Ana içeriğe geç
Plantronics CS50 Headset Battery Replacement
Neye ihtiyacın var
  1. Plantronics CS50 Headset Battery Replacement, Battery: adım 1, 3 resimden 1. Plantronics CS50 Headset Battery Replacement, Battery: adım 1, 3 resimden 2. Plantronics CS50 Headset Battery Replacement, Battery: adım 1, 3 resimden 3.
    • Flip the headset face down.
    • Squeeze both sides of the battery cover.
    • While squeezing, pull the cover up slowly to remove it.
    FixBot'a Sor
    Yorum Ekle
  2. Plantronics CS50 Headset Battery Replacement: adım 2, 3 resimden 1. Plantronics CS50 Headset Battery Replacement: adım 2, 3 resimden 2. Plantronics CS50 Headset Battery Replacement: adım 2, 3 resimden 3.
    • Locate and detatch the white connector that connects the wires of the battery to the wires of the headset.
    FixBot'a Sor
    Yorum Ekle
Sonuç
To reassemble your device, follow these instructions in reverse order
2 farklı kişi bu kılavuzu tamamladı.
Yuliya Levitskaya
77 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 17-29, Amido Spring 2012 Cal Poly, Team 17-29, Amido Spring 2012 üyesi
CPSU-AMIDO-S12S17G29
4 Üyeler
21 adet Kılavuz yazıldı
2Kılavuz Yorumları
I created the article https://de.ifixit.com/Artikel/Battery_Pl... for a Silvercrest bluetooth transmitter, but I was not able to change the needed parts of this howto to link to that article.
anton2 - Yanıt Paylaş
I replaced the battery with a new battery, I cleaned all the connectors and I reset the base and the headset is still not working
Lee kathryn lucas - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 13
Son 30 gün: 42
Her zaman: 8,287
