Ana içeriğe geç
PlayStation 4 Slim Bottom Cover Replacement
Neye ihtiyacın var
  1. PlayStation 4 Slim Bottom Cover Replacement, Bottom Cover: adım 1, 3 resimden 1. PlayStation 4 Slim Bottom Cover Replacement, Bottom Cover: adım 1, 3 resimden 2. PlayStation 4 Slim Bottom Cover Replacement, Bottom Cover: adım 1, 3 resimden 3.
    • Locate the plastic warranty sticker next to the three ports on the side of the console.
    • Remove the warranty sticker by peeling it off with any kind of spudger.
    • Removing the warranty sticker will NOT cause your warranty to be null and void.
  2. PlayStation 4 Slim Bottom Cover Replacement: adım 2, 2 resimden 1. PlayStation 4 Slim Bottom Cover Replacement: adım 2, 2 resimden 2.
    • Unscrew and remove the now exposed 5.0mm screw using a TR8 security Torx screwdriver with a counter-clockwise motion.
  3. PlayStation 4 Slim Bottom Cover Replacement: adım 3, 3 resimden 1. PlayStation 4 Slim Bottom Cover Replacement: adım 3, 3 resimden 2. PlayStation 4 Slim Bottom Cover Replacement: adım 3, 3 resimden 3.
    • Place the Playstation 4 Slim upside down with the side of the screw you just removed facing you.
    • Pry up on the two corners that are facing you with your fingers.
    • This may take a bit of force to open up and you will hear a fairly loud click when the bottom cover detaches.
    • Remove the bottom cover by sliding it towards the back corners and lifting up.
Sonuç
45 farklı kişi bu kılavuzu tamamladı.
Hernan Rodriguez
4.082 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S19-G4, Livingston Winter 2018 Cal Poly, Team S19-G4, Livingston Winter 2018 üyesi
CPSU-LIVINGSTON-W18S19G4
4 Üyeler
35 adet Kılavuz yazıldı
2Kılavuz Yorumları
Wo kann man die Bodenplatte kaufen?
Emre Kaman - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 20
Son 7 gün: 209
Son 30 gün: 989
Her zaman: 57,649
