Ana içeriğe geç
Giriş
This step-by-step procedure will allow the reader to get to and replace the optical drive responsible for reading the disc. Be aware that any replacement or teardown beyond the hard drive voids the Sony warranty.
  1. Flip the PS4 over on its top.
    • Flip the PS4 over on its top.
  2. Remove the four stickers on the back of the PS4. Despite the scary-sounding warning on the sticker, Sony cannot legally void your warranty for removing it—only if you damage your device.
  3. Remove the three 9mm TR8 Torx Security screws on the back of the system.
    • Remove the three 9mm TR8 Torx Security screws on the back of the system.
    what is the difference bw model adp 300cr & adp 300er ? where can i get adp 300er
    Ravindra Nagar - Yanıt
  4. Remove the bottom panel by lifting the front piece up and sliding the panel towards the back.
    • Remove the bottom panel by lifting the front piece up and sliding the panel towards the back.
  5. Remove the three 9mm TR9 Torx screws.
    • Remove the three 9mm TR9 Torx screws.
    • Remove the two 4cm Phillips head #1 screws.
    Step 5, 6, 7, 9, 10, 11 are useless. After step 4 you just need step 8, 12, 13, 14 to take out the drive.
    Peter Buergisser - Yanıt
  6. MacBook Pil Tamir Setleri
    Başlangıç $69.99
    Buy Now
    Başlangıç $69.99
    Buy Now
  7. Lift straight up on the power supply.
    • Lift straight up on the power supply.
    Mine doesnt go straight upp, its like i have tog struggle till do it, what do i do… i have opend it but with THE struggle.
    Albert Einstein - Yanıt
    There are two connections on the under side of the power supply on the left side. The right side should lift up easily and then with a better grip the left side will lift. This takes some force but as long as you don't pull too far and damage the cable, this extra force shouldn't damage anything.
    Qmox -
  8. Remove the 5 wire plug that is attached from the power supply to the motherboard. You can now fully remove the power supply from the system.
    • Remove the 5 wire plug that is attached from the power supply to the motherboard.
    • You can now fully remove the power supply from the system.
    Where can I buy a replacement power supply? Been ps4-less since march.
    Danny Mulato - Yanıt
    HERE A LINK DANNY HOPE THIS HELPS
    https://www.amazon.co.uk/gp/product/B013...
    LEEDS -
    You can't, i'm in the same boat. The only option is to buy a used ps4 that perhaps won't read discs or has some issue other than power, and use it's PSU as a replacement. But good luck with that as the Sony warranty period is still active.
    Lycaon OfArcadia - Yanıt
    whats the number on the ic unit of the power supply? it ends with 015
    Sanjay Lewis - Yanıt
    You can buy it in aliexpress
    Fede - Yanıt
    My PS4 has a 4 wire plug that is attached from the power supply to the motherboard not a 5 wire plug..... What do I do? Half way through the replacement and I can't go forward with it.
    Nate Beck - Yanıt
    Try visiting one of these repair shops for spare parts http://www.trustedrepairs.co.uk/electron...
    Damian - Yanıt
    If the five wire plug connected to the motherboard break off can you fix it back
    matthewcooper422 - Yanıt
    Lol i just broke mine so if someone can tell me too if i can fix it you would be a life saver
    Charles flack -
    Can somone help me? The pin connector won't budge for $@$*, any harder I'll tear it apart... My friend tols me ina a hurry to place something thin underneath it ( dunno what ) ... So underneath what? What is so thin? Not even paper can fit anywhere... So... Help please?
    Arman Delalic - Yanıt
    I just had this problem and i broke the connector.
    The problem is dont pull on the base or you'll pull it off the motherboard, pull the wires and a small plug will come off
    Hopefully this got to you in time :)
    Charles flack -
    Hello a little confused as to which tr 9 or 8 I need i know what it says here is was looking on the playstation community site and they have the 8 listed please help
    roxanne corona - Yanıt
    Hello, I pulled the connector of the mobo. What options do have if any to reconnect the connector? Thanks in advance.
