Ana içeriğe geç
PlayStation 2 Slimline CMOS Battery Replacement
Neye ihtiyacın var
  1. PlayStation 2 Slimline CMOS Battery Replacement, CMOS Battery: adım 1, 2 resimden 1. PlayStation 2 Slimline CMOS Battery Replacement, CMOS Battery: adım 1, 2 resimden 2.
    • Remove all five screws on the downside of the PS2 Slimline
    • Underneath the "Do not remove" sticker, there will be one last screw
  2. PlayStation 2 Slimline CMOS Battery Replacement, Remove the plate: adım 2, 2 resimden 1. PlayStation 2 Slimline CMOS Battery Replacement, Remove the plate: adım 2, 2 resimden 2.
    • Using a metal spudger, carefully pry open the chassis
    • Although a metal spudger is used in the tutorial, it is recommended to use plastic spudgers with most electronics as metal on metal can short circuts
  3. PlayStation 2 Slimline CMOS Battery Replacement, Remove the Battery: adım 3, 3 resimden 1. PlayStation 2 Slimline CMOS Battery Replacement, Remove the Battery: adım 3, 3 resimden 2. PlayStation 2 Slimline CMOS Battery Replacement, Remove the Battery: adım 3, 3 resimden 3.
    • Locate the battery on the motherboard. The battery will be a CR2032 Button Cell Battery
    • Carefully use a metal spudger to pull the battery out of the metal housing
    • Once the battery is fully removed, remove the connector upwards from the motherboard
    • The connector does not have any clips and can be easily removed and pushed back in with reassembly/disassembly
Sonuç
7 farklı kişi bu kılavuzu tamamladı.
tlroesner
1.891 İtibar
4 adet Kılavuz yazıldı
3Kılavuz Yorumları
why would i need to do this?
Dimitrios Frantzis - Yanıt Paylaş
To prior poster, you will not be able to effectively play certain types of games once the server is shut off by Sony.
Joe W. - Yanıt Paylaş
What do I replace the battery with? Can I re-apply the rubber casing of the original battery onto a new 2032 or what?
Jarad Webb - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 14
Son 7 gün: 94
Son 30 gün: 316
Her zaman: 15,019
