Ana içeriğe geç
Plantronics CS50 Headset System Reset
  1. Plantronics CS50 Headset System Reset, Plantronics CS50 Headset System Reset: adım 1, 2 resimden 1. Plantronics CS50 Headset System Reset, Plantronics CS50 Headset System Reset: adım 1, 2 resimden 2.
    • Press and hold both the call control button and the listening volume/mute button for five seconds.
    • When the talk indicator light blinks, release both buttons.
    FixBot'a Sor
    Yorum Ekle
  2. Plantronics CS50 Headset System Reset: adım 2, 1 resimden 1.
    • Press the call control button again.
    FixBot'a Sor
    Yorum Ekle
  3. Plantronics CS50 Headset System Reset: adım 3, 2 resimden 1. Plantronics CS50 Headset System Reset: adım 3, 2 resimden 2.
    • Unplug the base unit's power source for ten seconds.
    • Plug the power source back in.
    FixBot'a Sor
    Yorum Ekle
Bitiş Çizgisi
3 farklı kişi bu kılavuzu tamamladı.
Joe
117 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 17-29, Amido Spring 2012 Cal Poly, Team 17-29, Amido Spring 2012 üyesi
CPSU-AMIDO-S12S17G29
4 Üyeler
21 adet Kılavuz yazıldı
4Kılavuz Yorumları
Great fix. I was about to spend $200 on a new set. Thanks.
acseko - Yanıt Paylaş
I had a constant buzzing sound from the unit. I did what you recommended and could not stop it. Then I discovered that my handset also had the same buzzing sound so I unplugged the phone line and power cord (to the main phone unit) and it cleared up!
Russ - Yanıt Paylaş
I've got a unit that is getting no sound to or from the earpiece at all, though the lifter still lifts when I hit the answer button. I'll try this reset before I order a replacement set.
kool1zero - Yanıt Paylaş
I have the C053 model and have cleaned headset and base and can not get it to charge. I have noticed over the past few weeks that it will only stayed charged from 800 am to 100 pm. I have disconnected and restarted also. Any other suggestions?
Diane
Diane - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 5
Son 7 gün: 12
Son 30 gün: 43
Her zaman: 23,429
