Ana içeriğe geç
PlayStation Move Trigger Button Replacement
Neye ihtiyacın var
    1. PlayStation Move Trigger Button Replacement, Battery: adım 1, 3 resimden 1. PlayStation Move Trigger Button Replacement, Battery: adım 1, 3 resimden 2. PlayStation Move Trigger Button Replacement, Battery: adım 1, 3 resimden 3.
      • Using a Phillips #0 screwdriver, remove the four 10mm screws located on the back of the device.
      FixBot'a Sor
      Yorum Ekle
    2. PlayStation Move Trigger Button Replacement: adım 2, 2 resimden 1. PlayStation Move Trigger Button Replacement: adım 2, 2 resimden 2.
      • Insert the plastic opening tool at the indent.
      • Gently use a forward and backward motion to safely pop open the cover.
      • Using your hands to further pull it apart.
      FixBot'a Sor
      Yorum Ekle
    3. PlayStation Move Trigger Button Replacement: adım 3, 2 resimden 1. PlayStation Move Trigger Button Replacement: adım 3, 2 resimden 2.
      • Once the device is opened, lift the battery out of the black plastic holder.
      • Carefully pull the battery out and ensure that it's wires are still connected to the inside.
      FixBot'a Sor
      Yorum Ekle
    4. PlayStation Move Trigger Button Replacement: adım 4, 3 resimden 1. PlayStation Move Trigger Button Replacement: adım 4, 3 resimden 2. PlayStation Move Trigger Button Replacement: adım 4, 3 resimden 3.
      • Using a Phillips head screwdriver, remove the 9mm screw located to the right of the battery, which is connected to the inner plastic frame.
      • Using the plastic opening tool carefully take out the grey cylindrical piece (vibrator) that is also attached to a wire.
      FixBot'a Sor
      Yorum Ekle
    5. PlayStation Move Trigger Button Replacement: adım 5, 2 resimden 1. PlayStation Move Trigger Button Replacement: adım 5, 2 resimden 2.
      • Gently pull out the small grey cylindrical piece (vibrator).
      • Removing this piece makes it easier to access the wire connection of the battery and remove it.
      FixBot'a Sor
      Yorum Ekle
    6. PlayStation Move Trigger Button Replacement: adım 6, 2 resimden 1. PlayStation Move Trigger Button Replacement: adım 6, 2 resimden 2.
      Bu adımda kullanılan alet:
      • Using tweezers, remove the small piece with a cylindrical top that is located to the left of the inner plastic frame.
      FixBot'a Sor
      Yorum Ekle
    7. PlayStation Move Trigger Button Replacement: adım 7, 3 resimden 1. PlayStation Move Trigger Button Replacement: adım 7, 3 resimden 2. PlayStation Move Trigger Button Replacement: adım 7, 3 resimden 3.
      • Using one hand to hold the device, and the other hand to squeeze the inner plastic frame.
      • Remove by squeezing the inner plastic frame, lift and pull it towards you.
      • While removing the frame, be extremely careful because it could damage the frame or the motherboard.
      FixBot'a Sor
      Yorum Ekle
    8. PlayStation Move Trigger Button Replacement: adım 8, 2 resimden 1. PlayStation Move Trigger Button Replacement: adım 8, 2 resimden 2.
      • Gently pull on the white piece connecting the battery and the connector.
      FixBot'a Sor
      Yorum Ekle
    1. PlayStation Move Trigger Button Replacement, Motherboard: adım 9, 3 resimden 1. PlayStation Move Trigger Button Replacement, Motherboard: adım 9, 3 resimden 2. PlayStation Move Trigger Button Replacement, Motherboard: adım 9, 3 resimden 3.
      • Remove the five 1.2 mm screws from upper portion of the controller.
      • If you are replacing the trigger button, continue to step 13.
      FixBot'a Sor
      Yorum Ekle
    2. PlayStation Move Trigger Button Replacement: adım 10, 2 resimden 1. PlayStation Move Trigger Button Replacement: adım 10, 2 resimden 2.
      • Remove the two 1.2mm Phillips #1 screws.
      FixBot'a Sor
      Yorum Ekle
    3. PlayStation Move Trigger Button Replacement: adım 11, 3 resimden 1. PlayStation Move Trigger Button Replacement: adım 11, 3 resimden 2. PlayStation Move Trigger Button Replacement: adım 11, 3 resimden 3.
      • Cautiously remove the circular white piece at the top without removing the LED inside.
      FixBot'a Sor
      Yorum Ekle
    4. PlayStation Move Trigger Button Replacement: adım 12, 3 resimden 1. PlayStation Move Trigger Button Replacement: adım 12, 3 resimden 2. PlayStation Move Trigger Button Replacement: adım 12, 3 resimden 3.
      • Remove the blue strip that is connected to the trigger button from the motherboard.
      • Be careful to gently detach it from the motherboard. The strip may rip if too much strength is applied.
      FixBot'a Sor
      Yorum Ekle
    5. PlayStation Move Trigger Button Replacement: adım 13, 2 resimden 1. PlayStation Move Trigger Button Replacement: adım 13, 2 resimden 2.
      • Remove the trigger button from the controller.
      FixBot'a Sor
      Yorum Ekle
    6. PlayStation Move Trigger Button Replacement: adım 14, 3 resimden 1. PlayStation Move Trigger Button Replacement: adım 14, 3 resimden 2. PlayStation Move Trigger Button Replacement: adım 14, 3 resimden 3.
      • Remove the LED light by removing the white strip.
      • If you are replacing the LED light, continue to Step 17.
      FixBot'a Sor
      Yorum Ekle
    7. PlayStation Move Trigger Button Replacement: adım 15, 2 resimden 1. PlayStation Move Trigger Button Replacement: adım 15, 2 resimden 2.
      • Remove the motherboard from the plastic case.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Abdulaziz Refaei
183 İtibar
1 Kılavuz yazıldı
Ekip
USF Tampa, Team 3-3, Passmore Fall 2016 USF Tampa, Team 3-3, Passmore Fall 2016 üyesi
USFT-PASSMORE-F16S3G3
4 Üyeler
48 adet Kılavuz yazıldı
3Kılavuz Yorumları
This disassembly is destructive (namely to the LED connector as it is soldered to the main board) and has many unnecessary steps for simply replacing the trigger button assembly. It also says no parts are required but you would clearly need replacement trigger parts.
Peter Miller - Yanıt Paylaş
this did not help at all
lucas ainsworth - Yanıt Paylaş
I have searched a lot on the internet and cannot find any parts for it.
Dormius Oksivox - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 31
Son 30 gün: 109
Her zaman: 4,068
