Ana içeriğe geç
PlayStation 2 Slimline Motherboard Replacement
Neye ihtiyacın var
  1. PlayStation 2 Slimline Motherboard Replacement, Outer Shell: adım 1, 1 resimden 1.
    • Disconnect all cables from the console and flip the unit over to reveal its base.
  2. PlayStation 2 Slimline Motherboard Replacement: adım 2, 3 resimden 1. PlayStation 2 Slimline Motherboard Replacement: adım 2, 3 resimden 2. PlayStation 2 Slimline Motherboard Replacement: adım 2, 3 resimden 3.
    • Locate the 6 feet on the base of the unit. Pry them off using a spudger to reveal the screws.
    • Note: One of the feet is located under the sticker shown in the photo. Removing this sticker will void any warranty with Sony.
  3. PlayStation 2 Slimline Motherboard Replacement: adım 3, 3 resimden 1. PlayStation 2 Slimline Motherboard Replacement: adım 3, 3 resimden 2. PlayStation 2 Slimline Motherboard Replacement: adım 3, 3 resimden 3.
    • Remove all six 4.0 mm screws from the base of the unit using a #1 Phillips screwdriver.
  4. PlayStation 2 Slimline Motherboard Replacement: adım 4, 3 resimden 1. PlayStation 2 Slimline Motherboard Replacement: adım 4, 3 resimden 2. PlayStation 2 Slimline Motherboard Replacement: adım 4, 3 resimden 3.
    • Starting at the corner at which the power and Ethernet ports are located, pry open the outer shell using a spudger and continue around the entire unit.
    • Note: You may use your hands for additional force to separate the two pieces of the outer shell.
  5. PlayStation 2 Slimline Motherboard Replacement, Fan: adım 5, 2 resimden 1. PlayStation 2 Slimline Motherboard Replacement, Fan: adım 5, 2 resimden 2.
    • Locate the fan at the front, left section of the unit.
  6. PlayStation 2 Slimline Motherboard Replacement: adım 6, 2 resimden 1. PlayStation 2 Slimline Motherboard Replacement: adım 6, 2 resimden 2.
    • Peel off the sticker holding the power cords to the unit.
  7. PlayStation 2 Slimline Motherboard Replacement: adım 7, 2 resimden 1. PlayStation 2 Slimline Motherboard Replacement: adım 7, 2 resimden 2.
    • Lift the connector from the motherboard with a pair of tweezers using a firm, upward force.
  8. PlayStation 2 Slimline Motherboard Replacement: adım 8, 3 resimden 1. PlayStation 2 Slimline Motherboard Replacement: adım 8, 3 resimden 2. PlayStation 2 Slimline Motherboard Replacement: adım 8, 3 resimden 3.
    • Remove all three 1.6 mm screws fastening the fan to the unit using a #1 Phillips screwdriver.
    • Gently lift and remove the fan from its compartment.
  9. PlayStation 2 Slimline Motherboard Replacement, Clock Battery: adım 9, 1 resimden 1.
    • Locate the clock battery at the front, right section of the unit. The battery has a circular shape with red (+) and black (-) wires connecting to the motherboard.
  10. PlayStation 2 Slimline Motherboard Replacement: adım 10, 2 resimden 1. PlayStation 2 Slimline Motherboard Replacement: adım 10, 2 resimden 2.
  11. PlayStation 2 Slimline Motherboard Replacement: adım 11, 2 resimden 1. PlayStation 2 Slimline Motherboard Replacement: adım 11, 2 resimden 2.
    • Gently lift and remove the battery from its compartment using a spudger.
  12. PlayStation 2 Slimline Motherboard Replacement, IR Sensor: adım 12, 1 resimden 1.
    • Locate the IR sensor at the front, right corner of the unit.
  13. PlayStation 2 Slimline Motherboard Replacement: adım 13, 1 resimden 1.
    • Gently detach the ribbon cable connecting the IR sensor to the motherboard.
