Giriş
This guide will walk you through step-by-step on how to properly remove and install the metal chassis in the PlayStation 2 Slimline.
Neye ihtiyacın var
Adım 1 Removing Playstation 2 Slimline SCPH-7500x Outer Shell
Dikkatli ol: adımlar 1-7 yapım altında olarak işaretlenen bir kılavuzdan alınmıştır.
Turn off the PlayStation 2 and carefully unplug it from the power source. Also, it is important to eject the CD from the console before flipping the it upside down.
Adım 8 IR Sensor
Dikkatli ol: adım 8 yapım altında olarak işaretlenen bir kılavuzdan alınmıştır.
Locate the IR sensor on the motherboard. Then, use tweezers to gently detach the blue/white ribbon that attaches the IR sensor to the motherboard.
Identify the clock battery, then use tweezers to disconnect the connector from the motherboard.
Locate the fan component of the motherboard of the PS2.
With your fingers or tweezers, peel off the sticker that holds down the fan's wiring.
Locate the metal plate that is attached to the back of the motherboard.
2 farklı kişi bu kılavuzu tamamladı.
