Ana içeriğe geç
PlayStation Laser from a SCPH-7501 or SCPH-9001 Replacement
Arşivlenmiş Kılavuz
Bu kılavuz sadece arşivsel amaçlarla muhafaza edilmiştir. Onarımınızı gerçekleştirmek için kılavuzun güncel halini kullanın.
Neye ihtiyacın var
  1. PlayStation Laser from a SCPH-7501 or SCPH-9001 Replacement, Laser from a SCPH-7501: adım 1, 3 resimden 1. PlayStation Laser from a SCPH-7501 or SCPH-9001 Replacement, Laser from a SCPH-7501: adım 1, 3 resimden 2. PlayStation Laser from a SCPH-7501 or SCPH-9001 Replacement, Laser from a SCPH-7501: adım 1, 3 resimden 3.
    • Remove the parallel port cover on the back of the PlayStation.
    • Flip over the PlayStation and remove the six screws from the bottom.
    • Turn the PlayStation upright. Remove the cover by lifting it up.
  2. PlayStation Laser from a SCPH-7501 or SCPH-9001 Replacement: adım 2, 3 resimden 1. PlayStation Laser from a SCPH-7501 or SCPH-9001 Replacement: adım 2, 3 resimden 2. PlayStation Laser from a SCPH-7501 or SCPH-9001 Replacement: adım 2, 3 resimden 3.
    • Carefully disconnect the gold-colored ribbon cable from it's connector. To avoid damaging the cable, pull it by the white, reinforced tab.
  3. PlayStation Laser from a SCPH-7501 or SCPH-9001 Replacement: adım 3, 3 resimden 1. PlayStation Laser from a SCPH-7501 or SCPH-9001 Replacement: adım 3, 3 resimden 2. PlayStation Laser from a SCPH-7501 or SCPH-9001 Replacement: adım 3, 3 resimden 3.
    • Disconnect the second cable by pulling up on the plastic connector at the end.
    • Remove the 2 screws and take the black bottom piece of the old Optical drive.
    • Take the new Optical drive from either a SCPH-7501 or an SCPH-9001.
    • Gently pull on the orange ribbon, but not too much or you could rip it.
  4. PlayStation Laser from a SCPH-7501 or SCPH-9001 Replacement: adım 4, 1 resimden 1.
    • Take the bottom piece you took out and place it on the new Optical drive and screw it on the new drive.
  5. PlayStation Laser from a SCPH-7501 or SCPH-9001 Replacement: adım 5, 1 resimden 1.
    • Here is what your work should look like.
    • Put it back together, plug it in, turn it on and test it to see if it works.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Unchi
367 İtibar
2 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 8
Her zaman: 1,628
