator: adım 1, 2 resimden 1. Planet Eclipse Etha Solenoid Replacement, Regulator: adım 1, 2 resimden 2.
    • Firmly grasp hold of the ring on the bottom of the 90 degree silver fitting on the front of the gun.
    • Pull hard, but slowly, on the macroline where it comes out of silver piece until it comes out.
    • The macroline is the black hose connecting the regulator to the tank connection.
  2. Planet Eclipse Etha Solenoid Replacement: adım 2, 2 resimden 1. Planet Eclipse Etha Solenoid Replacement: adım 2, 2 resimden 2.
    • Remove the regulator by unscrewing it in a clockwise direction.
  3. Planet Eclipse Etha Solenoid Replacement, Battery and Grip Panels: adım 3, 2 resimden 1. Planet Eclipse Etha Solenoid Replacement, Battery and Grip Panels: adım 3, 2 resimden 2.
    • Use the 5/64" hex key to remove the screw shown.
    • Remove the grip panel by gently holding the bottom of the panel and lifting the panel off.
    • If you are only replacing the battery, skip the next step.
    • The screws in this guide are interchangeable with those shown in the Eyes replacement guide.
  4. Planet Eclipse Etha Solenoid Replacement: adım 4, 1 resimden 1.
    • Flip the marker over and use the 5/64" hex key to remove the screw shown.
  5. Planet Eclipse Etha Solenoid Replacement: adım 5, 2 resimden 1. Planet Eclipse Etha Solenoid Replacement: adım 5, 2 resimden 2.
    • Carefully remove the 9V battery and connector.
    • Remove the 9V battery from the connector.
  6. Planet Eclipse Etha Solenoid Replacement, Frame: adım 6, 2 resimden 1. Planet Eclipse Etha Solenoid Replacement, Frame: adım 6, 2 resimden 2.
    • Carefully disconnect the three connectors from the circuit board.
    • Don't worry about remembering which direction the connectors go in, they will not fit in the board in the wrong direction.
  7. Planet Eclipse Etha Solenoid Replacement: adım 7, 2 resimden 1. Planet Eclipse Etha Solenoid Replacement: adım 7, 2 resimden 2.
    • Use the 1/8" hex key to remove the two dome-headed screws by rotating them counter-clockwise.
  8. Planet Eclipse Etha Solenoid Replacement: adım 8, 1 resimden 1.
    • Be very careful during the step to avoid damage to the solenoid or wiring.
    • Gently separate the top and bottom of the marker.
  9. Planet Eclipse Etha Solenoid Replacement, Solenoid: adım 9, 2 resimden 1. Planet Eclipse Etha Solenoid Replacement, Solenoid: adım 9, 2 resimden 2.
    • Remove the two black hex bolts that connect the solenoid mount to the body.
    • Use the 5/64" Allen Key to rotate each screw counter clockwise.
  10. Planet Eclipse Etha Solenoid Replacement: adım 10, 2 resimden 1. Planet Eclipse Etha Solenoid Replacement: adım 10, 2 resimden 2.
    • Remove the two Phillips head screws that connect the solenoid to its mount.
    • Use a Phillip's head screwdriver and rotate each screw counter clockwise.
    • Do not attempt to dismantle the solenoid. Intentionally dismantling or tampering with the solenoid voids the manufacturer’s warranty.
Sonuç
Austin Eslinger
110 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 10-42, Amido Fall 2014 Cal Poly, Team 10-42, Amido Fall 2014 üyesi
CPSU-AMIDO-F14S10G42
5 Üyeler
7 adet Kılavuz yazıldı
3 Yorum
Watis the price on etha solenoid, where can i get one , l ma staying in SA, myne is leaking ear,email ratgonefishing @gmail. Com
Roelof Koekemoer - Yanıt
Hi my etha solenoid leaks ear,where do l get one,wats the price,i m staying in SA
Hello if it’s leaking try to lubricate your O-rings and switch out the filter, these can be very expensive from $55-$99 they don’t Make this model anymore so it’s very hard to find
Eddie -
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 5
Her zaman: 2,513
