Ana içeriğe geç
PlayStation 3 AC Inlet Replacement
Neye ihtiyacın var
  1. PlayStation 3 AC Inlet Replacement, Smart Plate: adım 1, 2 resimden 1. PlayStation 3 AC Inlet Replacement, Smart Plate: adım 1, 2 resimden 2.
    • Use the tip of a spudger to remove the black rubber screw cover from the side of the PS3.
    • The screw cover may be underneath a warranty sticker. This sticker will change appearance, and show "VOID" after it has been removed.
  2. PlayStation 3 AC Inlet Replacement: adım 2, 1 resimden 1.
    • Remove the single 8.5 mm T10 Security Torx screw from the smart plate.
  3. PlayStation 3 AC Inlet Replacement: adım 3, 3 resimden 1. PlayStation 3 AC Inlet Replacement: adım 3, 3 resimden 2. PlayStation 3 AC Inlet Replacement: adım 3, 3 resimden 3.
    • Pull the smart plate toward the hard drive bay, then lift it off the body of the PS3.
  4. PlayStation 3 AC Inlet Replacement: adım 4, 1 resimden 1.
    • Be sure to keep track of the small metal bracket loosely held in the top cover, if equipped.
  5. PlayStation 3 AC Inlet Replacement, Top Cover: adım 5, 1 resimden 1.
    • Remove the following seven screws:
    • Six 52 mm Phillips screws
    • One 30 mm Phillips screw
  6. PlayStation 3 AC Inlet Replacement: adım 6, 1 resimden 1.
    • Lift the top cover from its rear edge and rotate it toward the front of the PS3.
    • Remove the top cover.
    • There is a plastic hook located in a hole on the top back right hand side corner. Carefully push the plastic hook a bit from the rear of the machine with a spudger to release the rear right of the casing.
  7. PlayStation 3 AC Inlet Replacement, Blu-ray Disc Drive: adım 7, 1 resimden 1.
    • Disconnect the Blu-ray power cable from the motherboard.
    • Pull the connector straight up and out of its socket.
  8. PlayStation 3 AC Inlet Replacement: adım 8, 1 resimden 1.
    • Lift the Blu-ray drive from the edge nearest the power supply and rotate it away from the chassis enough to access its ribbon cable.
  9. PlayStation 3 AC Inlet Replacement: adım 9, 3 resimden 1. PlayStation 3 AC Inlet Replacement: adım 9, 3 resimden 2. PlayStation 3 AC Inlet Replacement: adım 9, 3 resimden 3.
    • Use your fingernail to flip up the retaining flap on the Blu-ray ribbon cable socket.
    • Be sure you are prying up on the retaining flap, not the socket itself.
    • Pull the ribbon cable out of its socket.
    • Remove the Blu-ray drive from the PS3.
    • If replacing the Blu-ray drive, transfer the power cable to your new drive.
  10. PlayStation 3 AC Inlet Replacement, Motherboard Assembly: adım 10, 1 resimden 1.
    • Pull the control board ribbon cable straight up and out of its socket on the motherboard.
  11. PlayStation 3 AC Inlet Replacement: adım 11, 2 resimden 1. PlayStation 3 AC Inlet Replacement: adım 11, 2 resimden 2.
    • Remove the two 12 mm Phillips screws securing the control board to the lower case.
    • Remove the control board and its attached cable from the PS3.
  12. PlayStation 3 AC Inlet Replacement: adım 12, 1 resimden 1.
    • Remove the following eight screws securing the motherboard assembly to the lower case:
    • Seven 12 mm Phillips screws (ph2)
  13. PlayStation 3 AC Inlet Replacement: adım 13, 1 resimden 1.
    • Remove the control board bracket.
  14. PlayStation 3 AC Inlet Replacement: adım 14, 2 resimden 1. PlayStation 3 AC Inlet Replacement: adım 14, 2 resimden 2.
    • Use the flat end of a spudger to pry the hard drive bay cover away from the lower case.
    • Remove the hard drive bay cover.
  15. PlayStation 3 AC Inlet Replacement: adım 15, 1 resimden 1.
    • Lift the motherboard assembly out of the lower case.
  16. PlayStation 3 AC Inlet Replacement, AC Inlet: adım 16, 1 resimden 1.
    • Remove the 7.7 mm Phillips screw securing the ground strap to the chassis.
  17. PlayStation 3 AC Inlet Replacement: adım 17, 2 resimden 1. PlayStation 3 AC Inlet Replacement: adım 17, 2 resimden 2.
    • Pull the AC-In cables slightly away from the rear cover for clearance to access the AC-In connector.
    • While depressing its locking mechanism, pull the AC-In connector out of its socket on the power supply.
  18. PlayStation 3 AC Inlet Replacement: adım 18, 1 resimden 1.
    • Pull the AC inlet out from the bottom of the rear cover, minding any of its cables that may get caught.
Sonuç
24 farklı kişi bu kılavuzu tamamladı.
1Rehber Yorum
Chupa chups ahhhhh guide
Harold - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 38
Son 30 gün: 153
Her zaman: 37,311
