Giriş
Follow this guide to replace the motherboard on your Sony Playstation 4.
The motherboard and optical drive are paired, thus replacing only the motherboard will result in a non-functioning device. Be sure to order the correct paired optical drive and motherboard for your PS4 model and replace both.
Unplug your PS4 before beginning any repairs.
Grip the PS4 with both hands along the gap in the top cover.
Push the glossy side of the top cover with your thumbs until it pops to the side.
Lift the glossy top cover up and back to remove it from the PS4.
Remove the 6.5 mm Phillips screw securing the hard drive bracket to the enclosure.
Use tweezers to remove the two stickers in the center of the back of the PS4 exposing two case screws.
Use tweezers to carefully remove the plastic screw covers in each corner, exposing two more case screws.
Remove the four 7.2 mm Torx security screws on the back of the PS4.
Remove three 9.7 mm Torx security screws.
Remove two 41 mm Phillips screws and brackets.
Lift the power supply straight up and out of the PS4.
why is this so hard to take out? I keep pulling on it but the left side is stuck….
It’s because of the metal prongs, unfortunately there’s no trick to make it easy to get out. Try different ways of gripping it to get more force.
Use the tip of a spudger to disconnect the antenna cable from the motherboard.
Use your fingernail to press down on the metal release lever of the ribbon cable on top of the optical drive.
Use your fingers or a pair of tweezers to disconnect the ribbon cable by pulling on the black tab.
Remove the four screws securing the optical drive.
Three 9.7 mm Torx screws
One 6.2 mm Phillips screw
Lift the upper case up and back to remove it from the PS4.
“Significant force” is a bit of an understatement. It’s like it’s superglued together..
Remove the twelve 9.7 mm Torx screws securing the upper EMI shield.
In my PS4, there is a small black Philips screw behind where the power lead connects to the motherboard. That screw connects the EMI shield to the inner metal where the power supply sits.
Remove the two 15.6 mm Phillips screws.
Gradually unscrew the pressure plate by turning each screw one half turn at a time.
Alternate between the two screws to maintain even pressure on the pressure plate.
Insert the flat end of a spudger in between the fan cable and the motherboard.
Twist the spudger to lift the connector straight up and disconnect it from the motherboard.
157 farklı kişi bu kılavuzu tamamladı.
34 Yorum
Regarding the three wire plug in step 20 - is there a good way to repair this piece if, say, you pulled the wires out of the connector by accident? is there a place to get a replacement part?
I have tried to replace the hdmi port however being somewhat of an idiot I slipped and knocked off onto the little black squares just behind the port on the left hand side. Does anyone know what these are?
contacts of the motherboard
You may be talking about capacitors that are critically important for the unit to function.
South30 -
You mean that little brown parts next to the desoldered HDMI port chip? Seems to be capaciators.
Check it with a multimeter: No connection through that parts: Capaciator, Connection through that parts: Coil
Ok so I was taking mine apart, and while I was separating the ribbon wire from the optical drive during step 7, I broke the top off the connector by accident. I thought I could fix it with hot glue, but my ps4 doesn't read disks (at all, doesn't even know there's a disk in the drive). Is there a way to repair this without getting a new drive?
when I bought the replacement motherboard and optical drive and installed everything, I got a message saying connect USB with software update. Is this because I'm using my original hdd from my original mobo+ optical drive that is different from the hdd my replacement parts came with?
Could you please tell me where you bought a replacement motherboard from as i've been looking everywhere!?
Does your blu-ray drive still work on the new motherboard? I seem to recall on the PS3 that the blu-ray drive was tied to a console, I assume you had to reformat the HDD also?
Cómo saber que tarjeta es la indicada
Es q tengo una ps4 slim y la tarjeta está dañada pero nose cual es la indicada xq trae unos números y nose si afecta en algo
Por favor la respuesta a mi correo gracias :: oscardanilo1724@gmail.com
Desarme la ps4 la limpie arme y andaba…resultado que cuando saque la fuente de alimentación desconecte un pin que que está en la placa base es blanco con unas fichas lo solde e igual no funciona …le pasa corriente pero muy poca que puede ser ayudaaaa
Pablolopez1095@gmail.com ayuda …es mi correo alguna
Brought a used ps4 any idea how to remove the ribbon port of the motherboad step by step to replace. Someone put crazy glue on it..
Thanks for this informative post <a href="http://www.buyplaystation.com/">buyplaystation.com</a>
I ordered a new HDMI port because it was just a black screen but the receivers on the motherboard are worn down, what should I do
thanks for the post myhelmetsguide
Hi Iwas cleaning my ps4 and pull the power connection and it is lose I bought another ps4 and tried to put my hard drive in the new one but doesn’t work. Somebody can help me. It’s posible just to change the mother board I have a lot of games there. Thanks
Motherboad of ps5 we are wating for the ps4 we need best hard drive for ps4 which can enhance the capability of ps4.
Welding gla a
welding jkgfkjjfhkfiyfyiryiriyriyriyr
tig hjjjjjjjjjjjjjjjjjjjjfkkkkkkhhkfkfkhf
sir i want ps4 motherboard,did u have ps4 motherboard.
I’ve read along the guides that a BDP-020 optical drive can work with an SAA-001 motherboard, but mine still receives the CE-35888-2 error. Am I replacing the incorrect part?
Hi my ps4 has stopped working and doesnt turn on at all, ive tried different outlets and different power cables for the ps4, still no luck. Ive pulled it apart and had a look at the power supply board and mother board aswell as dusted it all out. The mother board has yellow stains/ dots near the hdmi port and some other random spots around the mother board. I have the first ps4.
Does anyone know whats wrong? Id rather fix it than pay for a new one.
