Ana içeriğe geç
Giriş
This guide will show you how to replace the thermal paste inside a PS4. Now you might wonder just what thermal paste is. Thermal paste is a silver liquid you apply to a processor to transfer heat to a cooling solution. You want to replace the thermal paste of any electronic every couple of years or so since the thermal paste will dry out. The thermal paste board is right under the heat sync, and the heat sync is where all the dust builds up. If you clean the heat sync and replace the thermal paste, your PS4 will be working as if it was brand new. My PS4 is about six years old, and after doing this whole procedure, it never overheats anymore and is as quiet as a mouse. The only skills required for this task is you have to be able to screw and unscrew screws. It is a very easy, but it is a tedious process, so pick a day that you are free if you are going to do this.
  1. Grip the PS4 with both hands along the gap in the top cover. Push the glossy side of the top cover with your thumbs until it pops to the side. Lift the glossy top cover up and back to remove it from the PS4.
    • Grip the PS4 with both hands along the gap in the top cover.
    • Push the glossy side of the top cover with your thumbs until it pops to the side.
    • Lift the glossy top cover up and back to remove it from the PS4.
  2. Remove the 6.5 mm Phillips screw securing the hard drive bracket to the enclosure. Remove the 6.5 mm Phillips screw securing the hard drive bracket to the enclosure.
    • Remove the 6.5 mm Phillips screw securing the hard drive bracket to the enclosure.
  3. Pull the hard drive bracket out of the enclosure. Be careful not to drop the hard drive. The internal components are fragile and are susceptible to damage by sudden shock. Be careful not to drop the hard drive. The internal components are fragile and are susceptible to damage by sudden shock.
    • Pull the hard drive bracket out of the enclosure.
    • Be careful not to drop the hard drive. The internal components are fragile and are susceptible to damage by sudden shock.
  4. Flip the PS4 upside-down with the back side facing towards you.
    • Flip the PS4 upside-down with the back side facing towards you.
  5. Use tweezers to remove the two stickers in the center of the back of the PS4 exposing two case screws. Use tweezers to remove the two stickers in the center of the back of the PS4 exposing two case screws. Use tweezers to remove the two stickers in the center of the back of the PS4 exposing two case screws.
    • Use tweezers to remove the two stickers in the center of the back of the PS4 exposing two case screws.
  6. Use tweezers to carefully remove the plastic screw covers in each corner, exposing two more case screws. Use tweezers to carefully remove the plastic screw covers in each corner, exposing two more case screws.
    • Use tweezers to carefully remove the plastic screw covers in each corner, exposing two more case screws.
  7. Remove the four 7.2 mm Torx security screws on the back of the PS4. Remove the four 7.2 mm Torx security screws on the back of the PS4.
    • Remove the four 7.2 mm Torx security screws on the back of the PS4.
  8. Use your thumbs to lift the lower case up and off the PS4. The lower case is held into place by plastic clips. You may need to use significant force to release the lower case.
    • Use your thumbs to lift the lower case up and off the PS4.
    • The lower case is held into place by plastic clips. You may need to use significant force to release the lower case.
  9. Use a pair of tweezers to pull the power supply cable straight out and disconnect the power supply unit from the motherboard. Use a pair of tweezers to pull the power supply cable straight out and disconnect the power supply unit from the motherboard.
    • Use a pair of tweezers to pull the power supply cable straight out and disconnect the power supply unit from the motherboard.
  10. Remove three 9.7 mm Torx security screws. Remove two 41 mm Phillips screws and brackets.
    • Remove three 9.7 mm Torx security screws.
    • Remove two 41 mm Phillips screws and brackets.
  11. Lift the power supply straight up and out of the PS4. The power supply is held firmly in place by prongs on the left side. It may take multiple attempts to get it free. During reassembly, ensure the prongs are aligned, then press the power supply into place.
    • Lift the power supply straight up and out of the PS4.
    • The power supply is held firmly in place by prongs on the left side. It may take multiple attempts to get it free.
    • During reassembly, ensure the prongs are aligned, then press the power supply into place.
    why is this so hard to take out? I keep pulling on it but the left side is stuck….
    Morphitol - Yanıt
    It’s because of the metal prongs, unfortunately there’s no trick to make it easy to get out. Try different ways of gripping it to get more force.
