Ana içeriğe geç
PlayStation 2 Slimline SCPH-7500x Fan Replacement
Görüntüleme: 5,9 B
İstatistikleri görüntüle:
Son 24 Saat:
6
Son 7 Gün:
40
Son 30 Gün:
154
Her zaman:
5.947
Yorumlar: 2
2 comments on steps.
Tamamlandı: 6
6 kişi bu kılavuzu "tamamlandı" olarak işaretledi. Sıradaki sen olacak mısın?
Sık Kullanılanlar: 7
7 kişi bu kılavuzu favorilerine ekledi (ve abone oldu). Sıradaki sen olacak mısın?
Gerekli Süre: 15 dakika
Zorluk: Orta
Daha Fazla Görsel Gerekli
Biraz daha fazla görsel sayesinde bu kılavuzdaki prosedürler apaçık olacaktır.
Use this guide to walk through a step-by-step process on how to properly replace a broken fan in the PlayStation 2 Slimline SCPH-7500x . The fan’s purpose is to keep the other components in the PlayStation from overheating. You should hear the fan run intermittently while the PlayStation is on. If you do not hear a fan or the system is overheating try following this guide to replace it.
Neye ihtiyacın var
Aletler
      • Turn off the PlayStation 2 and carefully unplug it from the power source. Also, it is important to eject the CD from the console before flipping the it upside down.
      FixBot'a Sor
      Yorum Ekle
    1. PlayStation 2 Slimline SCPH-7500x Fan Replacement: adım 2, 1 resimden 1.
      • Locate the six feet on the bottom of the PS2.
      • Five of these feet are in plain sight while the last foot is located under the black void sticker on the back of the device.
      • Some versions of the console, such as the PAL Version, may not have this sticker. In this case, the foot or the screw should be in plain sight.
      FixBot'a Sor
      Yorum Ekle
    2. PlayStation 2 Slimline SCPH-7500x Fan Replacement: adım 3, 3 resimden 1. PlayStation 2 Slimline SCPH-7500x Fan Replacement: adım 3, 3 resimden 2. PlayStation 2 Slimline SCPH-7500x Fan Replacement: adım 3, 3 resimden 3.
      • Remove the five visible feet from the bottom of the device using a spudger.
      FixBot'a Sor
      Yorum Ekle
    3. PlayStation 2 Slimline SCPH-7500x Fan Replacement: adım 4, 2 resimden 1. PlayStation 2 Slimline SCPH-7500x Fan Replacement: adım 4, 2 resimden 2.
      • Remove the sticker and then remove the 6th foot.
      FixBot'a Sor
      Yorum Ekle
    4. PlayStation 2 Slimline SCPH-7500x Fan Replacement: adım 5, 3 resimden 1. PlayStation 2 Slimline SCPH-7500x Fan Replacement: adım 5, 3 resimden 2. PlayStation 2 Slimline SCPH-7500x Fan Replacement: adım 5, 3 resimden 3.
      • After all of the feet have been removed, Use a Phillips #1 screwdriver to remove the six 4.0mm screws from the base of the PS2.
      FixBot'a Sor
      Yorum Ekle
    5. PlayStation 2 Slimline SCPH-7500x Fan Replacement: adım 6, 3 resimden 1. PlayStation 2 Slimline SCPH-7500x Fan Replacement: adım 6, 3 resimden 2. PlayStation 2 Slimline SCPH-7500x Fan Replacement: adım 6, 3 resimden 3.
      • Once all of the screws have been removed, pry apart the plastic covers. Start by lifting the side containing the power cable and Ethernet port. Then, lift the opposite side to fully separate the two sides.
      • You may need to apply some gentle force to detach the covers. Be careful not to break the plastic screw pins.
      FixBot'a Sor
      Yorum Ekle
    6. PlayStation 2 Slimline SCPH-7500x Fan Replacement: adım 7, 1 resimden 1.
      • If done correctly, you should have a fully detached plastic backing, revealing the electronic components of the PlayStation 2.
      FixBot'a Sor
      Yorum Ekle
    1. PlayStation 2 Slimline SCPH-7500x Fan Replacement, Fan: adım 8, 3 resimden 1. PlayStation 2 Slimline SCPH-7500x Fan Replacement, Fan: adım 8, 3 resimden 2. PlayStation 2 Slimline SCPH-7500x Fan Replacement, Fan: adım 8, 3 resimden 3.
      Bu adımda kullanılan alet:
      • Locate the fan component of the motherboard of the PS2.
      • With your fingers or tweezers, peel off the sticker that holds down the fan's wiring.
      FixBot'a Sor
      Yorum Ekle
    2. PlayStation 2 Slimline SCPH-7500x Fan Replacement: adım 9, 2 resimden 1. PlayStation 2 Slimline SCPH-7500x Fan Replacement: adım 9, 2 resimden 2.
      • Detach the terminal (white covering) to the red and yellow cords from the motherboard to the fan with the use of tweezers.
      FixBot'a Sor
      Yorum Ekle
    3. PlayStation 2 Slimline SCPH-7500x Fan Replacement: adım 10, 2 resimden 1. PlayStation 2 Slimline SCPH-7500x Fan Replacement: adım 10, 2 resimden 2.
      • Locate and unscrew the three 1.6mm screws located next to the base of the fan.
      • They are located off the curved edge of the fan.
      • Once you have removed the three screws, you are able to remove the fan from the PS2.
      FixBot'a Sor
      Yorum Ekle
Sonuç
6 farklı kişi bu kılavuzu tamamladı.
Yazar
ile
Jared Hirata
1.071 İtibar
7 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 17-4, Regan Spring 2013 Cal Poly, Team 17-4, Regan Spring 2013 üyesi
CPSU-REGAN-S13S17G4
3 Üyeler
84 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 6
Son 7 gün: 40
Son 30 gün: 154
Her zaman: 5,947