    Mike - Yanıt
    Same thing .
    Breia Turms -
    Hab jetzt ausersehen das ganze Kabel entfernt wie auf dem Foto und jetzt merke ich das dass falsch war Danke jetzt kann ich meine ps4 wegschmeißen
    Breia Turms - Yanıt
    Ich Broke the connector from the motherboard. How Can i fix it
    Breia Turms - Yanıt
    Not necessary to remove ANY of the ribbons or wires from the MAIN circuit board. Just remove the ends on the optical drive. Also WiFi cable doesn’t need to be removed, just unscrew the end and then moved…
    My power supply cable was too tightly held by the aged rigid plastic board connector and I (way too easily) snapped the base connector off. Ive just hosed my ps4 because of this unessessary few steps. Sigh.
    any micro soldering suggestions for a newbie?
    Demetri Minotakis - Yanıt
    How do you know which PSU to buy ?
    Simon Goldberger - Yanıt
  9. Disconnect the ribbon wire from the optical drive by pressing down on the metal release tab and gently pulling the ribbon wire. This should not require force.
    • Disconnect the ribbon wire from the optical drive by pressing down on the metal release tab and gently pulling the ribbon wire. This should not require force.
  10. Disconnect the same ribbon wire from the motherboard; making sure you're pressing down on the metal release tab and gently pulling the ribbon wire.
    • Disconnect the same ribbon wire from the motherboard; making sure you're pressing down on the metal release tab and gently pulling the ribbon wire.
  11. Remove the wifi antenna cable attached to the motherboard.
    • Remove the wifi antenna cable attached to the motherboard.
    You may not have to unplug the antenna to remove the drive
    -H
    Hassan Sinanan - Yanıt
  12. Remove the optical drive four wire plug from the motherboard by pulling straight out.
    • Remove the optical drive four wire plug from the motherboard by pulling straight out.
    What is the part number of that cable? Please I need it!
    Matias KAPLAN - Yanıt
    @Matias KAPLAN I inspected the cable thoroughly with a magnifying glass and doesn’t have an OEM part number, only AWS cables information. For aftermarket part i found it on ebay as “Brand Optical Drive Cable + Power Cable for Playstation 4 PS4 Console “ comes in pair with the other cable tho. It seems to be a regular 1x 4pin Power cable.
    Phillipe Legenda - Yanıt
  13. Remove the four 9mm Torx T9 screw attached to the wifi antenna and optical drive.
    • Remove the four 9mm Torx T9 screw attached to the wifi antenna and optical drive.
    • Remove the 5mm Phillips head #1 screw.
  14. Lift up and remove the wifi antenna.
    • Lift up and remove the wifi antenna.
  15. The optical drive can now be lifted straight up and removed from the system.
    • The optical drive can now be lifted straight up and removed from the system.
    • Be aware that the optical drive is "married" to the motherboard. If you need to replace your optical drive you must remove the motherboard on the original optical drive and install it on the drive you intend to install in your PS4.
    Is the motherboard the drive is "married" to the board that is shown on top of the drive and what is entailed in switching it out?
    paulk128 - Yanıt
    I need to know as well does it require soldering or just connecting the cables back up to it
    Chrystal Allen YGX Themes - Yanıt
    Though I have not replaced my optical drive yet. I will. I have worked on many laptops. Looking at this guide, I see that the logic board (The Mother board is the main board of the machine.) on the optical drive is connected to the drive with Z.I.F. (Zero Input Force) connectors like those disconnected in the above instructions. It should be noted that these connectors have a release. Note the brownish 'flap' at the back of the 'socket', it will either flip up, or slide out. this will make replacing the ribbon cable much easier.
    manterdg - Yanıt
    Can you replace Just the flex ribbon or do you have to replace the entire drive
    dseit609 -
    How do you know when switching the drive that it's not a fault on the drives motherboard causing the problem
    willofmason - Yanıt
    I'd say you cannot know with certainty, until you test it!