    Sam Omiotek -
  12. Use the tip of a spudger to disconnect the antenna cable from the motherboard. Use the tip of a spudger to disconnect the antenna cable from the motherboard.
    • Use the tip of a spudger to disconnect the antenna cable from the motherboard.
  13. Use a pair of tweezers or your fingers to grab the antenna cable and move it out from the cable guides. Use a pair of tweezers or your fingers to grab the antenna cable and move it out from the cable guides. Use a pair of tweezers or your fingers to grab the antenna cable and move it out from the cable guides.
    • Use a pair of tweezers or your fingers to grab the antenna cable and move it out from the cable guides.
  14. Use a pair of tweezers or your fingers to thread the antenna cable out from underneath the optical drive cable. Use a pair of tweezers or your fingers to thread the antenna cable out from underneath the optical drive cable. Use a pair of tweezers or your fingers to thread the antenna cable out from underneath the optical drive cable.
    • Use a pair of tweezers or your fingers to thread the antenna cable out from underneath the optical drive cable.
  15. Remove the 9.7 mm Torx security screw securing the antenna. Remove the 9.7 mm Torx security screw securing the antenna.
    • Remove the 9.7 mm Torx security screw securing the antenna.
  16. Remove the Wi-Fi antenna. Remove the Wi-Fi antenna.
    • Remove the Wi-Fi antenna.
  17. Use your fingernail to press down on the metal release lever of the ribbon cable on top of the optical drive. Use your fingers or a pair of tweezers to disconnect the ribbon cable by pulling on the black tab. You do not need to press the metal lever when inserting the ribbon cable back in. You will hear a click once it is fully inserted.
    • Use your fingernail to press down on the metal release lever of the ribbon cable on top of the optical drive.
    • Use your fingers or a pair of tweezers to disconnect the ribbon cable by pulling on the black tab.
    • You do not need to press the metal lever when inserting the ribbon cable back in. You will hear a click once it is fully inserted.
    Please note that the younger generations of PS4 have a different setup of connectors to the driver, its sometimes 3 of these as presented but with different sizes and no pad to press down. However, dont be alarmed, just use the pair of tweezers and gently pull them off the connectors of the motherboard. Grab on tight on the blue area of the ribbon cable and pull gently! They tend to sit tight so take some time and patience on this.
    Mathias Kopp - Yanıt
  18. Use your fingernail to press down the metal release lever for the ribbon cable connected to the motherboard. Use your fingers or a pair of tweezers to disconnect the ribbon cable by pulling on the black tab. Set the ribbon cable aside for reassembly.
    • Use your fingernail to press down the metal release lever for the ribbon cable connected to the motherboard.
    • Set the ribbon cable aside for reassembly.
  19. Use your fingers or a pair of tweezers to disconnect the optical drive cable from the motherboard. Use your fingers or a pair of tweezers to disconnect the optical drive cable from the motherboard.
    • Use your fingers or a pair of tweezers to disconnect the optical drive cable from the motherboard.
  20. Use your fingers or a pair of tweezers to remove the optical drive cable from the cable guides that hold it in place. Use your fingers or a pair of tweezers to remove the optical drive cable from the cable guides that hold it in place. Use your fingers or a pair of tweezers to remove the optical drive cable from the cable guides that hold it in place.
    • Use your fingers or a pair of tweezers to remove the optical drive cable from the cable guides that hold it in place.
  21. Remove the four screws securing the optical drive. Three 9.7 mm Torx screws
    • Remove the four screws securing the optical drive.
    • Three 9.7 mm Torx screws
    • One 6.2 mm Phillips screw
  22. Lift the optical drive straight up and out of the PS4. Lift the optical drive straight up and out of the PS4.
    • Lift the optical drive straight up and out of the PS4.
  23. Remove the two 9.7 mm Torx screws securing the upper case. Remove the two 9.7 mm Torx screws securing the upper case.
    • Remove the two 9.7 mm Torx screws securing the upper case.
  24. Lift the upper case up and back to remove it from the PS4. The upper case in held in place by plastic tabs on the front side. It will take significant force to separate them. The upper case in held in place by plastic tabs on the front side. It will take significant force to separate them.
    • Lift the upper case up and back to remove it from the PS4.
