Ana içeriğe geç
Plastic Tooth Zipper Diagnosis
  1. Plastic Tooth Zipper Diagnosis, Plastic Tooth Zipper Diagnosis: adım 1, 2 resimden 1. Plastic Tooth Zipper Diagnosis, Plastic Tooth Zipper Diagnosis: adım 1, 2 resimden 2.
    • Before we get started, let's identify the basic parts of a plastic tooth zipper:
    • Slider
    • Pull
    • Stop
    • Box
    • Teeth
    • Zipper Tape
  2. Plastic Tooth Zipper Diagnosis: adım 2, 1 resimden 1.
    • The teeth on this zipper are melted.
    • This zipper cannot be repaired and needs to be replaced.
  3. Plastic Tooth Zipper Diagnosis: adım 3, 1 resimden 1.
    • The teeth are missing from the zipper.
    • This zipper cannot be repaired, so the zipper will need to be replaced.
  4. Plastic Tooth Zipper Diagnosis: adım 4, 2 resimden 1. Plastic Tooth Zipper Diagnosis: adım 4, 2 resimden 2.
    • This zipper is missing the zipper box at the bottom of the zipper.
  5. Plastic Tooth Zipper Diagnosis: adım 5, 2 resimden 1. Plastic Tooth Zipper Diagnosis: adım 5, 2 resimden 2.
    • This zipper is missing the zipper stop at the top of the zipper.
    • Provided there is enough of the fabric around the zipper, which has been clipped in this image for visibility, you can simply replace the stop as shown in our slider replacement guide.
Bitiş Çizgisi
7 farklı kişi bu kılavuzu tamamladı.
Brittany McCrigler
89.020 İtibar
131 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
135 Üyeler
17.243 adet Kılavuz yazıldı
5 Yorum
The link in Step 5 for the slider replacement guide is incorrect. It points to a Powerbook HD replacement guide. TG.
tgarrity - Yanıt
What if there's no reason other than one side of the slider came off?
Donna Brock - Yanıt
What about if the zipper zips up but the teeth do not keep closed. I.e. zip up the jacket, part of the teeth stay interlocked but from one point on the teeth become undone and do not lock.
Juan Umana - Yanıt
That's an issue with the zipper slider itself and I have experience fixing it. It's difficult to maneuver the tool because of fabric in the way and it's in a generally awkward spot but possible. Take needle pliers and squeeze down *a little bit* on the back of the zipper slider itself. Doesn't need too much of an adjustment, so squeeze a little and check, and squeeze a little and check. It's the small end of the zipper slider.
Malm -
I have the same problem as Juan Umana: one tooth at the bottom (beginning) of the zipper is broken off, so the teeth won’t mesh properly and the zipper teeth stay apart. Ideas welcome.
Robin Cunningham
Robin Cunningham - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 51
Son 30 gün: 229
Her zaman: 40,585