    If a fault on the drives motherboard was a common failure, then you'd have more reason to believe said theory.
    Kyle Andersen -
    I'm confused by Step 14. By "Motherboard" do you mean Logic Board? If so, is the Logic Board married to the Optical Drive or to the Motherboard? If it is married to the Optical Drive then the new Optical Drive should come with its own Logic Board correct? If not then replacing the Optical Drive and using the original Logic Board would not work? Should this actually read "the Logic Board on the Optical Drive is married to the Motherboard in the PS4"?
    Keith - Yanıt
    The logic board on the disc drive is married to the PS4s motherboard.
    Bradley Goode -
    Where is this logic board located because I don't have a long narrow board on the bottom outside part of the blu ray drive in my PS4 as the picture above illustrates. I have this 1and1/2 inch by 2 inch board that is inbetween both the top and bottom of the drives Casing located on the top right corner of the casing as you look at the PS4 in the upside down position with the front portion facing me.
    Carlos Inesta - Yanıt
    I realize that these might be foolish questions but, is that 1-1/2"by 2" board the logic board to my blu ray drive, and, do I have to swap it out with the one that will come to my house when I recieve my new blu ray drive? I don't want to have to take the PS4 apart for a second time because the logic board on my new blu ray drive wasn't recognized. Also, Would rebuilding the PS4 database by powering up the PS4 in safe mode help the PS4 motherboard recognize the new logic board if the logic board on the new blu ray drive wasn't replaced.
    Refer to step 14 in this tutorial. The Green Board that you can disconnect the Ribbon Cables from on top of the Blue Ray Drive IS the Circuit Board/Logic Board that is “married" to the PS4’s Motherboard/Mainboard. It needs to be installed to the replacement Blue Ray drive.
    Charles Holland -
    so I have a question how can we tell when its being married to each other???
    where do i look on the motherboard and optical drive to match them both???
    its going to get me frustrated looking for a new blu-ray drive
    im not really sure what im trying to say but I just hope someone understands what im trying to say
    stan w harper - Yanıt
    Hi there is a logic board on the top of the Blu-ray drive it is this small board that is paired to the PS4 mainboard so when replacing the Blu-ray drive just use the new part but keep your old board to use on the new drive
    chloe kitts -
    There is a small logic board on the Blu-ray drive take this off and keep it to use on the new Blu-ray drive as it’s usually mechanical or lens /laser failure not the logic board ,it is this small board that paired to the PS4 main board
    chloe kitts -
    They need to edit the end of this guide where it says “Be aware that the optical drive is "married" to the motherboard. If you need to replace your optical drive you must remove the motherboard on the original optical drive and install it on the drive you intend to install in your PS4. “, This seems disingenuous by ifixit. When you go to buy the drive from ifixit.com they try to sell you a drive/mobo combo. It seems to me the less knowledgeable users of this site, may think they need to buy a new motherboard when in reality they just need the disc drive and place their old logic board with the new disc drive. PLEASE FIX THE WARNING ON STEP 14! I dunno, don’t want to be a conspiracy theorist, but my trust in companies has been eroded and to me this seems intentional to sell more of their disc/mobo combinations. Maybe I’m just a bitter pessimist. Regardless, please fix step 14 to reflect reality.
    James Peters - Yanıt
Sonuç
120 farklı kişi bu kılavuzu tamamladı.
Robert Harvey
7.545 İtibar
5 adet Kılavuz yazıldı
Takım
Cal Poly, Team 8-12, Regan Spring 2014 Cal Poly, Team 8-12, Regan Spring 2014 üyesi
CPSU-REGAN-S14S8G12
5 Üyeler
32 adet Kılavuz yazıldı
48 Yorum
This was a great help after my 2 yr old put a coin in my PS4. However when following the steps backwards I got to step 7 which says 'Remove the 5 wire plug attached from the power supply to the motherboard' & couldn't see how to reattach it. I then noticed it looks like I've pulled the whole plastic white casing/plug holder (within the orange rectangle) off the mobo rather than just the plug from the casing. Although the pic looks like the plastic casing does come off the mobo as it's at an angle (maybe why I pulled the whole thing out or maybe I did it right).
