Ana içeriğe geç
PlayStation 4 Slim Power Supply Replacement
Neye ihtiyacın var
  1. PlayStation 4 Slim Power Supply Replacement, Bottom Cover: adım 1, 3 resimden 1. PlayStation 4 Slim Power Supply Replacement, Bottom Cover: adım 1, 3 resimden 2. PlayStation 4 Slim Power Supply Replacement, Bottom Cover: adım 1, 3 resimden 3.
    • Locate the plastic warranty sticker next to the three ports on the side of the console.
    • Remove the warranty sticker by peeling it off with any kind of spudger.
    • Removing the warranty sticker will NOT cause your warranty to be null and void.
  2. PlayStation 4 Slim Power Supply Replacement: adım 2, 2 resimden 1. PlayStation 4 Slim Power Supply Replacement: adım 2, 2 resimden 2.
    • Unscrew and remove the now exposed 5.0mm screw using a TR8 security Torx screwdriver with a counter-clockwise motion.
  3. PlayStation 4 Slim Power Supply Replacement: adım 3, 3 resimden 1. PlayStation 4 Slim Power Supply Replacement: adım 3, 3 resimden 2. PlayStation 4 Slim Power Supply Replacement: adım 3, 3 resimden 3.
    • Place the Playstation 4 Slim upside down with the side of the screw you just removed facing you.
    • Pry up on the two corners that are facing you with your fingers.
    • This may take a bit of force to open up and you will hear a fairly loud click when the bottom cover detaches.
    • Remove the bottom cover by sliding it towards the back corners and lifting up.
  4. PlayStation 4 Slim Power Supply Replacement, Power Supply: adım 4, 3 resimden 1. PlayStation 4 Slim Power Supply Replacement, Power Supply: adım 4, 3 resimden 2. PlayStation 4 Slim Power Supply Replacement, Power Supply: adım 4, 3 resimden 3.
    • Place the Playstation 4 Slim right side up, with the PS logo on top and the side with the words "SONY" and "PS4" facing you.
    • This may take a bit of force to open and you will hear a fairly loud click when the top cover detaches.
    • Remove the top cover by sliding it towards the back corners and lifting up.
  5. PlayStation 4 Slim Power Supply Replacement: adım 5, 3 resimden 1. PlayStation 4 Slim Power Supply Replacement: adım 5, 3 resimden 2. PlayStation 4 Slim Power Supply Replacement: adım 5, 3 resimden 3.
    • Unscrew and remove the two screws (left one 31.0mm and right one 24.0mm) using a T8 screwdriver with a counter-clockwise motion.
    • Unscrew and remove the 3.0mm screw using a Phillips #1 screwdriver with a counter-clockwise motion.
  6. PlayStation 4 Slim Power Supply Replacement: adım 6, 1 resimden 1.
    • Remove the four 16mm Philips screws holding the power supply in place.
  7. PlayStation 4 Slim Power Supply Replacement: adım 7, 2 resimden 1. PlayStation 4 Slim Power Supply Replacement: adım 7, 2 resimden 2.
    • Remove the metal sheet from the top of the power supply by grabbing and lifting up with your hands.
  8. PlayStation 4 Slim Power Supply Replacement: adım 8, 2 resimden 1. PlayStation 4 Slim Power Supply Replacement: adım 8, 2 resimden 2.
    • Remove the antenna from the top of the power supply by guiding the wire with your fingers through the groves underneath the metal panel.
  9. PlayStation 4 Slim Power Supply Replacement: adım 9, 2 resimden 1. PlayStation 4 Slim Power Supply Replacement: adım 9, 2 resimden 2.
    • Flip the Playstation 4 Slim onto its back.
    • Unscrew and remove the 4.0mm screw using a Phillips #1 screwdriver with a counter-clockwise motion.
  10. PlayStation 4 Slim Power Supply Replacement: adım 10, 3 resimden 1. PlayStation 4 Slim Power Supply Replacement: adım 10, 3 resimden 2. PlayStation 4 Slim Power Supply Replacement: adım 10, 3 resimden 3.
    • Use a plastic opening tool to make space between the power supply and console by wedging and wiggling it in-between the two.
    • Lift the power supply up and onto its back on the metal sheet using your hands.
  11. PlayStation 4 Slim Power Supply Replacement: adım 11, 3 resimden 1. PlayStation 4 Slim Power Supply Replacement: adım 11, 3 resimden 2. PlayStation 4 Slim Power Supply Replacement: adım 11, 3 resimden 3.
    Bu adımda kullanılan alet:
    • Disconnect the wire connection from the power supply by firmly gripping it with your fingers or tweezers and pulling out.
    • Remove the power supply completely by grabbing and lifting up with your hands.
Sonuç
82 farklı kişi bu kılavuzu tamamladı.
Hernan Rodriguez
4.094 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S19-G4, Livingston Winter 2018 Cal Poly, Team S19-G4, Livingston Winter 2018 üyesi
CPSU-LIVINGSTON-W18S19G4
4 Üyeler
35 adet Kılavuz yazıldı
8Kılavuz Yorumları
Can the N15-160P1A power supply work on a PS4 system that originally came with N17-160P1A?
derasky4u - Yanıt
My PS4 not turning on
Khai Stering - Yanıt
This was awesome. Thanks for the assist
Christopher Gorgon - Yanıt
I need help figuring out what I did to my ps4 and what needs replacement I had the new nba 2k 22 in the disc drive and the game was partly finished downloading so as it was doing that I brought shinobi striker which I previously had to use someone’s account to play it so the game popped up as light so I deleted it the first time and redownloaded it and it still said lite so then I deleted again but this time I double tapped the PlayStation button and it went to Home Screen slowed down then froze so I unplugged it plugged it back up and it wouldn’t turn on
Deontay - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 60
Son 7 gün: 322
Son 30 gün: 1,407
Her zaman: 109,261
