Giriş
In the need that you need to replace the entire disc drive, here's what you need to do. You may need to do a little eBay perusing first, but when you find that replacement, these steps will show you how to remove your old one.
Neye ihtiyacın var
Videoya Genel Bakış
Use the flat edge of a metal spudger to pry the eight flat screw covers out.
Remove the following eight screws securing the top cover to the bottom case:
Four 55.4 mm Philips screws
Four 18.0 mm Phillips screws
Remove the two 6.4 mm black Phillips screws securing the optical disc drive to the bottom case.
Lift and remove the optical disc drive straight up out of the bottom case.
Underneath where the power supply once was is a transparent piece of plastic. This is the heat shield, and it can now be removed.
58 farklı kişi bu kılavuzu tamamladı.
7Kılavuz Yorumları
It helped out a lot I was able to fix my
What replacement drive would you recommend?
How do you know if the DVD drive is a 3 watt or 5 watt?
Are there any "New" DVD drives we could buy?
To avoid activating the VOID that may come up, heat it carefully to remove and replace it clean
What is the VOID? Is this more than a sticker?
