Ana içeriğe geç
Planet Eclipse LV1 Paintball Marker Eye Replacement
Neye ihtiyacın var
  1. Planet Eclipse LV1 Paintball Marker Eye Replacement, Eye: adım 1, 2 resimden 1. Planet Eclipse LV1 Paintball Marker Eye Replacement, Eye: adım 1, 2 resimden 2.
    • Remove the four grip screws with a 5/64" Allen wrench. There are two screws on each side of the marker.
  2. Planet Eclipse LV1 Paintball Marker Eye Replacement: adım 2, 1 resimden 1.
    • Remove the rubber grip.
  3. Planet Eclipse LV1 Paintball Marker Eye Replacement: adım 3, 2 resimden 1. Planet Eclipse LV1 Paintball Marker Eye Replacement: adım 3, 2 resimden 2.
    • On the non-battery side of the marker, unscrew the eye cover with a 5/64" Allen wrench to remove the eye cover.
  4. Planet Eclipse LV1 Paintball Marker Eye Replacement: adım 4, 2 resimden 1. Planet Eclipse LV1 Paintball Marker Eye Replacement: adım 4, 2 resimden 2.
    • On the battery side of the marker, unscrew the other eye cover with a 5/64" Allen wrench to remove the eye cover.
  5. Planet Eclipse LV1 Paintball Marker Eye Replacement: adım 5, 2 resimden 1. Planet Eclipse LV1 Paintball Marker Eye Replacement: adım 5, 2 resimden 2.
    • Pull the red and black eye sensor wires to disconnect the plug from the control board.
  6. Planet Eclipse LV1 Paintball Marker Eye Replacement: adım 6, 2 resimden 1. Planet Eclipse LV1 Paintball Marker Eye Replacement: adım 6, 2 resimden 2.
    • On the battery side of the marker, pull out the red eye sensor wire from the slot.
    • On the non-battery side of the marker, pull out the black eye sensor wire from the slot.
  7. Planet Eclipse LV1 Paintball Marker Eye Replacement: adım 7, 2 resimden 1. Planet Eclipse LV1 Paintball Marker Eye Replacement: adım 7, 2 resimden 2.
    • On the battery side of the marker, grasp the plug to remove the red and black eye sensor wires.
  8. Planet Eclipse LV1 Paintball Marker Eye Replacement: adım 8, 1 resimden 1.
    • With the new eye, pass the plug in between the solenoid and the grip frame.
  9. Planet Eclipse LV1 Paintball Marker Eye Replacement: adım 9, 2 resimden 1. Planet Eclipse LV1 Paintball Marker Eye Replacement: adım 9, 2 resimden 2.
    • Orient the plug to align with the male receptors of the control board and click into place.
  10. Planet Eclipse LV1 Paintball Marker Eye Replacement: adım 10, 1 resimden 1.
    • Grasp the black eye sensor wire and pull it completely through and out of the grip frame on the battery side.
    • Keep the black eye sensor wire out of the way until step 13.
  11. Planet Eclipse LV1 Paintball Marker Eye Replacement: adım 11, 2 resimden 1. Planet Eclipse LV1 Paintball Marker Eye Replacement: adım 11, 2 resimden 2.
    • Orient the sensor with the flat side facing up.
    • On the battery side of the marker, place the red eye sensor wire into the slot of the marker.
  12. Planet Eclipse LV1 Paintball Marker Eye Replacement: adım 12, 2 resimden 1. Planet Eclipse LV1 Paintball Marker Eye Replacement: adım 12, 2 resimden 2.
    • Set the eye cover into the slot and secure with the eye cover screw using a 5/64" Allen wrench.
    • Ensure the wires are not pinched between the eye cover and the marker.
  13. Planet Eclipse LV1 Paintball Marker Eye Replacement: adım 13, 1 resimden 1.
    • On the battery side of the marker, push the black eye sensor wire through the grip frame and under the solenoid.
  14. Planet Eclipse LV1 Paintball Marker Eye Replacement: adım 14, 1 resimden 1.
    • On the non-battery side of the marker, pull through the black eye sensor wire completely.
  15. Planet Eclipse LV1 Paintball Marker Eye Replacement: adım 15, 1 resimden 1.
    • On the non-battery side of the marker, place the black eye sensor wire into the slot of the marker.
  16. Planet Eclipse LV1 Paintball Marker Eye Replacement: adım 16, 2 resimden 1. Planet Eclipse LV1 Paintball Marker Eye Replacement: adım 16, 2 resimden 2.
  17. Planet Eclipse LV1 Paintball Marker Eye Replacement: adım 17, 1 resimden 1.
    • Reinstall the rubber grip.
  18. Planet Eclipse LV1 Paintball Marker Eye Replacement: adım 18, 2 resimden 1. Planet Eclipse LV1 Paintball Marker Eye Replacement: adım 18, 2 resimden 2.
    • Secure the rubber grip with the four grip screws using a 5/64" Allen wrench. There are two screws on each side.
Sonuç
Thank you for viewing this step-by-step guide on replacing an eye for a Planet Eclipse LV1 Paintball Marker. Now get back out there and have fun!
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 6
Son 30 gün: 13
Her zaman: 62
