Ana içeriğe geç
PlayStation 2 Slimline IR Sensor Replacement
Neye ihtiyacın var
  1. PlayStation 2 Slimline IR Sensor Replacement, Outer Shell: adım 1, 1 resimden 1.
    • Disconnect all cables from the console and flip the unit over to reveal its base.
  2. PlayStation 2 Slimline IR Sensor Replacement: adım 2, 3 resimden 1. PlayStation 2 Slimline IR Sensor Replacement: adım 2, 3 resimden 2. PlayStation 2 Slimline IR Sensor Replacement: adım 2, 3 resimden 3.
    • Locate the 6 feet on the base of the unit. Pry them off using a spudger to reveal the screws.
    • Note: One of the feet is located under the sticker shown in the photo. Removing this sticker will void any warranty with Sony.
  3. PlayStation 2 Slimline IR Sensor Replacement: adım 3, 3 resimden 1. PlayStation 2 Slimline IR Sensor Replacement: adım 3, 3 resimden 2. PlayStation 2 Slimline IR Sensor Replacement: adım 3, 3 resimden 3.
    • Remove all six 4.0 mm screws from the base of the unit using a #1 Phillips screwdriver.
  4. PlayStation 2 Slimline IR Sensor Replacement: adım 4, 3 resimden 1. PlayStation 2 Slimline IR Sensor Replacement: adım 4, 3 resimden 2. PlayStation 2 Slimline IR Sensor Replacement: adım 4, 3 resimden 3.
    • Starting at the corner at which the power and Ethernet ports are located, pry open the outer shell using a spudger and continue around the entire unit.
    • Note: You may use your hands for additional force to separate the two pieces of the outer shell.
  5. PlayStation 2 Slimline IR Sensor Replacement, IR Sensor: adım 5, 1 resimden 1.
    • Locate the IR sensor at the front, right corner of the unit.
  6. PlayStation 2 Slimline IR Sensor Replacement: adım 6, 1 resimden 1.
    • Gently detach the ribbon cable connecting the IR sensor to the motherboard.
    • Caution: Always remove ribbon cables by the plastic handles located on either end. Gripping a ribbon cable anywhere but the provided handles can damage the cable and render the component useless.
  7. PlayStation 2 Slimline IR Sensor Replacement: adım 7, 1 resimden 1.
    • Gently lift and remove the IR Sensor from its designated slot.
Sonuç
10 farklı kişi bu kılavuzu tamamladı.
Thomas Sullivan
4.258 İtibar
6 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 17
Son 30 gün: 118
Her zaman: 7,845
