Ana içeriğe geç
PlayStation 3 Slim Laser Unit (Laser and Mechanism) Replacement
Neye ihtiyacın var
Videoya Genel Bakış
  1. PlayStation 3 Slim  Laser Unit (Laser and Mechanism) Replacement, Laser Unit (Laser and Mechanism): adım 1, 3 resimden 1. PlayStation 3 Slim  Laser Unit (Laser and Mechanism) Replacement, Laser Unit (Laser and Mechanism): adım 1, 3 resimden 2. PlayStation 3 Slim  Laser Unit (Laser and Mechanism) Replacement, Laser Unit (Laser and Mechanism): adım 1, 3 resimden 3.
    • Disconnect all cables. You have 4x Torx T8 screws and 7x Phillips screws. Now you can remove outer case.
  2. PlayStation 3 Slim  Laser Unit (Laser and Mechanism) Replacement: adım 2, 3 resimden 1. PlayStation 3 Slim  Laser Unit (Laser and Mechanism) Replacement: adım 2, 3 resimden 2. PlayStation 3 Slim  Laser Unit (Laser and Mechanism) Replacement: adım 2, 3 resimden 3.
    • To remove the power supply, first disconnect the two cables, then the 2 Phillips screws. Then lift it upwards.
  3. PlayStation 3 Slim  Laser Unit (Laser and Mechanism) Replacement: adım 3, 3 resimden 1. PlayStation 3 Slim  Laser Unit (Laser and Mechanism) Replacement: adım 3, 3 resimden 2. PlayStation 3 Slim  Laser Unit (Laser and Mechanism) Replacement: adım 3, 3 resimden 3.
    • Separate cables, unscrew the screw and remove the Blu Ray drive.
    • Depending on the model of your PS3 Slim, the number of cables to be removed may vary between 2 and 4. If your model has more than one ribbon cable, remove the drive very carefully, as a fourth ribbon cable may be hidden underneath.
  4. PlayStation 3 Slim  Laser Unit (Laser and Mechanism) Replacement: adım 4, 3 resimden 1. PlayStation 3 Slim  Laser Unit (Laser and Mechanism) Replacement: adım 4, 3 resimden 2. PlayStation 3 Slim  Laser Unit (Laser and Mechanism) Replacement: adım 4, 3 resimden 3.
    • Disassemble the upper metal shield by first unscrewing the 3 Phillips screws.
    • On the 2-cables model, you'll need to unscrew an additional 2 small Phillips screws, located on the underside of the drive. While you're at it, unscrew the 2 other Phillips screws at the bottom of the shield. (Their presence does not prevent removal of the upper metal shield, but removing them will be useful later).
  5. PlayStation 3 Slim  Laser Unit (Laser and Mechanism) Replacement: adım 5, 3 resimden 1. PlayStation 3 Slim  Laser Unit (Laser and Mechanism) Replacement: adım 5, 3 resimden 2. PlayStation 3 Slim  Laser Unit (Laser and Mechanism) Replacement: adım 5, 3 resimden 3.
    • For the 2-cables model, remove the two very small phillips screws in each lower corner referenced by the red circles.
    • For the 4-cables model, remove the small Phillips screw in the bottom left corner referenced by the red circle.
  6. PlayStation 3 Slim  Laser Unit (Laser and Mechanism) Replacement: adım 6, 3 resimden 1. PlayStation 3 Slim  Laser Unit (Laser and Mechanism) Replacement: adım 6, 3 resimden 2. PlayStation 3 Slim  Laser Unit (Laser and Mechanism) Replacement: adım 6, 3 resimden 3.
    • Carefully remove the plastic shell, paying attention to the cable that runs through it for the 4-cables model.
  7. PlayStation 3 Slim  Laser Unit (Laser and Mechanism) Replacement: adım 7, 3 resimden 1. PlayStation 3 Slim  Laser Unit (Laser and Mechanism) Replacement: adım 7, 3 resimden 2. PlayStation 3 Slim  Laser Unit (Laser and Mechanism) Replacement: adım 7, 3 resimden 3.
    • Remove the 4 Phillips screws at each corner of the laser mechanism.
    • Then remove the mechanism.
  8. PlayStation 3 Slim  Laser Unit (Laser and Mechanism) Replacement: adım 8, 3 resimden 1. PlayStation 3 Slim  Laser Unit (Laser and Mechanism) Replacement: adım 8, 3 resimden 2. PlayStation 3 Slim  Laser Unit (Laser and Mechanism) Replacement: adım 8, 3 resimden 3.
    • If necessary, transfer parts and screws from the old mechanism to the new one.
  9. PlayStation 3 Slim  Laser Unit (Laser and Mechanism) Replacement: adım 9, 3 resimden 1. PlayStation 3 Slim  Laser Unit (Laser and Mechanism) Replacement: adım 9, 3 resimden 2. PlayStation 3 Slim  Laser Unit (Laser and Mechanism) Replacement: adım 9, 3 resimden 3.
    • You can test the console before full assembling.
    • To do this, reassemble the blu-ray drive, reconnect its cables, and reconnect the power supply.
Sonuç
18 farklı kişi bu kılavuzu tamamladı.
ZFix
195.826 İtibar
330 adet Kılavuz yazıldı
Ekip
Master Techs Master Techs üyesi
Community
329 Üyeler
1.453 adet Kılavuz yazıldı
1Rehber Yorum
Do you know what the part number is for the deck? I don’t want to buy the wrong one. Thanks.
Edmond Charrette - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 9
Son 7 gün: 68
Son 30 gün: 291
Her zaman: 35,432