I'm thinking I've made a mistake is because now I cant see anywhere that I can 'plug' the 5 L shaped wires on the bottom of the plastic casing back onto the mobo. Plus where they used to be attached there's now 5 tiny silver rectangles on the mobo (2 opposite 3), so I guess these 5 wires were some how adhered to those mobo rectangles by a conductive adhesive of some sort.
Any suggestion for the best repair method would be appreciated.
Thanks
doc browejnn - Yanıt
If you've pulled the female end from the motherboard the it need to be resoldered to the board, most likely gonna need to pull the motherboard. It's a very simple connector, sounds as if you yanked the whole thing off.
lynx2069 -
Is anyone there who try to change the optical drive without change the Motherboard in the same time ? And does it run ?
Thanks for your help.
Frederic Morelli - Yanıt
Would this fix the disc ejection issue?
Tim - Yanıt
No, as the issue isn't attributable to the drive itself. The issue is the capacitive eject button and the rubber foot on the bottom of the console. The foot expands with the heating and cooling cycles of the machine, and can set off the button just by making any contact at all. I suggest removing it, cutting off the front 1/8", then reinstalling it. That's what worked for me.
Nathan Rice -
This is very useful, however in order to play a new Optical drive a married motherboard must be installed also. Since the these are not plug and play drives.
Fueled by Rage - Yanıt
Frederic Morelli -
I don't know which one of these to fix my Playstation 4 works fine until I put a disk in it it just says corrupted data it turns on fine the Internet works fine but games movies nothing works please someone tell me how to fix this
Samantha price - Yanıt
Sounds like the connector fron the disk drive to the motherboard may not be fully connected.
UnicornsOnLSD -
I recently got a PS4 form a relative that was a busted disk drive because he spilled water on it. the repair man said that the drive controll board is dead bacause foo water damage. What do i do? buy a new whole dirve or will that not work because of MARRage
Daniel Anishchenko - Yanıt
I wonder what I could damage. I used tutorial from yt.
Console works, games are running without problems, it is silent after new thermal paste.
But blue ray is dead: - not responding when pressing bottom eject button. - not reading already inside cd. - not accepting any cd - no option to eject from controler options
I wonder what could go wrong. Some cable? Something wrong with this small board that is next to blue ray?
I see small board, 1 4-pin connector, 4 tapes( 1 from motherboard, 3 from blue ray). Everything connected but not working.
Anyone has some clue how I can fix this or investigate?
Lukasz Z - Yanıt
I have the exact same problem, I cleaned my very dirty PS4, applied the arctic MX-2 thermal compound, put everything back together. When I fired the PS4 back on the Blu-ray drive doesn't do anything., won't take any discs, the eject button does nothing.
Were you able to fix yours? How did you do it? what was the problem? If not.... can anyone help us both?
Haris -
I have the exact same problem :((((
my Blue ray drive is dead
Ali -
When you remove the blu ray drive one of the most important steps to replacing it (and one that most instructions fail to mention) is the two metal tabs on the drive that hang over the back and left side. Starting withe the rear of the drive make sure the silver tab that hangs off the back slips over the plastic ridge and do the same with the other silver tab on the left side. The first time i tried to clean my optical drive i just popped it in without making sure these two tabs were in the proper position and it was as if there was no power being supplied to the drive.
