Giriş
Use this guide to remove the plastic top cover.
Neye ihtiyacın var
Turn the PS3 over and lay it on its backside.
Carefully peel the warranty sticker up off the lower case to reveal a hidden screw cover.
Remove the four 13.3 mm T8 security Torx screws beneath the Blu-ray drive opening. (Some models may only have three screws)
Can we edit this to say 4 screws?
I made the change from three to four screws, but you're able to edit the guides as well. If you want to edit something, you can click the Edit link on the right side of any guide step, or the Edit link at the top right of the page (sandwiched in-between View and History).
Do you guys have a guide for the PS3 Slim Model 3001A. The fan is different than this model.
3001a is basically same motherboard but cheaper plastic bd drive other than that its exactly the same until you get to the new slim line
Robert -
My PS3 had only three Torx screws. Having four in the diagram was initially confusing. Obviously they made a mid-stream change at some point (mine is several years old now).
I've accidentally removed the ribbon cable from the blu-Ray drive and can not seem to figure out how to reconnect it. Can anyone help?
Take the top off the drive, connect the ribbon to the motherboard then replace the drive sliding the ribbon through the slot on the bottom of the drive and reconnect to the laser.
If the screw has a pin in the center, that means it is a security Torx meant to prevent tampering. To remove this screw, follow the guide I have linked below...
How do u buy the screw driver for these screws
Online at the usual suspects?
Or some hobby stores or places that sell tools will sometimes carry these.
Anyone else's screws for this step need the T7 bit instead of T8?
What is the name of this screwdriver
92 farklı kişi bu kılavuzu tamamladı.
2 Yorum
No good mine a Sony.
Thank you this helped me so much!!!!
Don’t even need to bother with the sticker anymore since SONY does not care what you do with them anymore.
Travis Wheeler - Yanıt
