Ana içeriğe geç
Planet Eclipse Geo3 Solenoid Manifold Gasket Replacement
Neye ihtiyacın var
  1. Planet Eclipse Geo3 Solenoid Manifold Gasket Replacement, Grip: adım 1, 2 resimden 1. Planet Eclipse Geo3 Solenoid Manifold Gasket Replacement, Grip: adım 1, 2 resimden 2.
    • Remove the four screws from the grip with the 5/64" allen wrench. There are two on each side.
  2. Planet Eclipse Geo3 Solenoid Manifold Gasket Replacement: adım 2, 2 resimden 1. Planet Eclipse Geo3 Solenoid Manifold Gasket Replacement: adım 2, 2 resimden 2.
    • Pull the grip away from the frame.
  3. Planet Eclipse Geo3 Solenoid Manifold Gasket Replacement: adım 3, 2 resimden 1. Planet Eclipse Geo3 Solenoid Manifold Gasket Replacement: adım 3, 2 resimden 2.
    • Pull the grip through the opening.
    • The grip is connected in the middle and is one piece.
  4. Planet Eclipse Geo3 Solenoid Manifold Gasket Replacement, Macroline: adım 4, 3 resimden 1. Planet Eclipse Geo3 Solenoid Manifold Gasket Replacement, Macroline: adım 4, 3 resimden 2. Planet Eclipse Geo3 Solenoid Manifold Gasket Replacement, Macroline: adım 4, 3 resimden 3.
    • Remove the macroline from the fitting by pulling the metal ring around the end of the fitting away while pulling out the macroline.
    • It helps to rotate the collar to create room to pull out macroline.
  5. Planet Eclipse Geo3 Solenoid Manifold Gasket Replacement: adım 5, 3 resimden 1. Planet Eclipse Geo3 Solenoid Manifold Gasket Replacement: adım 5, 3 resimden 2. Planet Eclipse Geo3 Solenoid Manifold Gasket Replacement: adım 5, 3 resimden 3.
    • While pulling in the metal ring on the fitting, pull the macroline out.
  6. Planet Eclipse Geo3 Solenoid Manifold Gasket Replacement, Body: adım 6, 3 resimden 1. Planet Eclipse Geo3 Solenoid Manifold Gasket Replacement, Body: adım 6, 3 resimden 2. Planet Eclipse Geo3 Solenoid Manifold Gasket Replacement, Body: adım 6, 3 resimden 3.
    • Use 1/8" allen wrench to remove screw behind regulator.
  7. Planet Eclipse Geo3 Solenoid Manifold Gasket Replacement: adım 7, 3 resimden 1. Planet Eclipse Geo3 Solenoid Manifold Gasket Replacement: adım 7, 3 resimden 2. Planet Eclipse Geo3 Solenoid Manifold Gasket Replacement: adım 7, 3 resimden 3.
    • Use 1/8" allen wrench to loosen the screw inside the grip on the right side.
    • The screw only needs to be turned a couple of times.
    • Slide the upper frame forward on the rails and remove the screw from the slot to separate the two halves of the body.
    • BE CAREFUL: Do not pull the two frames apart too much or too quickly. This may cause the wires to be damaged.
  8. Planet Eclipse Geo3 Solenoid Manifold Gasket Replacement, Solenoid: adım 8, 3 resimden 1. Planet Eclipse Geo3 Solenoid Manifold Gasket Replacement, Solenoid: adım 8, 3 resimden 2. Planet Eclipse Geo3 Solenoid Manifold Gasket Replacement, Solenoid: adım 8, 3 resimden 3.
    • Using the Phillips #0 screwdriver, remove the 2 screws in the solenoid.
    • Remove the solenoid.
  9. Planet Eclipse Geo3 Solenoid Manifold Gasket Replacement: adım 9, 1 resimden 1.
    • Pry the board connection with the 2 black wires from the terminal.
    • BE CAREFUL: Do not pull hard by the wires or you may dislodge them from the connection instead of removing the connection from the board.
    • Pull out the wires through the opening in the top of the grip and replace the solenoid.
  10. Planet Eclipse Geo3 Solenoid Manifold Gasket Replacement, Solenoid Gasket: adım 10, 3 resimden 1. Planet Eclipse Geo3 Solenoid Manifold Gasket Replacement, Solenoid Gasket: adım 10, 3 resimden 2. Planet Eclipse Geo3 Solenoid Manifold Gasket Replacement, Solenoid Gasket: adım 10, 3 resimden 3.
    • Locate the solenoid gasket manifold, underneath the top half of the body.
  11. Planet Eclipse Geo3 Solenoid Manifold Gasket Replacement: adım 11, 3 resimden 1. Planet Eclipse Geo3 Solenoid Manifold Gasket Replacement: adım 11, 3 resimden 2. Planet Eclipse Geo3 Solenoid Manifold Gasket Replacement: adım 11, 3 resimden 3.
    • Remove the solenoid gasket manifold by applying pressure with one finger to the part closest to the end of the barrel.
Sonuç
Rett Triplett
801 İtibar
8 adet Kılavuz yazıldı
Ekip
Clemson, Team 13-6, Benson Fall 2013 Clemson, Team 13-6, Benson Fall 2013 üyesi
CLEM-BENSON-F13S13G6
3 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 5
Her zaman: 622
