Ana içeriğe geç
  1. Bu adım çevrilmemiş. Çevrilmesine yardım edin
    Use the tip of a spudger to remove the black rubber screw cover from the side of the PS3. The screw cover may be underneath a warranty sticker. This sticker will change appearance, and show "VOID" after it has been removed.
    • Use the tip of a spudger to remove the black rubber screw cover from the side of the PS3.
    • The screw cover may be underneath a warranty sticker. This sticker will change appearance, and show "VOID" after it has been removed.
  2. Bu adım çevrilmemiş. Çevrilmesine yardım edin
    Remove the single 8.5 mm T10 Security Torx screw from the smart plate.
    • Remove the single 8.5 mm T10 Security Torx screw from the smart plate.
  3. Bu adım çevrilmemiş. Çevrilmesine yardım edin
    Pull the smart plate toward the hard drive bay, then lift it off the body of the PS3. Pull the smart plate toward the hard drive bay, then lift it off the body of the PS3. Pull the smart plate toward the hard drive bay, then lift it off the body of the PS3.
    • Pull the smart plate toward the hard drive bay, then lift it off the body of the PS3.
  4. Bu adım çevrilmemiş. Çevrilmesine yardım edin
    Be sure to keep track of the small metal bracket loosely held in the top cover, if equipped.
    • Be sure to keep track of the small metal bracket loosely held in the top cover, if equipped.
  5. Bu adım çevrilmemiş. Çevrilmesine yardım edin
    Remove the following seven screws:
    • Remove the following seven screws:
    • Six 52 mm Phillips screws
    • One 30 mm Phillips screw
  6. Bu adım çevrilmemiş. Çevrilmesine yardım edin
    Lift the top cover from its rear edge and rotate it toward the front of the PS3.
    • Lift the top cover from its rear edge and rotate it toward the front of the PS3.
    • Remove the top cover.
    • There is a plastic hook located in a hole on the top back right hand side corner. Carefully push the plastic hook a bit front the rear of the machine with a spudger to release the rear right of the casing.
  7. Bu adım çevrilmemiş. Çevrilmesine yardım edin
    Disconnect the Blu-ray power cable from the motherboard.
    • Disconnect the Blu-ray power cable from the motherboard.
    • Pull the connector straight up and out of its socket.
  8. Bu adım çevrilmemiş. Çevrilmesine yardım edin
    Lift the Blu-ray drive from the edge nearest the power supply and rotate it away from the chassis enough to access its ribbon cable.
    • Lift the Blu-ray drive from the edge nearest the power supply and rotate it away from the chassis enough to access its ribbon cable.
  9. Bu adım çevrilmemiş. Çevrilmesine yardım edin
    Use your fingernail to flip up the retaining flap on the Blu-ray ribbon cable socket. Be sure you are prying up on the retaining flap, not the socket itself. Pull the ribbon cable out of its socket.
    • Use your fingernail to flip up the retaining flap on the Blu-ray ribbon cable socket.
    • Be sure you are prying up on the retaining flap, not the socket itself.
    • Pull the ribbon cable out of its socket.
    • Remove the Blu-ray drive from the PS3.
    • If replacing the Blu-ray drive, transfer the power cable to your new drive.
  10. Bu adım çevrilmemiş. Çevrilmesine yardım edin
    Pull the control board ribbon cable straight up and out of its socket on the motherboard.
    • Pull the control board ribbon cable straight up and out of its socket on the motherboard.
  11. Bu adım çevrilmemiş. Çevrilmesine yardım edin
    Remove the two 12 mm Phillips screws securing the control board to the lower case. Remove the control board and its attached cable from the PS3.
    • Remove the two 12 mm Phillips screws securing the control board to the lower case.
    • Remove the control board and its attached cable from the PS3.
  12. Bu adım çevrilmemiş. Çevrilmesine yardım edin
    Remove the following eight screws securing the motherboard assembly to the lower case:
    • Remove the following eight screws securing the motherboard assembly to the lower case:
    • Seven 12 mm Phillips screws (ph2)
  13. Bu adım çevrilmemiş. Çevrilmesine yardım edin
    Remove the control board bracket.
    • Remove the control board bracket.
  14. Bu adım çevrilmemiş. Çevrilmesine yardım edin
    Use the flat end of a spudger to pry the hard drive bay cover away from the lower case. Remove the hard drive bay cover.
    • Use the flat end of a spudger to pry the hard drive bay cover away from the lower case.
    • Remove the hard drive bay cover.
  15. Bu adım çevrilmemiş. Çevrilmesine yardım edin
    Lift the motherboard assembly out of the lower case.
    • Lift the motherboard assembly out of the lower case.
