Ana içeriğe geç
PlayStation Move LED Light Replacement
Neye ihtiyacın var
  1. PlayStation Move LED Light Replacement, Battery: adım 1, 3 resimden 1. PlayStation Move LED Light Replacement, Battery: adım 1, 3 resimden 2. PlayStation Move LED Light Replacement, Battery: adım 1, 3 resimden 3.
    • Using a Phillips #0 screwdriver, remove the four 10mm screws located on the back of the device.
    FixBot'a Sor
    Yorum Ekle
  2. PlayStation Move LED Light Replacement: adım 2, 2 resimden 1. PlayStation Move LED Light Replacement: adım 2, 2 resimden 2.
    • Insert the plastic opening tool at the indent.
    • Gently use a forward and backward motion to safely pop open the cover.
    • Using your hands to further pull it apart.
    FixBot'a Sor
    Yorum Ekle
  3. PlayStation Move LED Light Replacement: adım 3, 2 resimden 1. PlayStation Move LED Light Replacement: adım 3, 2 resimden 2.
    • Once the device is opened, lift the battery out of the black plastic holder.
    • Carefully pull the battery out and ensure that it's wires are still connected to the inside.
    FixBot'a Sor
    Yorum Ekle
  4. PlayStation Move LED Light Replacement: adım 4, 3 resimden 1. PlayStation Move LED Light Replacement: adım 4, 3 resimden 2. PlayStation Move LED Light Replacement: adım 4, 3 resimden 3.
    • Using a Phillips head screwdriver, remove the 9mm screw located to the right of the battery, which is connected to the inner plastic frame.
    • Using the plastic opening tool carefully take out the grey cylindrical piece (vibrator) that is also attached to a wire.
    FixBot'a Sor
    Yorum Ekle
  5. PlayStation Move LED Light Replacement: adım 5, 2 resimden 1. PlayStation Move LED Light Replacement: adım 5, 2 resimden 2.
    • Gently pull out the small grey cylindrical piece (vibrator).
    • Removing this piece makes it easier to access the wire connection of the battery and remove it.
    FixBot'a Sor
    Yorum Ekle
  6. PlayStation Move LED Light Replacement: adım 6, 2 resimden 1. PlayStation Move LED Light Replacement: adım 6, 2 resimden 2.
    Bu adımda kullanılan alet:
    • Using tweezers, remove the small piece with a cylindrical top that is located to the left of the inner plastic frame.
    FixBot'a Sor
    Yorum Ekle
  7. PlayStation Move LED Light Replacement: adım 7, 3 resimden 1. PlayStation Move LED Light Replacement: adım 7, 3 resimden 2. PlayStation Move LED Light Replacement: adım 7, 3 resimden 3.
    • Using one hand to hold the device, and the other hand to squeeze the inner plastic frame.
    • Remove by squeezing the inner plastic frame, lift and pull it towards you.
    • While removing the frame, be extremely careful because it could damage the frame or the motherboard.
    FixBot'a Sor
    Yorum Ekle
  8. PlayStation Move LED Light Replacement: adım 8, 2 resimden 1. PlayStation Move LED Light Replacement: adım 8, 2 resimden 2.
    • Gently pull on the white piece connecting the battery and the connector.
    FixBot'a Sor
    Yorum Ekle
  9. PlayStation Move LED Light Replacement, Motherboard: adım 9, 3 resimden 1. PlayStation Move LED Light Replacement, Motherboard: adım 9, 3 resimden 2. PlayStation Move LED Light Replacement, Motherboard: adım 9, 3 resimden 3.
    • Remove the five 1.2 mm screws from upper portion of the controller.
    • If you are replacing the trigger button, continue to step 13.
    FixBot'a Sor
    Yorum Ekle
  10. PlayStation Move LED Light Replacement: adım 10, 2 resimden 1. PlayStation Move LED Light Replacement: adım 10, 2 resimden 2.
    • Remove the two 1.2mm Phillips #1 screws.
    FixBot'a Sor
    Yorum Ekle
  11. PlayStation Move LED Light Replacement: adım 11, 3 resimden 1. PlayStation Move LED Light Replacement: adım 11, 3 resimden 2. PlayStation Move LED Light Replacement: adım 11, 3 resimden 3.
