Ana içeriğe geç
PlayStation 4 Slim Optical Disc Drive Replacement
Neye ihtiyacın var
  1. PlayStation 4 Slim Optical Disc Drive Replacement, Bottom Cover: adım 1, 3 resimden 1. PlayStation 4 Slim Optical Disc Drive Replacement, Bottom Cover: adım 1, 3 resimden 2. PlayStation 4 Slim Optical Disc Drive Replacement, Bottom Cover: adım 1, 3 resimden 3.
    • Locate the plastic warranty sticker next to the three ports on the side of the console.
    • Remove the warranty sticker by peeling it off with any kind of spudger.
    • Removing the warranty sticker will NOT cause your warranty to be null and void.
    FixBot'a Sor
    Yorum Ekle
  2. PlayStation 4 Slim Optical Disc Drive Replacement: adım 2, 2 resimden 1. PlayStation 4 Slim Optical Disc Drive Replacement: adım 2, 2 resimden 2.
    • Unscrew and remove the now exposed 5.0mm screw using a TR8 security Torx screwdriver with a counter-clockwise motion.
    FixBot'a Sor
    Yorum Ekle
  3. PlayStation 4 Slim Optical Disc Drive Replacement: adım 3, 3 resimden 1. PlayStation 4 Slim Optical Disc Drive Replacement: adım 3, 3 resimden 2. PlayStation 4 Slim Optical Disc Drive Replacement: adım 3, 3 resimden 3.
    • Place the Playstation 4 Slim upside down with the side of the screw you just removed facing you.
    • Pry up on the two corners that are facing you with your fingers.
    • This may take a bit of force to open up and you will hear a fairly loud click when the bottom cover detaches.
    • Remove the bottom cover by sliding it towards the back corners and lifting up.
    FixBot'a Sor
    Yorum Ekle
  4. PlayStation 4 Slim Optical Disc Drive Replacement, Power Supply: adım 4, 3 resimden 1. PlayStation 4 Slim Optical Disc Drive Replacement, Power Supply: adım 4, 3 resimden 2. PlayStation 4 Slim Optical Disc Drive Replacement, Power Supply: adım 4, 3 resimden 3.
    • Place the Playstation 4 Slim right side up, with the PS logo on top and the side with the words "SONY" and "PS4" facing you.
    • This may take a bit of force to open and you will hear a fairly loud click when the top cover detaches.
    • Remove the top cover by sliding it towards the back corners and lifting up.
    FixBot'a Sor
    Yorum Ekle
  5. PlayStation 4 Slim Optical Disc Drive Replacement: adım 5, 3 resimden 1. PlayStation 4 Slim Optical Disc Drive Replacement: adım 5, 3 resimden 2. PlayStation 4 Slim Optical Disc Drive Replacement: adım 5, 3 resimden 3.
    • Unscrew and remove the two screws (left one 31.0mm and right one 24.0mm) using a T8 screwdriver with a counter-clockwise motion.
    • Unscrew and remove the 3.0mm screw using a Phillips #1 screwdriver with a counter-clockwise motion.
    FixBot'a Sor
    Yorum Ekle
  6. PlayStation 4 Slim Optical Disc Drive Replacement: adım 6, 1 resimden 1.
    • Remove the four 16mm Philips screws holding the power supply in place.
    FixBot'a Sor
    Yorum Ekle
  7. PlayStation 4 Slim Optical Disc Drive Replacement: adım 7, 2 resimden 1. PlayStation 4 Slim Optical Disc Drive Replacement: adım 7, 2 resimden 2.
    • Remove the metal sheet from the top of the power supply by grabbing and lifting up with your hands.
    FixBot'a Sor
    Yorum Ekle
  8. PlayStation 4 Slim Optical Disc Drive Replacement: adım 8, 2 resimden 1. PlayStation 4 Slim Optical Disc Drive Replacement: adım 8, 2 resimden 2.
    • Remove the antenna from the top of the power supply by guiding the wire with your fingers through the groves underneath the metal panel.
    FixBot'a Sor
    Yorum Ekle
  9. PlayStation 4 Slim Optical Disc Drive Replacement: adım 9, 2 resimden 1. PlayStation 4 Slim Optical Disc Drive Replacement: adım 9, 2 resimden 2.