  16. Bu adım çevrilmemiş. Çevrilmesine yardım edin
    Remove the 7.7 mm Phillips screw securing the ground strap to the chassis.
    • Remove the 7.7 mm Phillips screw securing the ground strap to the chassis.
  17. Bu adım çevrilmemiş. Çevrilmesine yardım edin
    Pull the AC-In cables slightly away from the rear cover for clearance to access the AC-In connector. While depressing its locking mechanism, pull the AC-In connector out of its socket on the power supply.
    • Pull the AC-In cables slightly away from the rear cover for clearance to access the AC-In connector.
    • While depressing its locking mechanism, pull the AC-In connector out of its socket on the power supply.
  18. Bu adım çevrilmemiş. Çevrilmesine yardım edin
    Pull the AC inlet out from the bottom of the rear cover, minding any of its cables that may get caught.
    • Pull the AC inlet out from the bottom of the rear cover, minding any of its cables that may get caught.
  19. Bu adım çevrilmemiş. Çevrilmesine yardım edin
    While lightly pulling the rear cover away from the logic board assembly, use the flat end of a spudger to release the clips along the top and bottom edges of the rear cover. While lightly pulling the rear cover away from the logic board assembly, use the flat end of a spudger to release the clips along the top and bottom edges of the rear cover.
    • While lightly pulling the rear cover away from the logic board assembly, use the flat end of a spudger to release the clips along the top and bottom edges of the rear cover.
  20. Bu adım çevrilmemiş. Çevrilmesine yardım edin
    Remove the rear cover from the logic board assembly.
    • Remove the rear cover from the logic board assembly.
  21. Bu adım çevrilmemiş. Çevrilmesine yardım edin
    De-route the fan cables from the plastic finger molded into the heat sink. Disconnect the fan from the motherboard.
    • De-route the fan cables from the plastic finger molded into the heat sink.
    • Disconnect the fan from the motherboard.
  22. Bu adım çevrilmemiş. Çevrilmesine yardım edin
    Remove the two 9 mm Phillips screws securing the memory card reader to the chassis.
    • Remove the two 9 mm Phillips screws securing the memory card reader to the chassis.
  23. Bu adım çevrilmemiş. Çevrilmesine yardım edin
    Lift the memory card reader out of the PS3 enough to access its ribbon cable. Flip up the retaining flap on the memory card reader ribbon cable socket.
    • Lift the memory card reader out of the PS3 enough to access its ribbon cable.
    • Flip up the retaining flap on the memory card reader ribbon cable socket.
    • Pull the ribbon cable out of its socket and remove the memory card reader.
  24. Bu adım çevrilmemiş. Çevrilmesine yardım edin
    Disconnect the DC-In cables from the front of the heat sink.
    • Disconnect the DC-In cables from the front of the heat sink.
    • Pull the connector toward the front of the PS3.
  25. Bu adım çevrilmemiş. Çevrilmesine yardım edin
    Remove the five 9 mm Phillips screws securing the power supply to the chassis.
    • Remove the five 9 mm Phillips screws securing the power supply to the chassis.
  26. Bu adım çevrilmemiş. Çevrilmesine yardım edin
    Lift the power supply by its front edge to clear the two posts attached to the motherboard.
    • Lift the power supply by its front edge to clear the two posts attached to the motherboard.
    • Remove the power supply.
  27. Bu adım çevrilmemiş. Çevrilmesine yardım edin
    Remove the four 16.5 mm shouldered Phillips screws securing the heat sink to the motherboard.
    • Remove the four 16.5 mm shouldered Phillips screws securing the heat sink to the motherboard.
    • Remove the two brackets held under the screws you just removed.
  28. Bu adım çevrilmemiş. Çevrilmesine yardım edin
    Lift the motherboard assembly off the heat sink.
    • Lift the motherboard assembly off the heat sink.
    • The heat sink may still be held in place by the thermal paste. If this is the case, gently pry the heat sink away from the motherboard housing. Make sure to not bend the copper piping on the heat sink.
    • Be sure to apply a new layer of thermal paste when reattaching the heat sink.
    • Never applied thermal paste before? Our thermal paste guide makes it easy.
    • If you're following the YLOD repair guide, stay tuned for where to apply the replacement thermal paste.
  29. Bu adım çevrilmemiş. Çevrilmesine yardım edin
    Flip up the retaining flap on the Blu-ray ribbon cable socket. Be sure you are prying up on the retaining flap, not the socket itself.
    • Flip up the retaining flap on the Blu-ray ribbon cable socket.
    • Remove the Blu-ray ribbon cable.
  30. Bu adım çevrilmemiş. Çevrilmesine yardım edin
    Flip up the flap on the memory card reader ribbon cable socket and remove the ribbon cable. Flip up the flap on the memory card reader ribbon cable socket and remove the ribbon cable.