    • Caution: Always remove ribbon cables by the plastic handles located on either end. Gripping a ribbon cable anywhere but the provided handles can damage the cable and render the component useless.
  14. PlayStation 2 Slimline Motherboard Replacement: adım 14, 1 resimden 1.
    • Gently lift and remove the IR Sensor from its designated slot.
  15. PlayStation 2 Slimline Motherboard Replacement, Optical Drive: adım 15, 2 resimden 1. PlayStation 2 Slimline Motherboard Replacement, Optical Drive: adım 15, 2 resimden 2.
    • Locate the optical drive which occupies most of the space on the right side of the unit. It can be identified by the four screws with wide-diameter heads fastening the optical drive to the motherboard.
  16. PlayStation 2 Slimline Motherboard Replacement: adım 16, 2 resimden 1. PlayStation 2 Slimline Motherboard Replacement: adım 16, 2 resimden 2.
    • Remove the four 4.0 mm screws using a #1 Phillips screwdriver.
  17. PlayStation 2 Slimline Motherboard Replacement: adım 17, 1 resimden 1.
    • Locate the three ribbon cables connecting the optical drive to the motherboard.
  18. PlayStation 2 Slimline Motherboard Replacement: adım 18, 3 resimden 1. PlayStation 2 Slimline Motherboard Replacement: adım 18, 3 resimden 2. PlayStation 2 Slimline Motherboard Replacement: adım 18, 3 resimden 3.
    • Gently detach the ribbon cables from the motherboard using a pair of tweezers.
    • Note: The ribbon cable in the center must be unlocked by lifting up the black tab. Remember to push the tab down upon re-installation to secure the cable.
    • Caution: Always remove ribbon cables by the plastic handles located on each end. Gripping a ribbon cable anywhere but the provided handles can damage the cable and render the component useless.
  19. PlayStation 2 Slimline Motherboard Replacement: adım 19, 3 resimden 1. PlayStation 2 Slimline Motherboard Replacement: adım 19, 3 resimden 2. PlayStation 2 Slimline Motherboard Replacement: adım 19, 3 resimden 3.
    • Remove any tape fastening the cables to the motherboard and gently lift and remove the optical drive.
  20. PlayStation 2 Slimline Motherboard Replacement, Motherboard: adım 20, 1 resimden 1.
    • Remove the 2.4 mm screw located in between the controller ports using a #1 Phillips screwdriver.
  21. PlayStation 2 Slimline Motherboard Replacement: adım 21, 3 resimden 1. PlayStation 2 Slimline Motherboard Replacement: adım 21, 3 resimden 2. PlayStation 2 Slimline Motherboard Replacement: adım 21, 3 resimden 3.
    • Gently lift and remove the motherboard and chassis from the outer shell.
  22. PlayStation 2 Slimline Motherboard Replacement: adım 22, 3 resimden 1. PlayStation 2 Slimline Motherboard Replacement: adım 22, 3 resimden 2. PlayStation 2 Slimline Motherboard Replacement: adım 22, 3 resimden 3.
    • There are a total of five 1.6 mm screws which mount the metal chassis to the motherboard.
    • Remove the screw on top and the four screws on the bottom with a #1 Phillips screwdriver.
  23. PlayStation 2 Slimline Motherboard Replacement: adım 23, 3 resimden 1. PlayStation 2 Slimline Motherboard Replacement: adım 23, 3 resimden 2. PlayStation 2 Slimline Motherboard Replacement: adım 23, 3 resimden 3.
    • Gently separate the two metal plates from the motherboard.
Sonuç
33 farklı kişi bu kılavuzu tamamladı.
Thomas Sullivan
3.927 İtibar
6 adet Kılavuz yazıldı
2 Yorum
نرجو اضافة اللغة العربية
Muammar lmgaroush - Yanıt
Mi placa no tiene corriente, seguro tiene un corto quien me ayuda a solucionar, es la 77001, ya tiene botón y flex nuevo y no me da luz Led
gasper6913 - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 11
Son 7 gün: 55
Son 30 gün: 202
Her zaman: 24,976
