Giriş
PlayStation 3 - How to replace Laser Lens and Mechanism (Laser Deck).
Please SUBSCRIBE to my channel ツ
More info about disassembling, you can find in
PlayStation 3 Slim Teardown
Videoya Genel Bakış
  1. Disconnect all cables. You have 4x Torx T8 screws and 7x Phillips screws. Now you can remove outer case. Disconnect all cables. You have 4x Torx T8 screws and 7x Phillips screws. Now you can remove outer case. Disconnect all cables. You have 4x Torx T8 screws and 7x Phillips screws. Now you can remove outer case.
    • Disconnect all cables. You have 4x Torx T8 screws and 7x Phillips screws. Now you can remove outer case.
  2. Remove Power Supply. Remove Power Supply. Remove Power Supply.
    • Remove Power Supply.
  3. Separate cables, unscrew the screw and remove the Blu Ray drive. Separate cables, unscrew the screw and remove the Blu Ray drive. Separate cables, unscrew the screw and remove the Blu Ray drive.
    • Separate cables, unscrew the screw and remove the Blu Ray drive.
  4. Pro Tech Toolkit içeren veya $100tüm siparişlerde ücretsiz kargo!
    Mağazamıza Göz Atın
  5. Disassemble the upper metal shield. . Please SUBSCRIBE to my channel  ツ
  6. Remove the two very small phillips screws in each lower corner referenced by the red circles. Remove the two very small phillips screws in each lower corner referenced by the red circles. Remove the two very small phillips screws in each lower corner referenced by the red circles.
    • Remove the two very small phillips screws in each lower corner referenced by the red circles.
  7. Be careful with flex cables. Be careful with flex cables. Be careful with flex cables.
    • Be careful with flex cables.
  8. Now you can remove the Laser Deck. Now you can remove the Laser Deck. Now you can remove the Laser Deck.
    • Now you can remove the Laser Deck.
  9. Transfer two flex cables and 2x rubbers. Transfer two flex cables and 2x rubbers. Transfer two flex cables and 2x rubbers.
    • Transfer two flex cables and 2x rubbers.
  10. You can test the console before full assembling. . Did you do it successfully?
Sonuç
12 farklı kişi bu kılavuzu tamamladı.
ZFix
163.044 İtibar
304 adet Kılavuz yazıldı
Takım
Master Techs Master Techs üyesi
Community
281 Üyeler
792 adet Kılavuz yazıldı
0 Yorum
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 Gün: 23
Son 30 Gün: 114
Her zaman: 16,228
