Ana içeriğe geç
PlayStation Move Battery Replacement
Neye ihtiyacın var
  1. PlayStation Move  Battery Replacement, Battery: adım 1, 3 resimden 1. PlayStation Move  Battery Replacement, Battery: adım 1, 3 resimden 2. PlayStation Move  Battery Replacement, Battery: adım 1, 3 resimden 3.
    • Using a Phillips #0 screwdriver, remove the four 10mm screws located on the back of the device.
    FixBot'a Sor
    Yorum Ekle
  2. PlayStation Move  Battery Replacement: adım 2, 2 resimden 1. PlayStation Move  Battery Replacement: adım 2, 2 resimden 2.
    • Insert the plastic opening tool at the indent.
    • Gently use a forward and backward motion to safely pop open the cover.
    • Using your hands to further pull it apart.
    FixBot'a Sor
    Yorum Ekle
  3. PlayStation Move  Battery Replacement: adım 3, 2 resimden 1. PlayStation Move  Battery Replacement: adım 3, 2 resimden 2.
    • Once the device is opened, lift the battery out of the black plastic holder.
    • Carefully pull the battery out and ensure that it's wires are still connected to the inside.
    FixBot'a Sor
    Yorum Ekle
  4. PlayStation Move  Battery Replacement: adım 4, 3 resimden 1. PlayStation Move  Battery Replacement: adım 4, 3 resimden 2. PlayStation Move  Battery Replacement: adım 4, 3 resimden 3.
    • Using a Phillips head screwdriver, remove the 9mm screw located to the right of the battery, which is connected to the inner plastic frame.
    • Using the plastic opening tool carefully take out the grey cylindrical piece (vibrator) that is also attached to a wire.
    FixBot'a Sor
    Yorum Ekle
  5. PlayStation Move  Battery Replacement: adım 5, 2 resimden 1. PlayStation Move  Battery Replacement: adım 5, 2 resimden 2.
    • Gently pull out the small grey cylindrical piece (vibrator).
    • Removing this piece makes it easier to access the wire connection of the battery and remove it.
    FixBot'a Sor
    Yorum Ekle
  6. PlayStation Move  Battery Replacement: adım 6, 2 resimden 1. PlayStation Move  Battery Replacement: adım 6, 2 resimden 2.
    Bu adımda kullanılan alet:
    • Using tweezers, remove the small piece with a cylindrical top that is located to the left of the inner plastic frame.
    FixBot'a Sor
    Yorum Ekle
  7. PlayStation Move  Battery Replacement: adım 7, 3 resimden 1. PlayStation Move  Battery Replacement: adım 7, 3 resimden 2. PlayStation Move  Battery Replacement: adım 7, 3 resimden 3.
    • Using one hand to hold the device, and the other hand to squeeze the inner plastic frame.
    • Remove by squeezing the inner plastic frame, lift and pull it towards you.
    • While removing the frame, be extremely careful because it could damage the frame or the motherboard.
    FixBot'a Sor
    Yorum Ekle
  8. PlayStation Move  Battery Replacement: adım 8, 2 resimden 1. PlayStation Move  Battery Replacement: adım 8, 2 resimden 2.
    • Gently pull on the white piece connecting the battery and the connector.
    FixBot'a Sor
    Yorum Ekle
Sonuç
11 farklı kişi bu kılavuzu tamamladı.
Ekip
USF Tampa, Team 3-3, Passmore Fall 2016 USF Tampa, Team 3-3, Passmore Fall 2016 üyesi
USFT-PASSMORE-F16S3G3
4 Üyeler
10 adet Kılavuz yazıldı
5Kılavuz Yorumları
When putting the plastic battery rig back in on my second time doing this, I bent one of the little plastic pins that fits into a hole in the PCB. Definitely want to be careful with that. To make it a bit easier, I unscrewed the bottom port PCB part of the way so I could take the bottom plastic housing and put the plastic battery rig in straight. It made it a lot easier.
Burke Cates - Yanıt Paylaş
No need to take out the motor, just use sharp tweezers and grab the connector (NOT the wires) and with small wiggling pull it out. Worked for mine.
crus - Yanıt Paylaş
Worked great! Thanks for this. I did not need to take out the black battery / motor piece. Tweezers worked great to remove and install the battery cable
Harry Skigis - Yanıt Paylaş
Any recommended online / physical store to buy new batteries for this because ifixit doesn’t have them?
[deleted] - Yanıt Paylaş
Je suis pas capable de coupler les manettes et quand j essaie de l ouvrir la lumière ne reste pas allumée. Sa se peut tu que les batteries sont finis. Je viens de l acheter usager
Rachelle Tremblay - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 25
Son 30 gün: 125
Her zaman: 17,470
