Giriş
If you want to replace the fan or clean the fan system - video tutorial:
Please SUBSCRIBE to my channel ツ
Videoya Genel Bakış
  1. Disconnect the fan cable and remove the nine screws from the bottom side. Disconnect the fan cable and remove the nine screws from the bottom side. Disconnect the fan cable and remove the nine screws from the bottom side.
    • Disconnect the fan cable and remove the nine screws from the bottom side.
  2. Remove the two heat sink clamps and bottom shield, then gently separate  the motherboard off the top shield. Remove the two heat sink clamps and bottom shield, then gently separate  the motherboard off the top shield. Remove the two heat sink clamps and bottom shield, then gently separate  the motherboard off the top shield.
    • Remove the two heat sink clamps and bottom shield, then gently separate the motherboard off the top shield.
  3. Pro Tech Toolkit içeren veya $100,00tüm siparişlerde ücretsiz kargo!
    Mağazamıza Göz Atın
  4. Remove the four Phillips screws and lift the top shield. Remove the four Phillips screws and lift the top shield. Remove the four Phillips screws and lift the top shield.
    • Remove the four Phillips screws and lift the top shield.
Sonuç
6 başka kişi bu kılavuzu tamamladı.
ZFix
162.473 İtibar
304 adet Kılavuz yazıldı
Takım
Master Techs Master Techs üyesi
Community
280 Üyeler
783 adet Kılavuz yazıldı
2 Yorum
Awesome guide. Thank you so much. I did it, but now I just wonder what that white stuff was when I removed the motherboard. I think it's that thermal stuff people have been talking about and I suppose I have to replace that. I also hope that it's the fan that is what's causing my PS3 to say that it's overheating and shut off. I'm so glad you guys posted this. Great job. I rather do it myself than pay Sony an arm and a leg. Cheers!
chetacheez - Yanıt
This is CPU / GPU thermal paste / compound. I recommend you Arctic MX-2, MX-4. It is very good and not expensive.
ZFix -
İstatistikleri Görüntüle:
Son 24 Saat: 8
Son 7 Gün: 19
Son 30 Gün: 79
Her zaman: 7,942
