Ana içeriğe geç
Fix Your Stuff
Right to Repair
Parts & Tools
Giriş
If your controllers no longer work from long distances you might have a broken WiFi antenna.
Be aware that any replacement or teardown beyond the hard drive voids the Sony warranty.
*You are using this guide at your own risk. TronicsFix take no responsibility and will not be held liable for any damages that may occur while using this guide.
  1. Using a dental pick or something similar, remove the three stickers on the bottom casing. Using a dental pick or something similar, remove the three stickers on the bottom casing. Using a dental pick or something similar, remove the three stickers on the bottom casing.
    • Using a dental pick or something similar, remove the three stickers on the bottom casing.
  2. Remove the three black screws in the bottom case using a T9 security torx bit. Remove the three black screws in the bottom case using a T9 security torx bit.
    • Remove the three black screws in the bottom case using a T9 security torx bit.
  3. Pull up on one side of the case, then the other then slide the case back. It will then be free from the rest of the console. Pull up on one side of the case, then the other then slide the case back. It will then be free from the rest of the console. Pull up on one side of the case, then the other then slide the case back. It will then be free from the rest of the console.
    • Pull up on one side of the case, then the other then slide the case back. It will then be free from the rest of the console.
  4. Remove the five screws that secure the power supply. There are two PH1 and three T9 torx security screws. Remove the five screws that secure the power supply. There are two PH1 and three T9 torx security screws. Remove the five screws that secure the power supply. There are two PH1 and three T9 torx security screws.
    • Remove the five screws that secure the power supply. There are two PH1 and three T9 torx security screws.
  5. First pull up on one side of the power supply, then pull up on the other side. Gently but firmly wiggle it out. Be careful as you pull up on the power supply as it is still connected with a connector from the motherboard. Be careful as you pull up on the power supply as it is still connected with a connector from the motherboard.
    • First pull up on one side of the power supply, then pull up on the other side. Gently but firmly wiggle it out.
    • Be careful as you pull up on the power supply as it is still connected with a connector from the motherboard.
  6. The power supply can lifted out and rotated down and set on the workbench. Be very careful not to pull on the power supply as it will still be connected to the motherboard. Use ESD-safe tweezers to carefully disconnect the wi-fi antenna by pulling it straight up.
    • The power supply can lifted out and rotated down and set on the workbench.
    • Be very careful not to pull on the power supply as it will still be connected to the motherboard.
    • Use ESD-safe tweezers to carefully disconnect the wi-fi antenna by pulling it straight up.
    • Be be careful not to apply too much force on the WiFi connector as it can break off.
    • After the WiFi cable is disconnected, de-route the cable from the two clips and under the optical drive cable.
  7. Remove the one torx T9 security screw from the WiFi antenna located at the front of the console. The WiFi Antenna can now be fully removed from the PS4. The WiFi Antenna can now be fully removed from the PS4.
    • Remove the one torx T9 security screw from the WiFi antenna located at the front of the console.
    • The WiFi Antenna can now be fully removed from the PS4.
Sonuç
Be sure to route the WiFi antenna cable the same way as it was routed before disassembly. Then take a break and have some ice cream!
68 farklı kişi bu kılavuzu tamamladı.
TronicsFix
31.278 İtibar
5 adet Kılavuz yazıldı
Takım
TronicsFix TronicsFix üyesi
Business
1 Üye
22 adet Kılavuz yazıldı
94 Yorum
Took me about 10mins with this guide. Super easy. New parts in and working wonderfully. Ty ifixit!
luckycha87 - Yanıt
My wireless controlers wasn't recognised. I change the WiFi connector but this problem is not resoleved yet.
Frederic Morelli - Yanıt
Hi Frederic! Have you tried resetting the controller? Have you tried any other controllers to see if they work? Also, are you sure the battery in your controller is good and it's charged up?
TronicsFix -
Hello my controller has a hard time working from 4 feet away from my console and disconnecting. Im thinking of doing this hopefully it works. Is the bluetooth and wifi part the same thing because my wifi doesnt seem to pick up my wireless router.
ludracing - Yanıt
Yes, the wifi and bluetooth antenna is the same.
TronicsFix -
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 33
Son 7 gün: 321
Son 30 gün: 1,525
Her zaman: 86,097