Casey Jonason -
Hi! My son put a coin in the optical drive, how can I put the coin out doing this? sorry for my english im from spain, i need help
Diana M Da Silva Henriques - Yanıt
when i am trying to find an optical drive for my ps4 its says there are 2 types which do i need and hwo would i know which one i need
kerim pala - Yanıt
this s the same problem i am having can somebody help us. it would be muchly appreciated tnx
LEEDS -
Changed my ps4 blue ray disc drive with mother board cause my son put multiple games in. Ordered and installed new one but now it will not recognize cd or game when inserted. Do i have to sync new disc drive to ps4 or does it automatically do it? Please help
dagucc - Yanıt
I installed new optical disc drive and now my ps4 will not recognize any disc or game. Wat to do?
dagucc - Yanıt
Okay, why is the system automatically flagging my reply to someone as spam?
Nathan Rice - Yanıt
I had this problem where I didn't press the release tab on the mother border and the flex ribbons ends got cut off . could this be the reason why my drive doesn't even accepttdisks anymore ?
claudio - Yanıt
I went step by step replaced the drive and now there is no power. It was working fine when I took it apart now nothing... I've gone back over it 3 times... Power supply's just don't die like that do they?
Mike - Yanıt
I'm in this same boat. Bought two optical drives, and when installed the Playstation 4 won't turn on, with the old one it turns on but the disc sensor doesn't work and won't receive discs...
Did you solve your problem?
RobertoLL -
I NEED HELP!!!
I TOOK APART MY PS4 TO REPLACE MY FAN, WHICH WAS SUCCESSFUL. BUT THEN ALL THE SUDDEN MY DRIVE WILL NOT WORK. IT JUST GIVES KE AN ERROR MESSAGE. WENT BACK THROUGH AND MADE SURE EVERYTHING WAS CONNECTED PROPERLY AND IT IS. I FEAR SOMEHOW THE DAUGHTERBOARD GOT MESSD UP. I NEED TO SPEAK WITH SOMEONE FAMILIAR WITH THE ISSUE AND IM WILLING TO COMPENSATE SOMOEN WHO CAN POINT ME IN THE RIGHT DIRECTION.
I CN BE REACHED AT chooseloveorfear@gmail OR TEXTED AT 602#429#9236. THANKS!!!
Paul - Yanıt
I have a problem! i bought a bdp-020 wich is the one that was inside my console! but when i try to play something i got this error "CE-35888-2" and when i tried to update i got this one "e-ffffffff " help me please.
i follow the step by stem video on youtube. but isnt working!
Mauri Rios - Yanıt
Your bleuray board is married to your motherboard if you want to Let it workshop again you have to place your old bord frame your bleuray
Ws -
Ook nl mensen hier?
Ik had problemen met mijn bleuray hij accepteert geen disk meer. Reset ect gedaan restore data ect. Niets
Heb een nieuwe bleuray gekocht en oude printplaat omgezet op mijn nieuwe bleuray. Nou hij is 5 dagen goed geweest en krijg het zelfde gedonder weer reset niets werkt iemand een idee?
Ws -
Thanks i was trying to find my model optical drive for so long as a replacement for my current one but after seeing your awareness comment at the end then i'm guessing that i can just buy any new replacement optical drive i just need to take the motherboard off of my current one and put it on the new one is that right ?
Reaper666 - Yanıt
Do i need to find my model optical drive and put the motherboard off of my current one onto that one or can i buy any model optical drive and put the motherboard off of my current one onto that one ?
Reaper666 - Yanıt
Yeah that's what I need to know does anyone have the answer?
zane akhter -
So quick question. By married motherboard do you mean the board that is on the optical drive itself or are you referring to the whole system board of the PS4? If I bought a new disc drive online and swapped out the disc drive motherboards would that work? Any soldering required, or simply remove some screws? Thank you for your help, just need a quick answer!
Jabran Shakil - Yanıt
My PS4 is doing the thing where it's constantly trying to eject a disk that isn't in there. It had been doing this for a long time so I tightened the manual "eject" screw, turned it on it's side, removed the rubber foot, unplugged it from the way and let it sit for 10 mins, etc (pretty much everything on the interwebs) this worked for a a few months but it's back to it's old habits. Am I able to just removed the optical drive? All my games are digital copies anywho and having the optical drive has just been annoying (it's now at the point where it ejects every 30 seconds) due to the ejection noises and the beeping.