    • Flip up the flap on the memory card reader ribbon cable socket and remove the ribbon cable.
  31. Bu adım çevrilmemiş. Çevrilmesine yardım edin
    Flip up the retaining flap on the Wi-Fi/Bluetooth ribbon cable socket. Pull the Wi-Fi/Bluetooth ribbon cable out of its socket.
    • Flip up the retaining flap on the Wi-Fi/Bluetooth ribbon cable socket.
    • Pull the Wi-Fi/Bluetooth ribbon cable out of its socket.
  32. Bu adım çevrilmemiş. Çevrilmesine yardım edin
    Disconnect the DC-In cable from the motherboard and set it aside.
    • Disconnect the DC-In cable from the motherboard and set it aside.
    • Pull the connector straight up and out of its socket on the motherboard.
  33. Bu adım çevrilmemiş. Çevrilmesine yardım edin
    Disconnect the PRAM battery from the motherboard.
    • Disconnect the PRAM battery from the motherboard.
    • The PRAM socket is delicate and has the potential to break off the motherboard. If possible, hold down the socket as you disconnect the PRAM battery cable.
  34. Bu adım çevrilmemiş. Çevrilmesine yardım edin
    Rotate the PRAM battery slightly counter-clockwise and remove it from the motherboard assembly. Rotate the PRAM battery slightly counter-clockwise and remove it from the motherboard assembly. Rotate the PRAM battery slightly counter-clockwise and remove it from the motherboard assembly.
    • Rotate the PRAM battery slightly counter-clockwise and remove it from the motherboard assembly.
  35. Bu adım çevrilmemiş. Çevrilmesine yardım edin
    Remove the blue 8 mm Phillips screw securing the hard drive cage to the chassis.
    • Remove the blue 8 mm Phillips screw securing the hard drive cage to the chassis.
  36. Bu adım çevrilmemiş. Çevrilmesine yardım edin
    Push the hard drive cage toward the front of the motherboard assembly. Remove the hard drive from the motherboard assembly. Remove the hard drive from the motherboard assembly.
    • Push the hard drive cage toward the front of the motherboard assembly.
    • Remove the hard drive from the motherboard assembly.
  37. Bu adım çevrilmemiş. Çevrilmesine yardım edin
    Remove the two 3.7 mm #0 Phillips screws securing the chassis to the hard drive socket.
    • Remove the two 3.7 mm #0 Phillips screws securing the chassis to the hard drive socket.
  38. Bu adım çevrilmemiş. Çevrilmesine yardım edin
    Remove the two 8.3 mm #0 Phillips screws securing the two halves of the motherboard together.
    • Remove the two 8.3 mm #0 Phillips screws securing the two halves of the motherboard together.
  39. Bu adım çevrilmemiş. Çevrilmesine yardım edin
    Carefully feed the Wi-Fi/Bluetooth ribbon cable through the hole in the top motherboard cover.
    • Carefully feed the Wi-Fi/Bluetooth ribbon cable through the hole in the top motherboard cover.
    • Remove the top motherboard cover.
  40. Bu adım çevrilmemiş. Çevrilmesine yardım edin
    Remove the motherboard from the bottom motherboard cover.
    • Remove the motherboard from the bottom motherboard cover.
  41. Bu adım çevrilmemiş. Çevrilmesine yardım edin
    Flip up the retaining flap on the Wi-Fi/Bluetooth ribbon cable socket. Remove the Wi-Fi/Bluetooth ribbon cable from the motherboard.
    • Remove the Wi-Fi/Bluetooth ribbon cable from the motherboard.
    • Motherboard remains.
Bitiş Çizgisi
68 farklı kişi bu kılavuzu tamamladı.
2 Yorum
Just fixed my YLOD last nite and it works like a charm! best guide on the internet, and it was free! i bought the kit here and it has everything you need minus the gunk off. One thing I'd like to see is how to organize all the screws... I had 2 left over after reassembling the unit. it'll also be nice if the guide showed you how to put certain parts back on (back case, top case units).
It took me a total of 3 hours to do. Not bad considering I don't tear things apart for a living.
other than that, the guide and kit are awesome!
Mike Cha - Yanıt
Just fixed my PS3 Fat. It's the only one that plays PS2 games so it was hard to part with. Instructions were easy to follow. However, I didn't replace the pads on the chips. PS3 is working beautifully again and the fan is much quieter now. I kept forgetting screws and the WIFI cable so I had to take it apart at least a few more times. Now I can take apart and reassemble the PS3 in my sleep.
Charles - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 25
Son 7 gün: 132
Son 30 gün: 503
Her zaman: 156,000
