Giriş
Use this guide to replace your PlayStation 3 Slim's Bluetooth and Wi-Fi antennas.
Parçalar
Turn the PS3 over and lay it on its backside.
Carefully peel the warranty sticker up off the lower case to reveal a hidden screw cover.
Squeeze the AC inlet connector's locking mechanism and pull straight up to disconnect it from the power supply.
If present, remove the pieces of tape securing the antenna cables to the fan shroud, Blu-ray drive, and top shield.
18 farklı kişi bu kılavuzu tamamladı.
6 Yorum
Do you guys have parts for PlayStation 3 Slim Antennas I want to now I can buy some from you guys
Hi! i'm facing this 8002f1f9 error code and my ps3 is slim can you please help me out or suggest some troubleshootings.
Network adapter or joystick connection problem
Hyperion -
Which color is the wifi and which is the bluetooth? I haven’t tested the wifi on the system yet, but the controllers are not connecting so I think I have to replace just the bluetooth part.
A year or so ago I noticed my controller wasn't working unless plugged in. I thought it might just be failed battery over the years, but it worked when plugged in, so it was only a minor inconvenience. Later, I realized WiFi wasn't working either, so I thought maybe an update would fix things… plugged into wired network to update system.
DO NOT UPDATE YOUR SYSTEM IF EXPERIENCING WIFI OR BLUETOOTH CONNECTIVITY ISSUES!
Now stuck in a boot loop where the update tries and fails to install. I can't get back into my system to backup and transfer my data, so I'm stuck looking for a solution to either fix my system or transfer to a replacement, but even for an estimated repair cost of $120, Sony support said their first attempted fix action will be to factory reset the system.
Anybody have any advice?
Sony, why would you allow a firmware update to begin install without first running a basic hardware check? Then, why wouldn't you allow some recovery option for a failed update?
Guess I've learned to always backup my stuff.
