Ana içeriğe geç
PlayStation 3 Slim Laser lens Replacement
Neye ihtiyacın var
Videoya Genel Bakış
  1. PlayStation 3 Slim Laser lens Replacement, Blu-ray Disc Drive: adım 1, 2 resimden 1. PlayStation 3 Slim Laser lens Replacement, Blu-ray Disc Drive: adım 1, 2 resimden 2.
    • If present, remove the pieces of tape securing the cables to the body of the Blu-ray drive.
  2. PlayStation 3 Slim Laser lens Replacement: adım 2, 1 resimden 1.
    • Use the flat end of a spudger or your fingernail to flip up the retaining flap on the Blu-ray ribbon cable socket.
    • Be sure you are prying up on the movable retaining flap, not the socket itself.
  3. PlayStation 3 Slim Laser lens Replacement: adım 3, 1 resimden 1.
    • Pull the Blu-ray ribbon cable straight up and out of its socket.
  4. PlayStation 3 Slim Laser lens Replacement: adım 4, 1 resimden 1.
    • Pull the Blu-ray power cable straight up to lift its connector out of the socket on the Blu-ray drive.
  5. PlayStation 3 Slim Laser lens Replacement: adım 5, 1 resimden 1.
    • Remove the single 9.5 mm Phillips screw securing the Blu-ray drive to the lower case.
  6. PlayStation 3 Slim Laser lens Replacement: adım 6, 2 resimden 1. PlayStation 3 Slim Laser lens Replacement: adım 6, 2 resimden 2.
    • Lift the Blu-ray drive slightly by its right edge to dislodge the control board from its housing.
    • Remove the Blu-ray drive from the PS3.
    • After you reinstall the Blu-ray drive, be sure the control board is firmly seated in the lower case before proceeding.
    • If replacing the Blu-ray drive with a new drive, swap the circuit board from your old drive into the new drive.
Sonuç
20 farklı kişi bu kılavuzu tamamladı.
ZFix
191.368 İtibar
330 adet Kılavuz yazıldı
Ekip
Master Techs Master Techs üyesi
Community
321 Üyeler
1.464 adet Kılavuz yazıldı
5 Yorum
Donde puedo comprar refacciones y partes para PS3 Slim?
David - Yanıt
yo vendo amigo = ivaramso@gmail.com para ventas
Ivan Ramirez -
How can this be easy, but the Blu-Ray drive be considered Moderate? You need to complete the Blu-Ray drive removal prior to replacing the laser lens, which means this is at best a Moderate task.
Ben Kevan - Yanıt
This is not lens replacement, this is drive replacement. Is there a separate guide for lens replacement?
cmchallam - Yanıt
Shows how to do the laser assembly in the video but not how to reinstall it in the drive. Lazy guide. Just buy a whole new drive if you are following this guide.
Beninja - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 31
Son 30 gün: 127
Her zaman: 32,686
