Ana içeriğe geç
PlayStation 3 Super Slim Optical Drive Replacement
Neye ihtiyacın var
  1. PlayStation 3 Super Slim Optical Drive Replacement, Power Supply Unit: adım 1, 2 resimden 1. PlayStation 3 Super Slim Optical Drive Replacement, Power Supply Unit: adım 1, 2 resimden 2.
    • Remove the side HDD bay cover by sliding the panel towards the back of the device.
    • The bay cover is found on the right side of the device.
  2. PlayStation 3 Super Slim Optical Drive Replacement: adım 2, 2 resimden 1. PlayStation 3 Super Slim Optical Drive Replacement: adım 2, 2 resimden 2.
    • Remove all three black 9.8mm long screws with a T-8 security screwdriver.
    • Remove the blue 7.9mm long screw with a Phillips #1 screwdriver.
  3. PlayStation 3 Super Slim Optical Drive Replacement: adım 3, 2 resimden 1. PlayStation 3 Super Slim Optical Drive Replacement: adım 3, 2 resimden 2.
    • Pull on the tab to remove the HDD.
    • The HDD should be removed and stored carefully to prevent damage to data.
  4. PlayStation 3 Super Slim Optical Drive Replacement: adım 4, 2 resimden 1. PlayStation 3 Super Slim Optical Drive Replacement: adım 4, 2 resimden 2.
    • On the bottom of the device, pry out the three rubber feet covers with the metal spudger.
    • Remove the four black 36.3mm long screws underneath with a Phillips #1 screwdriver.
    • One screw is located underneath the warranty sticker. This sticker can either be peeled off or punctured through with a screwdriver.
  5. PlayStation 3 Super Slim Optical Drive Replacement: adım 5, 2 resimden 1. PlayStation 3 Super Slim Optical Drive Replacement: adım 5, 2 resimden 2.
    • On the top of the device, unlatch the hook on the furthest right beneath the front panel, lift the panel slightly and apply pressure.
    • Unlatch the second right-side hook by sliding a plastic opening tool in the marked area.
    • Slide the panel to the left to unlatch the rest of the hooks.
    • This is probably the most difficult part of the procedure. If you cannot unlatch the hook on the front panel, you can attempt to pry all the hooks off. However, do this at your own risk, as these hooks break easily.
  6. PlayStation 3 Super Slim Optical Drive Replacement: adım 6, 1 resimden 1.
    • Remove the back panel by pressing down the tab on the right side of the device, and sliding the panel to the left.
  7. PlayStation 3 Super Slim Optical Drive Replacement: adım 7, 3 resimden 1. PlayStation 3 Super Slim Optical Drive Replacement: adım 7, 3 resimden 2. PlayStation 3 Super Slim Optical Drive Replacement: adım 7, 3 resimden 3.
    • Remove the five silver 20.8mm long screws with a Phillips #1 screwdriver.
    • Remove the two black 9.9mm long screws in the disc reader with a T-8 security screwdriver.
    • Remove the top black plastic shell.
  8. PlayStation 3 Super Slim Optical Drive Replacement: adım 8, 3 resimden 1. PlayStation 3 Super Slim Optical Drive Replacement: adım 8, 3 resimden 2. PlayStation 3 Super Slim Optical Drive Replacement: adım 8, 3 resimden 3.
    • Move the optical drive to the side to reveal one of the silver 8.8mm long screws.
    • Remove the two silver 8.8mm long screws on either side with a Phillips #1 screwdriver.
  9. PlayStation 3 Super Slim Optical Drive Replacement: adım 9, 3 resimden 1. PlayStation 3 Super Slim Optical Drive Replacement: adım 9, 3 resimden 2. PlayStation 3 Super Slim Optical Drive Replacement: adım 9, 3 resimden 3.
    • Remove the cable from the plug and remove the wires from the two plastic hooks.
    • When removing the cable from the plug, pull on the plastic male connecter, not on the wires.
    • Remove the power supply unit.
  10. PlayStation 3 Super Slim Optical Drive Replacement, Optical Drive: adım 10, 3 resimden 1. PlayStation 3 Super Slim Optical Drive Replacement, Optical Drive: adım 10, 3 resimden 2. PlayStation 3 Super Slim Optical Drive Replacement, Optical Drive: adım 10, 3 resimden 3.
    • Remove the front white flex-ribbon cable by pulling upward from its base.
    • Remove the black and blue flex-ribbon cable behind it by pulling upward on the black tab, then pulling out the cable.
  11. PlayStation 3 Super Slim Optical Drive Replacement: adım 11, 3 resimden 1. PlayStation 3 Super Slim Optical Drive Replacement: adım 11, 3 resimden 2. PlayStation 3 Super Slim Optical Drive Replacement: adım 11, 3 resimden 3.
    • Rotate the device 180 degrees.
    • Remove the back white flex-ribbon cable by pulling upward from its base.
    • Remove the optical drive.
Sonuç
Install the replacement optical drive. To reassemble your device, follow these instructions in reverse order.
17 farklı kişi bu kılavuzu tamamladı.
Joseph O'Connor
2.775 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 34-13, Maness Spring 2016 Cal Poly, Team 34-13, Maness Spring 2016 üyesi
CPSU-MANESS-S16S34G13
4 Üyeler
24 adet Kılavuz yazıldı
7Kılavuz Yorumları
It might be useful to have pictures of the super slim too since it’s in the title. I’m referring to CECH-3xxx / 4xxx mostly because the shell and disassembly looks a bit different. Great guide all the same. Thanks!
Sam Roney - Yanıt
Hi i have a Question
I change the Optical Drive on my PS 3 Super Slim Named KEM850 PHA KES850 .But the new drive only play DVD not Blueray Game or Movie
An update was made without drive on board connected .can be this the problem. how can i fix them
Please Help
s
Karl-Heinz Schumacher - Yanıt
How to pair a new optical drive with the old motherboard?
Tiago - Yanıt
PS3s and PS4s have daughterboards on their disc drives. Put the daughterboard of your old disc drive on the new one and it may work.
Joe Drew -
I am replacing the optical drive in my console. But didn't note where the drive ribbon was positioned!? Every video I have found, they just pop right in...my original and replacement drives, have larger receptacles than the ribbon it self. There are at least 5 pins, that don't have (potentially) anything connecting them, to the ribbon. I don't want to randomly place the ribbon in one of the possible (7?) positions and fry something in the process...so where do I connect the smaller ribbon?!
Robert Shelton - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 12
Son 7 gün: 83
Son 30 gün: 424
Her zaman: 21,483
