Ana içeriğe geç
HP Photosmart 935 Plastic Casing Replacement
Neye ihtiyacın var
  1. HP Photosmart 935 Plastic Casing Replacement, Batteries: adım 1, 2 resimden 1. HP Photosmart 935 Plastic Casing Replacement, Batteries: adım 1, 2 resimden 2.
    • Flip the camera over so the bottom of the camera is facing you.
    • Turn the mode dial to the OFF position.
  2. HP Photosmart 935 Plastic Casing Replacement: adım 3, 2 resimden 1. HP Photosmart 935 Plastic Casing Replacement: adım 3, 2 resimden 2.
    • Slide the bottom cover in the direction of the arrow to open it.
  3. HP Photosmart 935 Plastic Casing Replacement: adım 4, 1 resimden 1.
    • Pull out the batteries.
  4. HP Photosmart 935 Plastic Casing Replacement, Plastic Casing: adım 5, 1 resimden 1.
    • Use a Phillips #00 screwdriver to remove the two 4.7 mm screws in the bottom of the plastic casing.
  5. HP Photosmart 935 Plastic Casing Replacement: adım 6, 2 resimden 1. HP Photosmart 935 Plastic Casing Replacement: adım 6, 2 resimden 2.
    • Remove the four 4.7 mm screws on the left side of the camera.
  6. HP Photosmart 935 Plastic Casing Replacement: adım 7, 2 resimden 1. HP Photosmart 935 Plastic Casing Replacement: adım 7, 2 resimden 2.
    • Remove the four 4.7 mm screws on the opposite side of the camera.
  7. HP Photosmart 935 Plastic Casing Replacement: adım 8, 3 resimden 1. HP Photosmart 935 Plastic Casing Replacement: adım 8, 3 resimden 2. HP Photosmart 935 Plastic Casing Replacement: adım 8, 3 resimden 3.
    • Use your thumbs to pry the case apart.
    • It is easiest to pry the case apart if you start at the bottom.
    • The case should come apart with minimal effort. If it doesn't, you can use a spudger or plastic opening tool to pry it open.
  8. HP Photosmart 935 Plastic Casing Replacement: adım 9, 1 resimden 1.
    • This step requires a significant amount of force.
    • Pull the bottom half of the inner camera out of the case by half an inch. This may be difficult.
  9. HP Photosmart 935 Plastic Casing Replacement: adım 10, 2 resimden 1. HP Photosmart 935 Plastic Casing Replacement: adım 10, 2 resimden 2.
    • While pulling the camera out of the case, note the small soft plastic cover on the side. This cover will detach from the rest of the device.
    • Once the bottom of the inner camera is pulled out, pull the device out completely.
    • Use a firm grasp when removing the device from the case for stability and control.
Sonuç
Clay Young
233 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 15-13, Forte Spring 2012 Cal Poly, Team 15-13, Forte Spring 2012 üyesi
CPSU-FORTE-S12S15G13
5 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 14
Her zaman: 1,739
