Ana içeriğe geç
PlayStation Classic Controller Port Replacement
Neye ihtiyacın var
  1. PlayStation Classic Controller Port Replacement, Motherboard: adım 1, 1 resimden 1.
    • Flip the console so its back is facing up.
  2. PlayStation Classic Controller Port Replacement: adım 2, 1 resimden 1.
    • Remove the five 3mm screws using the Phillips #00 screwdriver.
    • Make sure to keep your screws together in a secure location to avoid misplacement.
  3. PlayStation Classic Controller Port Replacement: adım 3, 3 resimden 1. PlayStation Classic Controller Port Replacement: adım 3, 3 resimden 2. PlayStation Classic Controller Port Replacement: adım 3, 3 resimden 3.
    • Remove the back plate from the rest of the console using your hands or the Jimmy tool.
  4. PlayStation Classic Controller Port Replacement: adım 4, 1 resimden 1.
    • Unscrew the motherboard's five 3mm screws with the Phillips #00 screwdriver.
    • Be careful not to apply too much force. The motherboard is flimsy and easy to break.
    • Keep track of your screws once they are removed.
  5. PlayStation Classic Controller Port Replacement: adım 5, 3 resimden 1. PlayStation Classic Controller Port Replacement: adım 5, 3 resimden 2. PlayStation Classic Controller Port Replacement: adım 5, 3 resimden 3.
    • Carefully remove the motherboard from the the rest of the console using your hands or the Jimmy tool.
  6. PlayStation Classic Controller Port Replacement: adım 6, 3 resimden 1. PlayStation Classic Controller Port Replacement: adım 6, 3 resimden 2. PlayStation Classic Controller Port Replacement: adım 6, 3 resimden 3.
    • The motherboard is connected to its metal protective casing with sticky pads. No tools are required to remove it.
    • Pull the metal casing off the motherboard.
    • Remember to be gentle when handling the motherboard.
  7. PlayStation Classic Controller Port Replacement, Controller Port: adım 7, 2 resimden 1. PlayStation Classic Controller Port Replacement, Controller Port: adım 7, 2 resimden 2.
    • Identify the damaged or faulty controller port and simply use your fingers to remove.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Maxwell Webb
685 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S2-G8, Maness Spring 2019 Cal Poly, Team S2-G8, Maness Spring 2019 üyesi
CPSU-MANESS-S19S2G8
2 Üyeler
23 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 12
Son 30 gün: 51
Her zaman: 2,067
