Giriş
This will guide you through the replacement of your controller port.
Parçalar
Hiçbir parçaya gerek yok.
  1. Remove the parallel port cover on the back of the PlayStation.
    • Remove the parallel port cover on the back of the PlayStation.
  2. Flip over the PlayStation and remove the six screws from the bottom.
    • Flip over the PlayStation and remove the six screws from the bottom.
    • Turn the PlayStation upright. Remove the cover by lifting it up.
    • Remove the two screws securing the controller port to the case.
    • Gently disconnect the ribbon cable from the logic board. This is done by pulling on the blue area of the cable near the connector.
    • Remove and replace the controller port.
Sonuç
6 başka kişi bu kılavuzu tamamladı.
JakeDeschamps
1.047 İtibar
5 adet Kılavuz yazıldı
Takım
Cal Poly, Team 5-2, Regan Fall 2009 Cal Poly, Team 5-2, Regan Fall 2009 üyesi
CPSU-REGAN-F09S5G2
5 Üyeler
13 adet Kılavuz yazıldı
3 Yorum
I try replacing the controller and still wouldn't play memory cards.
redevil19 - Yanıt
I changed the controller port but the psx still doesn't recognize any controller. Both controller port and ribbon cable work perfect in other console. I wonder which components on the mother board are related with the controller ports so I can check them with a tester.
Daniel Prieto - Yanıt
I replaced the PS605 fuse and now the controllers work again! Thanks to this video https://www.youtube.com/watch?v=HdULot5F...
Daniel Prieto -
İstatistikleri Görüntüle:
Son 24 Saat: 6
Son 7 Gün: 22
Son 30 Gün: 125
Her zaman: 18,941
