Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Remove the side HDD bay cover by sliding the panel towards the back of the device.
Remove all three black 9.8mm long screws with a T-8 security screwdriver.
Remove the blue 7.9mm long screw with a Phillips #1 screwdriver.
On the bottom of the device, pry out the three rubber feet covers with the metal spudger.
Remove the four black 36.3mm long screws underneath with a Phillips #1 screwdriver.
On the top of the device, unlatch the hook on the furthest right beneath the front panel, lift the panel slightly and apply pressure.
Unlatch the second right-side hook by sliding a plastic opening tool in the marked area.
Slide the panel to the left to unlatch the rest of the hooks.
Remove the back panel by pressing down the tab on the right side of the device, and sliding the panel to the left.
Remove the five silver 20.8mm long screws with a Phillips #1 screwdriver.
Remove the two black 9.9mm long screws in the disc reader with a T-8 security screwdriver.
Remove the top black plastic shell.
Move the optical drive to the side to reveal one of the silver 8.8mm long screws.
Remove the two silver 8.8mm long screws on either side with a Phillips #1 screwdriver.
Remove the cable from the plug and remove the wires from the two plastic hooks.
Remove the power supply unit.
22 farklı kişi bu kılavuzu tamamladı.
8 Yorum
Perfect how to guide. Fixed my PS3 easily. Thanks
Great guide. However, still no power on PS3. Any suggestions as to what else may be the problem?
Peter Maher, I am in the same boat. I have no idea what the problem is. Red light in standby, but as soon as I try to power on, nothing. Same as before I did this power supply replacement. Obviously, something else is the problem. Anyone who has some insight into this please help!
Did you guys get word on the red light with no power on fix mine has the same issue.
i have the same problem as Peter Maher, the red light is in standby neither turning green on pressing nor it sounds beep on long press. dont know whats wrong. anyone has any solution to this?