    • The upper case in held in place by plastic tabs on the front side. It will take significant force to separate them.
    “Significant force” is a bit of an understatement. It’s like it’s superglued together..
    Wouter Rietberg - Yanıt
  25. Remove the twelve 9.7 mm Torx screws securing the upper EMI shield. Remove the twelve 9.7 mm Torx screws securing the upper EMI shield.
    • Remove the twelve 9.7 mm Torx screws securing the upper EMI shield.
    In my PS4, there is a small black Philips screw behind where the power lead connects to the motherboard. That screw connects the EMI shield to the inner metal where the power supply sits.
  26. This step shows you how to properly unscrew the pressure plate. Remove the two 15.6 mm Phillips screws. Gradually unscrew the pressure plate by turning each screw one half turn at a time.
    • This step shows you how to properly unscrew the pressure plate.
    • Remove the two 15.6 mm Phillips screws.
    • Gradually unscrew the pressure plate by turning each screw one half turn at a time.
    • Alternate between the two screws to maintain even pressure on the pressure plate.
    • Do not unscrew one side completely before unscrewing the other side or you may damage the processor.
    why does my PS4 have some metal thing attaching the plate to the metal beneath it?
    Morphitol - Yanıt
    My PS4 also has 2 metal rings around each screw hole and 4 metal pieces 2 on each side closing in the same shape as the pressure plate as you take the pressure plate off?
    Geoff King - Yanıt
  27. Remove the pressure plate.
    • Remove the pressure plate.
  28. Remove the upper EMI shield. Remove the upper EMI shield.
    • Remove the upper EMI shield.
    This is the 2nd PS4 I have disassembled and on both units I have found there is a black Phillips screw securing the upper EMI shield. This should be mentioned in the teardown as the EMI shield cannot be removed completely without first removing this screw and you risk damaging the EMI shield in the process . To locate the screw turn the unit over and you will see a small black Phillips screw located near the power supply prongs. There will be a set of arrows pointing to the screw. Once you remove this screw then you can fully release the upper EMI shield.
    Geoff King - Yanıt
    Ditto. This is my first time disassembling a PS4. EMI shield didn’t lift off easily on one corner. Noticed the black Phillips screw holding it in place. I scrolled up in the tutorial to see if I missed it. Easy enough.
    Kwan Park Tom - Yanıt
  29. Insert the flat end of a spudger in between the fan cable and the motherboard. Twist the spudger to lift the connector straight up and disconnect it from the motherboard.
    • Insert the flat end of a spudger in between the fan cable and the motherboard.
    • Twist the spudger to lift the connector straight up and disconnect it from the motherboard.
  30. Grab the edge of the motherboard on the front of the PS4. Lift the motherboard until the USB ports clear the PS4 case.
    • Grab the edge of the motherboard on the front of the PS4.
    • Lift the motherboard until the USB ports clear the PS4 case.
  31. Lift the motherboard out from the PS4. Apply a new layer of thermal paste to the processor before installing a motherboard using this guide. Failure to properly install new thermal paste will cause your PS4 to overheat.
    • Lift the motherboard out from the PS4.
    • Apply a new layer of thermal paste to the processor before installing a motherboard using this guide.
    • Failure to properly install new thermal paste will cause your PS4 to overheat.
    • Insert the I/O side of the Motherboard in first, then lower the other side in.
  32. Using a tissue paper, wipe off the existing thermal paste. Take your new thermal paste and apply a small amount in the middle of the component. Make sure you have cleaned off the thermal paste on both ends. Make sure you have cleaned off the thermal paste on both ends.
    • Using a tissue paper, wipe off the existing thermal paste. Take your new thermal paste and apply a small amount in the middle of the component.
    • Make sure you have cleaned off the thermal paste on both ends.
Sonuç
27 farklı kişi bu kılavuzu tamamladı.
Alyasin Hossain
729 İtibar
1 Kılavuz yazıldı
Takım
Bir Yorum
Se me hizo muy buena la guia, sobre todo para no cometer algun error al trabajar en la reparacion, mi PS4 dejo de zumbar el abanico con el cambio de pasta termica y una limpieza general de polvo y pelusa.
Luis Garcia - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 108
Son 7 gün: 777
Son 30 gün: 2,924
Her zaman: 13,460
