Ana içeriğe geç
PlayStation Move Motherboard Replacement
Neye ihtiyacın var
  1. PlayStation Move Motherboard Replacement, Battery: adım 1, 3 resimden 1. PlayStation Move Motherboard Replacement, Battery: adım 1, 3 resimden 2. PlayStation Move Motherboard Replacement, Battery: adım 1, 3 resimden 3.
    • Using a Phillips #0 screwdriver, remove the four 10mm screws located on the back of the device.
  2. PlayStation Move Motherboard Replacement: adım 2, 2 resimden 1. PlayStation Move Motherboard Replacement: adım 2, 2 resimden 2.
    • Insert the plastic opening tool at the indent.
    • Gently use a forward and backward motion to safely pop open the cover.
    • Using your hands to further pull it apart.
  3. PlayStation Move Motherboard Replacement: adım 3, 2 resimden 1. PlayStation Move Motherboard Replacement: adım 3, 2 resimden 2.
    • Once the device is opened, lift the battery out of the black plastic holder.
    • Carefully pull the battery out and ensure that it's wires are still connected to the inside.
    You can disconnect the back/trigger assembly ribbon cable at this point by proceeding to Steps 13/14 (without the other steps for disassembly as they are unnecessary for replacing just the trigger).
    Peter Miller - Yanıt
  4. PlayStation Move Motherboard Replacement: adım 4, 3 resimden 1. PlayStation Move Motherboard Replacement: adım 4, 3 resimden 2. PlayStation Move Motherboard Replacement: adım 4, 3 resimden 3.
    • Using a Phillips head screwdriver, remove the 9mm screw located to the right of the battery, which is connected to the inner plastic frame.
    • Using the plastic opening tool carefully take out the grey cylindrical piece (vibrator) that is also attached to a wire.
  5. PlayStation Move Motherboard Replacement: adım 5, 2 resimden 1. PlayStation Move Motherboard Replacement: adım 5, 2 resimden 2.
    • Gently pull out the small grey cylindrical piece (vibrator).
    • Removing this piece makes it easier to access the wire connection of the battery and remove it.
  6. PlayStation Move Motherboard Replacement: adım 6, 2 resimden 1. PlayStation Move Motherboard Replacement: adım 6, 2 resimden 2.
    • Using tweezers, remove the small piece with a cylindrical top that is located to the left of the inner plastic frame.
  7. PlayStation Move Motherboard Replacement: adım 7, 3 resimden 1. PlayStation Move Motherboard Replacement: adım 7, 3 resimden 2. PlayStation Move Motherboard Replacement: adım 7, 3 resimden 3.
    • Using one hand to hold the device, and the other hand to squeeze the inner plastic frame.
    • Remove by squeezing the inner plastic frame, lift and pull it towards you.
    • While removing the frame, be extremely careful because it could damage the frame or the motherboard.
  8. PlayStation Move Motherboard Replacement: adım 8, 2 resimden 1. PlayStation Move Motherboard Replacement: adım 8, 2 resimden 2.
    • Gently pull on the white piece connecting the battery and the connector.
  9. PlayStation Move Motherboard Replacement, Motherboard: adım 9, 3 resimden 1. PlayStation Move Motherboard Replacement, Motherboard: adım 9, 3 resimden 2. PlayStation Move Motherboard Replacement, Motherboard: adım 9, 3 resimden 3.
    • Remove the five 1.2 mm screws from upper portion of the controller.
    • If you are replacing the trigger button, continue to step 13.
  10. PlayStation Move Motherboard Replacement: adım 10, 2 resimden 1. PlayStation Move Motherboard Replacement: adım 10, 2 resimden 2.
    • Remove the two 1.2mm Phillips #1 screws.
  11. PlayStation Move Motherboard Replacement: adım 11, 3 resimden 1. PlayStation Move Motherboard Replacement: adım 11, 3 resimden 2. PlayStation Move Motherboard Replacement: adım 11, 3 resimden 3.
    • Cautiously remove the circular white piece at the top without removing the LED inside.
    Accidentally ripped this off as my PS Move is a different model, any chance this could be fixed using like jumper wires or not?
    Alex Flint - Yanıt
  12. PlayStation Move Motherboard Replacement: adım 12, 3 resimden 1. PlayStation Move Motherboard Replacement: adım 12, 3 resimden 2. PlayStation Move Motherboard Replacement: adım 12, 3 resimden 3.
    • Remove the blue strip that is connected to the trigger button from the motherboard.
    • Be careful to gently detach it from the motherboard. The strip may rip if too much strength is applied.
  13. PlayStation Move Motherboard Replacement: adım 13, 2 resimden 1. PlayStation Move Motherboard Replacement: adım 13, 2 resimden 2.
    • Remove the trigger button from the controller.
  14. PlayStation Move Motherboard Replacement: adım 14, 3 resimden 1. PlayStation Move Motherboard Replacement: adım 14, 3 resimden 2. PlayStation Move Motherboard Replacement: adım 14, 3 resimden 3.
    • Remove the LED light by removing the white strip.
    • If you are replacing the LED light, continue to Step 17.
    This step is destructive and simply breaks the LED solder joints!!!
    WTF, you literally broke the soldered ribbon cable.
    fastasleep - Yanıt
  15. PlayStation Move Motherboard Replacement: adım 15, 2 resimden 1. PlayStation Move Motherboard Replacement: adım 15, 2 resimden 2.
    • Remove the motherboard from the plastic case.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Destiny Jenkins
157 İtibar
1 Kılavuz yazıldı
Ekip
USF Tampa, Team 3-3, Passmore Fall 2016 USF Tampa, Team 3-3, Passmore Fall 2016 üyesi
USFT-PASSMORE-F16S3G3
4 Üyeler
8 adet Kılavuz yazıldı
2 Yorum
Where does one obtain a replacement motherboard?
Tekkromancer - Yanıt
my controllers are also dying anyone know where to get a replacement board? I live in Canada
Jin - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 16
Her zaman: 1,565
