Ana içeriğe geç
Plantronics CS50 Headset Motherboard of the Base Unit Replacement
Neye ihtiyacın var
  1. Plantronics CS50 Headset Motherboard of the Base Unit Replacement, Motherboard of the Base Unit: adım 1, 2 resimden 1. Plantronics CS50 Headset Motherboard of the Base Unit Replacement, Motherboard of the Base Unit: adım 1, 2 resimden 2.
    • Flip over the base unit to reveal the bottom.
  2. Plantronics CS50 Headset Motherboard of the Base Unit Replacement: adım 2, 2 resimden 1. Plantronics CS50 Headset Motherboard of the Base Unit Replacement: adım 2, 2 resimden 2.
    • Using a #0 screwdriver, remove the two 2.50mm screws.
  3. Plantronics CS50 Headset Motherboard of the Base Unit Replacement: adım 3, 3 resimden 1. Plantronics CS50 Headset Motherboard of the Base Unit Replacement: adım 3, 3 resimden 2. Plantronics CS50 Headset Motherboard of the Base Unit Replacement: adım 3, 3 resimden 3.
    • Separate, but do not remove, the silver upper piece from the dark lower piece.
    • Carefully disconnect the wires from the motherboard.
    • Remove the silver top of the base.
  4. Plantronics CS50 Headset Motherboard of the Base Unit Replacement: adım 4, 3 resimden 1. Plantronics CS50 Headset Motherboard of the Base Unit Replacement: adım 4, 3 resimden 2. Plantronics CS50 Headset Motherboard of the Base Unit Replacement: adım 4, 3 resimden 3.
    • Remove the motherboard from the base
Sonuç
Bir başkası bu kılavuzu tamamladı.
Bryan Clark
51 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 17-29, Amido Spring 2012 Cal Poly, Team 17-29, Amido Spring 2012 üyesi
CPSU-AMIDO-S12S17G29
4 Üyeler
7 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 5
Her zaman: 1,154