    • Cautiously remove the circular white piece at the top without removing the LED inside.
    FixBot'a Sor
    Yorum Ekle
  12. PlayStation Move LED Light Replacement: adım 12, 3 resimden 1. PlayStation Move LED Light Replacement: adım 12, 3 resimden 2. PlayStation Move LED Light Replacement: adım 12, 3 resimden 3.
    • Remove the blue strip that is connected to the trigger button from the motherboard.
    • Be careful to gently detach it from the motherboard. The strip may rip if too much strength is applied.
    FixBot'a Sor
    Yorum Ekle
  13. PlayStation Move LED Light Replacement: adım 13, 2 resimden 1. PlayStation Move LED Light Replacement: adım 13, 2 resimden 2.
    • Remove the trigger button from the controller.
    FixBot'a Sor
    Yorum Ekle
  14. PlayStation Move LED Light Replacement: adım 14, 3 resimden 1. PlayStation Move LED Light Replacement: adım 14, 3 resimden 2. PlayStation Move LED Light Replacement: adım 14, 3 resimden 3.
    • Remove the LED light by removing the white strip.
    • If you are replacing the LED light, continue to Step 17.
    FixBot'a Sor
    Yorum Ekle
  15. PlayStation Move LED Light Replacement: adım 15, 2 resimden 1. PlayStation Move LED Light Replacement: adım 15, 2 resimden 2.
    • Remove the motherboard from the plastic case.
    FixBot'a Sor
    Yorum Ekle
  16. PlayStation Move LED Light Replacement, LED Light: adım 16, 2 resimden 1. PlayStation Move LED Light Replacement, LED Light: adım 16, 2 resimden 2.
    • Insert tweezers between the LED case and the LED clear plastic cover.
    • Lift the edge of the LED clear cover clip to be able to remove the cover.
    • Repeat the previous step to the other side.
    • Remove the LED cover.
    FixBot'a Sor
    Yorum Ekle
  17. PlayStation Move LED Light Replacement: adım 17, 2 resimden 1. PlayStation Move LED Light Replacement: adım 17, 2 resimden 2.
    • Remove the LED board using a blue opening tool to lift the board.
    • After the board is loose, remove the LED board.
    FixBot'a Sor
    Yorum Ekle
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Maritza Martinez
155 İtibar
1 Kılavuz yazıldı
Ekip
USF Tampa, Team 3-3, Passmore Fall 2016 USF Tampa, Team 3-3, Passmore Fall 2016 üyesi
USFT-PASSMORE-F16S3G3
4 Üyeler
10 adet Kılavuz yazıldı
5Kılavuz Yorumları
Okay, going to try this. Do I have to solder the white strip back onto the board?
randallrigdonjr - Yanıt Paylaş
did you ever get this done? need to know the same.
[deleted] - Yanıt Paylaş
très clair, mais où trouver une led ? et en enlevant le cable de la led, il faut le dessourder, non ?
Pierrot - Yanıt Paylaş
This is BEYOND useless without the information as to where to get the LED unit itself. It's not a standard LED board I can find anywhere.
Also, on the PS3 Move controller the cable from the main board to the LED is soldered both ends and doesn't simply lift away from the circuit.
As to the "beyond useless" comment, this isn't meant to be directed towards the kind people who have spent their time to help others with their knowledge and, their LED cable may have simply lifted away from the board if the Move controller was the later PS4 model, I don't know, I haven't pulled a PS4 Move controller apart (yet).
The guide however would be so much better with that one tiny bit of information, where can I find the LED module and the 1039 number on the LED board itself is of no help in my search.
I stripped my controller down before I found the link to this article (qualifications in electronics), my main need is identifying the faulty LED module so I can replace it.
Leo Anon - Yanıt Paylaş
Sorry, how do I reconnect the white cable I've just cut away from the circuit board solder joints as you've done?
Butchers!
SERIOUSLY??
No, I'm NOT stupid enough to cut cables and magically think they reconnect using the reverse disassembly instructions as suggested (just poke them in like a magician and they magically connect themselves, if only). Someone needs to rethink their idea of an article to "HELP" people.
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 11
Son 30 gün: 70
Her zaman: 5,559
