Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Disconnect the DC-In and Blu-ray power cables from the motherboard.
Pull the fan cables straight up to lift the fan connector up and out of its socket on the motherboard.
Remove the following nine screws holding the motherboard assembly together:
Four 14.8 mm shouldered Phillips
Five 9.5 mm Phillips
Remove the two heat sink clamps from the bottom of the motherboard assembly.
Gently press the board away from the top shield assembly near the fan connector and the corner of the board near the wireless sockets.
Lift the top shield assembly off the motherboard from its front edge.
