Ana içeriğe geç
PlayStation 2 Controller L/R Trigger and Shoulder Buttons Replacement
Neye ihtiyacın var
  1. PlayStation 2 Controller L/R Trigger and Shoulder Buttons Replacement, L/R Trigger and Shoulder Buttons: adım 1, 3 resimden 1. PlayStation 2 Controller L/R Trigger and Shoulder Buttons Replacement, L/R Trigger and Shoulder Buttons: adım 1, 3 resimden 2. PlayStation 2 Controller L/R Trigger and Shoulder Buttons Replacement, L/R Trigger and Shoulder Buttons: adım 1, 3 resimden 3.
    • Place the controller face-down on a solid surface.
    • Remove the six screws from the back cover using a Phillips #00 screwdriver.
    • Gently remove both covers away from each other and place in a safe area.
  2. PlayStation 2 Controller L/R Trigger and Shoulder Buttons Replacement: adım 2, 3 resimden 1. PlayStation 2 Controller L/R Trigger and Shoulder Buttons Replacement: adım 2, 3 resimden 2. PlayStation 2 Controller L/R Trigger and Shoulder Buttons Replacement: adım 2, 3 resimden 3.
    • Grab the back cover of the controller.
    • Gently push the shoulder buttons down and out to remove them from their socket.
  3. PlayStation 2 Controller L/R Trigger and Shoulder Buttons Replacement: adım 3, 3 resimden 1. PlayStation 2 Controller L/R Trigger and Shoulder Buttons Replacement: adım 3, 3 resimden 2. PlayStation 2 Controller L/R Trigger and Shoulder Buttons Replacement: adım 3, 3 resimden 3.
    • Grab your replacement shoulder buttons.
    • Slide them under the socket and push them up into the sockets.
    • Be gentle as excessive force can cause damage to them.
    • You'll hear a small click to secure them in place. Test the buttons so they don't fall out of place accidentally.
  4. PlayStation 2 Controller L/R Trigger and Shoulder Buttons Replacement: adım 4, 2 resimden 1. PlayStation 2 Controller L/R Trigger and Shoulder Buttons Replacement: adım 4, 2 resimden 2.
    • Grab the front cover.
    • Push the L1 and R1 buttons down and away from the cover.
    • This will remove the buttons in place.
    • Often when you go to put the case back together, the rubber pads for the L1/R1 buttons get scrunched out the place. Instead of putting those buttons in before putting the case together. leave them off. Once you have the case back together, you can snap them in from the outside.
  5. PlayStation 2 Controller L/R Trigger and Shoulder Buttons Replacement: adım 5, 1 resimden 1.
    • Connect both covers together and replace the screws using a Phillips #00 screwdriver.
  6. PlayStation 2 Controller L/R Trigger and Shoulder Buttons Replacement: adım 6, 2 resimden 1. PlayStation 2 Controller L/R Trigger and Shoulder Buttons Replacement: adım 6, 2 resimden 2.
    • Take your replacement L1 and L2 buttons.
    • Don't excessively press down the buttons as they can get stuck on the side.
    • Gently press them inside the sockets.
    • Press the buttons repeatedly to make sure they are placed correctly so you don't have any issues with them.
Sonuç
Test your buttons out. If it feels loose or unresponsive you can repeat the process and ensure the buttons are in place.
Miguel Aguirre
133 İtibar
1 Kılavuz yazıldı
Ekip
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 23
Son 30 gün: 109
Her zaman: 1,206