Harrison - Yanıt
Yeah I'm with you. I've tried all that and more. Turning the manual eject screw seemed a temporary fix but even that doesn't work now. Still beeps and ejects. That's why i'm here. Will it help to replace the drive entirely or not? Seems not. I'm mostly digital but I still do have a need for the optical drive.
shabznet -
So the motherboard that is on the old blue ray disk drive do you need to put that on the new one or do I have to buy another one?
zane akhter - Yanıt
Hi how do I determine which disc drive I have to replace with the same as there are different ones out thrre
stevec5238 - Yanıt
I bought the new bluray drive, switched over the mother board, and now I can't insert a disc. It's almost as though there's no power to the drive.
James Brogan - Yanıt
Could anyone help me.
I tried to change the drive board and somehow broke the big ribbon cable.
Now the disc won't spin anymore.
AlessioM - Yanıt
I removed my old disc drive because it wouldn't accept discs at all. It wouldn't even make a noise....almost like it was just DEAD. So I bought a brand new blu Ray optical drive for the PS4 and I removed the old one and installed the new one. I removed the motherboard from the old and screwed it onto the new one. I am sure I've installed everything like it should be but when I go to insert a disk.... I GET THE EXACT SAME RESULT!!!! No noise and it won't accept the disc. Please help if anyone can think of something I might have forgotten to do or overlooked.
gilleytopher@gmail.com
gilleytopher - Yanıt
Hello I have a problem I have damaged my optical disc drive and the logic board is there anything I can do
Jason - Yanıt
I just don't underatand, I bought another optical drive with a new laser installed and I took out the optical mother board from the new drive replacing it with the original one and I still get un recognized discs and I know for a fact it's the optical drive mother board because I tested the new optical drive with it's mother board and I could play blue rays but not ps4 games which gave me an error pretty much saying not compatable. I swapped back to the original optical mother board and pretty much back to normal again, not recognizing discs and I checked everything, even the rollers. I just don't get it, I always had back luck with play stations. I don't think anyone had changed it before and therefore the optical mother board should still be original, so what's happening here?
Deeb - Yanıt
If you bought a married drive and mother board, would they then run together?
Todd Law - Yanıt
To anyone whats haveing tecnical issues wtever is search jase12354 on facebook send as post will reply a soon as i can profile is v for vendette
Jason - Yanıt
You guys are using a total different kinda of PS4 I have .. My blu ray isn’t married to my motherboard .. And now I dont know how to fix this error ..
Betty Sales - Yanıt
So how do I marry a new disc drive with the original blue ray logic board??? Naturally to replace a functioning logic board when only the old warn out drive itself seems like a waste of $160.
Todd Ashelman - Yanıt
have a ps4 cannot get a part which is the disk detection sensor kld-003 can get kld-002 and kld-001 but cannot find find kld-003 anyone with the same problem.
stuart - Yanıt
I recently took apart my ps4 to replace the thermal paste and since putting it back together the drive will not eject via the button on the ps4 and will not accept a disc.
I can eject the disc via the on screen menu so there is power and I can also hear the drive churning away when I turn the unit on.
Any ideas?
J P - Yanıt
After I completed all the directions in reverse. For the drive to actually read a disc, I had to do an update. Now the eject button doesn't work. No clue what is wrong or how to fix it.
Kyle Roberts - Yanıt
Not sure if this is still updated, but I installed the new disk drive made sure all the cables are connected correctly and made sure it was the right type of drive, but now when i try and insert a disk it doesnt even seem to drag it in. Any help would be appreciated
dashiellsarnoff - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 86
Son 7 Gün: 654
Son 30 Gün: 3,214
Her zaman: 225,779
