Bu kılavuzda güncel değişiklikler var. En son onaylanmamış sürüme geçin.
Giriş
If your PS4 is running hard and constantly overheating and has led you to replacing the fan, follow the steps below. Be aware that any replacement or teardown beyond the hard drive voids the Sony warranty.
Removing the motherboard separates the original thermal paste between the processor and the heat sink. Before you reassemble your device, reapply a new layer of thermal paste. Follow this guide to learn how.
Neye ihtiyacın var
Videoya Genel Bakış
Remove the twelve 9.7 mm Torx screws securing the upper EMI shield.
Insert the flat end of a spudger in between the fan cable and the motherboard.
Twist the spudger to lift the connector straight up and disconnect it from the motherboard.
Remove three, 5mm Phillips head #1 screws.
Lift straight up on the metal tray to remove it.
274 farklı kişi bu kılavuzu tamamladı.
35 Yorum
Great guide, but where to buy a fan for the ps4?!
Look one ebay, that's where my store gets the majority of out parts from. considering we fix computers.
Will this guide work with the CUH-1200 model?
My PS4 has been overheating so I decided to take it apart and clean it. I cleaned it well but it still over heats the fan will try to start up but cuts back off plz help
