Ana içeriğe geç
PlayStation 2 Optical Disc Drive Lens Cleaning
Neye ihtiyacın var
  1. PlayStation 2 Optical Disc Drive Lens Cleaning, Top Cover: adım 1, 3 resimden 1. PlayStation 2 Optical Disc Drive Lens Cleaning, Top Cover: adım 1, 3 resimden 2. PlayStation 2 Optical Disc Drive Lens Cleaning, Top Cover: adım 1, 3 resimden 3.
    • Flip the PlayStation 2 over so it lays with the bottom of the device facing upwards.
    • Use the flat edge of a metal spudger to pry the eight flat screw covers out.
    • Remove the following eight screws securing the top cover to the bottom case:
    • Four 55.4 mm Philips screws
    • Four 18.0 mm Phillips screws
    FixBot'a Sor
  2. PlayStation 2 Optical Disc Drive Lens Cleaning: adım 2, 1 resimden 1.
    • Some models have a different number of screws and feet. Remove all the feet and screws in the bottom of the case.
    • The 10 screw model has 6 screws in the bottom-most portion and 4 in the upper tray.
    FixBot'a Sor
  3. PlayStation 2 Optical Disc Drive Lens Cleaning: adım 3, 1 resimden 1.
    • Peel the warranty sticker (located next to the main power switch) straight away from the case.
    • To avoid activating the VOID that may come up, heat it carefully to remove and replace it clean
    FixBot'a Sor
  4. PlayStation 2 Optical Disc Drive Lens Cleaning: adım 4, 2 resimden 1. PlayStation 2 Optical Disc Drive Lens Cleaning: adım 4, 2 resimden 2.
    • Flip the PlayStation 2 back to its original upside position.
    • Lift the top cover off the bottom case.
    • To facilitate the removal, it is recommended to pry open the half closer to the power switch first while rocking the top cover towards the front of the bottom case.
    • Carefully remove the power cord that attaches the top and bottom halves by disconnecting the power cord assembly from the top case.
    FixBot'a Sor
  5. PlayStation 2 Optical Disc Drive Lens Cleaning, PlayStation 2 Optical Disc Drive Lens Cleaning: adım 5, 2 resimden 1. PlayStation 2 Optical Disc Drive Lens Cleaning, PlayStation 2 Optical Disc Drive Lens Cleaning: adım 5, 2 resimden 2.
    • Remove the four 6.4 mm Phillips screws securing the top lid of the optical disc drive.
    • Lift and remove the lid from the optical disc drive.
    FixBot'a Sor
  6. PlayStation 2 Optical Disc Drive Lens Cleaning: adım 6, 1 resimden 1.
    • Carefully wipe the lens in a circular motion with a rubbing alcohol damped Q-Tip.
    • Do not over-dampen the Q-Tip with rubbing alcohol.
    • Allow a few minutes for the rubbing alcohol to evaporate.
    FixBot'a Sor
Sonuç
73 farklı kişi bu kılavuzu tamamladı.
emessers
2.947 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 19-1, Maness Fall 2009 Cal Poly, Team 19-1, Maness Fall 2009 üyesi
CPSU-MANESS-F09S19G1
4 Üyeler
35 adet Kılavuz yazıldı
10Kılavuz Yorumları
I've tried the steps mentioned above to no avail. The problem persist. Anything else i can do besides purchasing another console? Sentimental value.Thank you.
Albie - Yanıt Paylaş
What I'm gonna try and do is take a laser from a PC DVD burner tray and see if I reads things. It's a long shot but you can't break what's already broken ehh. I'll let you know what happens. And if it works I will write the proper tutorial for it:)
Yuri weinberg - Yanıt Paylaş
HOw to use a lens cleaner dvd in Ps2
sajidsahito110 - Yanıt Paylaş
please answer my problem
Hi
I have problem with my ps2 when I put the cd in the screen says that it's reading the cd but after a few minutes it stops and says no data.
What should I do ? how do I fix it ? And any clues on what to do?
Arif Ali - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 13
Son 7 gün: 154
Son 30 gün: 692
Her zaman: 127,822