    • Flip the Playstation 4 Slim onto its back.
    • Unscrew and remove the 4.0mm screw using a Phillips #1 screwdriver with a counter-clockwise motion. This screw holds the power supply in place
    FixBot'a Sor
    Yorum Ekle
  10. PlayStation 4 Slim Optical Disc Drive Replacement: adım 10, 3 resimden 1. PlayStation 4 Slim Optical Disc Drive Replacement: adım 10, 3 resimden 2. PlayStation 4 Slim Optical Disc Drive Replacement: adım 10, 3 resimden 3.
    • Use a plastic opening tool to make space between the power supply and console by wedging and wiggling it in-between the two.
    • Lift the power supply up and onto its back on the metal sheet using your hands.
    FixBot'a Sor
    Yorum Ekle
  11. PlayStation 4 Slim Optical Disc Drive Replacement: adım 11, 3 resimden 1. PlayStation 4 Slim Optical Disc Drive Replacement: adım 11, 3 resimden 2. PlayStation 4 Slim Optical Disc Drive Replacement: adım 11, 3 resimden 3.
    Bu adımda kullanılan alet:
    • Disconnect the wire connection from the power supply by firmly gripping it with your fingers or tweezers and pulling out.
    • Remove the power supply completely by grabbing and lifting up with your hands.
    FixBot'a Sor
    Yorum Ekle
  12. PlayStation 4 Slim Optical Disc Drive Replacement, Optical Disc Drive: adım 12, 2 resimden 1. PlayStation 4 Slim Optical Disc Drive Replacement, Optical Disc Drive: adım 12, 2 resimden 2.
    • Unscrew and remove the 31.0mm screw using a T8 screwdriver with a counter-clockwise motion.
    • Unscrew and remove the 10x 5.0mm screws using a Phillips #1 screwdriver with a counter-clockwise motion.
    FixBot'a Sor
    Yorum Ekle
    • If there are black plastic rivets in place of some screws, pull them out using pliers. They aren't necessary.
    FixBot'a Sor
    Yorum Ekle
  13. PlayStation 4 Slim Optical Disc Drive Replacement: adım 14, 2 resimden 1. PlayStation 4 Slim Optical Disc Drive Replacement: adım 14, 2 resimden 2.
    • Remove the metal plate by grabbing the edges and lifting up with your hands.
    FixBot'a Sor
    Yorum Ekle
  14. PlayStation 4 Slim Optical Disc Drive Replacement: adım 15, 2 resimden 1. PlayStation 4 Slim Optical Disc Drive Replacement: adım 15, 2 resimden 2.
    • Unscrew and remove the two 3.0mm screws using a PH000 screwdriver with a counter-clockwise motion.
    FixBot'a Sor
    Yorum Ekle
  15. PlayStation 4 Slim Optical Disc Drive Replacement: adım 16, 2 resimden 1. PlayStation 4 Slim Optical Disc Drive Replacement: adım 16, 2 resimden 2.
    • Remove the disk drive out by pinching on either side of the two black plastic "claws" and lifting up with your hand.
    • TIP: Before lifting the mechanism, note the white plastic rocker arm engaged with the center wheel. The underside of that rocker arm has a pin near the edge that engages with a slider mechanism underneath. When reassembling, you need to line this pin up again the same way.
    FixBot'a Sor
    Yorum Ekle
Sonuç
If you need to go deeper to fix your drive, see the comment section for suggestions.
121 farklı kişi bu kılavuzu tamamladı.
Hernan Rodriguez
4.910 İtibar
3 adet Kılavuz yazıldı
27Kılavuz Yorumları
incomplete guide, what replacement? the last step is taking the cover off but what about the disk drive?
Yegor Ilchuk - Yanıt Paylaş
its easy you need to take off the bottom cover and the black thingy
Albert Einstein - Yanıt Paylaş
Yeah, where's the ending to this?
Ben Baptist - Yanıt Paylaş
To remove the complete drive you have to remove the motherboard. with the motherboard removed some of the above steps may not be necessary.
This guide is useful if you just need to remove disc or clean laser.
Freddie Parsons - Yanıt Paylaş
when replacing do you have to swap a board like the PS4’s of the past?
Frank Ferrante - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 79
Son 7 gün: 500
Son 30 gün: 2,354
Her zaman: 233,103
