Giriş
This guide will walk you through step-by-step on how to properly remove and install the optical drive in the PlayStation 2 Slimline.
Neye ihtiyacın var
Adım 1 Removing Playstation 2 Slimline SCPH-7500x Outer Shell
Dikkatli ol: adımlar 1-7 yapım altında olarak işaretlenen bir kılavuzdan alınmıştır.
Turn off the PlayStation 2 and carefully unplug it from the power source. Also, it is important to eject the CD from the console before flipping the it upside down.
Once all of the screws have been removed, pry apart the plastic covers. Start by lifting the side containing the power cable and Ethernet port. Then, lift the opposite side to fully separate the two sides.
It took force to open it, but i broke a plastic pin where the screws enter
You can use a pick to get the thin edge up without breaking anything.
11 farklı kişi bu kılavuzu tamamladı.
Bir Yorum
I think that if the entire disc drive, assembled with a simple click in connection, would be much easier and faster.
